How Do I Split A Roof Wall?
4hotshoez
Go to solution Solved by Kbird1,
  On 10/29/2014 at 4:14 PM, lbuttery said:
a pic or plan would probably help get better answers
Lew
The link provides the plan, I made an image but forgot to attach it. The image will explain more than words. Tomorrow I will post it.
  On 10/29/2014 at 11:49 PM, Alaskan_Son said:
I like Tommy's version better.
Teach a man to fish...
Incorrect Michael, GW has the correct answer.... I'll put up some good Mexican food against some of your salmon. The loser must send the winner the spoils via fed ex.
Deal...try Tommy's version and see what happens.  I would like Chili Colorado please.
Never heard of it. I looked it up, I will cook some up, I will cook enough that if it is worthy, I will send some to you..... win or lose.
My mother is hispanic...grew up in New Mexico.  I have the best of both worlds right here in Alaska.  You can keep your chili Scott.  Just mail me some warm sand and we'll call it even : )  Because you are definitely gonna lose.
Since you all are just guessing, I will attempt to explain in lieu of a picture. Imagine a gabled roof with the ceiling to the rafters, then directly behind that is another gabled roof slightly taller with the same pitch. There is a space on the wall between the two roofs that has siding on it, BUT on the inside the siding shows because the ceiling slope matches the rafters. I do not want siding to show on the inside. I want drywall. How do I do this?
  On 10/30/2014 at 12:05 AM, dshall said:
I assume you have tried GW's method, why do you think TB's method is better?
GW method is auto and auto corrects for any editing.
The question is why isn't the GW method the best?
They are the same method.  Tommy's suggestion just encouraged a little more effort from the OP.
  On 10/29/2014 at 8:16 PM, tommy1 said:
Open a wall and go to the roof section in the wall dbx, look at the bottom and see what it says. If you can't get that to work, try a pony wall.
My mistake, thus is what I was reading...... My mistake, I know Tommy knows the correct method.
