WhistlerBuilder Posted February 5, 2020 Share Posted February 5, 2020 Hi Chiefers, I have a weird issue where I have invisible walls being generated and I cannot figure out why. They appear to be generated in the middle of two other wall sections and run through a room. They do nothing, but are very annoying and I am trying to delete them but they keep being generated. I even copy pasted the area in question to a new file, tried everything to delete them, and its still not working. It's not in the room definition, heights, roofs etc... So confused by this. Any suggestions? invis wall question.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted February 5, 2020 Share Posted February 5, 2020 Sounds like a general wall default to me. "Connect Island Rooms" 1 Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted February 5, 2020 Author Share Posted February 5, 2020 Thanks solver. I uploaded the file now. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted February 5, 2020 Author Share Posted February 5, 2020 So I have no idea what that means... "Connect Island Rooms"? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 5, 2020 Share Posted February 5, 2020 Notice that if you turn off the default and delete the walls you will get duplicate Living Area totals for each Island Room. Not sure what else it does but you can keep the connections and change the wall to a blank or white line style. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted February 5, 2020 Author Share Posted February 5, 2020 Thanks. Turning off "Connect Island Rooms" allows me to delete these. Cheers, Link to comment Share on other sites More sharing options...
rgardner Posted February 5, 2020 Share Posted February 5, 2020 1 hour ago, solver said: The program wants them there. I'd put them on a new layer and turn that layer off. You can draw in your own connecting walls too. Don't need the Chief ones, but should have a connection. As Eric mentioned best to leave them in but hide them by changing layer or color to background color. Room labels/attributes will not work correctly and you will have some other "weird" little quirks happen if you delete them. I wish chief would automatically put them in on a separate layer or on the hidden walls layer. Link to comment Share on other sites More sharing options...
MoeGia Posted February 6, 2020 Share Posted February 6, 2020 You can set your room divider wall default to a specific layer. I have mine set to a custom layer 'Walls, no show plan' which have a dotted line style (I like to see them while working). The Chief created walls automatically come in on that layer. That layer is turned off in my printing layer sets. Link to comment Share on other sites More sharing options...
Dermot Posted February 6, 2020 Share Posted February 6, 2020 I recommend that you leave "Connect Island Rooms" turned on. The program puts them in because having unconnected island rooms can cause a multitude of problems with room definitions which can affect things like living area calculations, floors and ceilings, room moldings, etc. If you don't like where the program puts them, then just move them or draw your own and then you will be able to delete the ones the program put in. If you don't want to see them, then just turn the layer off. If you want to see your room divider walls, but not the automatic ones, then just put them on a custom layer and turn that layer off. Please remember that just because they are hidden they may still affect things like bumping, snapping, dimensions, etc. For this reason, I would keep them turned on in your working drawings but turn them off in your construction documents. Link to comment Share on other sites More sharing options...
gene1472 Posted August 12, 2022 Share Posted August 12, 2022 This forum never fails with it's wisdom. I had this same problem this morning, and this thread was the first to pop up in my search. Chopsaw, you are the man! Problem solved. Link to comment Share on other sites More sharing options...
MartyS Posted February 13 Share Posted February 13 I can't find "Connect Island Rooms" Looked in General walls and can't see it. I have Chief 15 Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 13 Share Posted February 13 30 minutes ago, MartyS said: I can't find "Connect Island Rooms" Looked in General walls and can't see it. I have Chief 15 That setting was removed in version X15. Link to comment Share on other sites More sharing options...
MartyS Posted February 13 Share Posted February 13 I( have the same problem with 15 and wall not able to delete. Anyway I can do this easly? Link to comment Share on other sites More sharing options...
DBCooper Posted February 13 Share Posted February 13 Quote I have the same problem with 15 and wall not able to delete. Anyway I can do this easly? I haven't had any plans where the invisible walls get added automatically since they got rid of the "connect island rooms" checkbox. You should post your plan and someone might be able to figure out what is going on. Or, just turn off the layer they're on. Link to comment Share on other sites More sharing options...
