winterdd Posted January 29, 2020 Share Posted January 29, 2020 hello fellow chiefers, i'm trying to figure out how to space my posts to beam as shown. where is the option to not space them equally on centers? Link to comment Share on other sites More sharing options...
winterdd Posted January 29, 2020 Author Share Posted January 29, 2020 19 minutes ago, solver said: Think about a 30' long wall divided into 3 10' sections. The center section is siding and the 2 outside sections are brick. How would you create that wall? Draw 4 railing walls to form a room (or a deck). Draw stairs. What happens to the railing? What does the program use to change the railing? no clue what you are trying to explain, however here is a pic. only one railing wall, post to beam to catch the porch roof. i want to slide the posts as shown. they are currently 120" o.c. and you cannot manually manipulate them. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 29, 2020 Share Posted January 29, 2020 Eric is talking about wall breaks. Draw a couple CAD lines; dimension them where you want the breaks, and then break the railing wall at the CAD lines. The posts will move. Link to comment Share on other sites More sharing options...
winterdd Posted January 29, 2020 Author Share Posted January 29, 2020 2 minutes ago, Ridge_Runner said: Eric is talking about wall breaks. Draw a couple CAD lines; dimension them where you want the breaks, and then break the railing wall at the CAD lines. The posts will move. hmm, i would have never thought to try that, but hey if it works it works lol Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 29, 2020 Share Posted January 29, 2020 If you don't want the post to move after breaking the original railing wall, pick the center railing wall and reverse its wall layers from the edit toolbar (wall with line and 2-arrows). That prevents the walls from rejoining if you accidentally adjust one of the end wall handles. Link to comment Share on other sites More sharing options...
winterdd Posted January 29, 2020 Author Share Posted January 29, 2020 it definately works BUT it did what i thought would happen. it threw another post in the center for the middle break so i chose "no post". thats makes it remove my beam as well. lol Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 30, 2020 Share Posted January 30, 2020 20 minutes ago, ChiefUserBigRob said: it threw another post in the center Just increase the newel spacing. In the future if you're trying to get rid of a post and the above technique isn't suitable, you can also set the newel width to ZERO. Link to comment Share on other sites More sharing options...
winterdd Posted January 30, 2020 Author Share Posted January 30, 2020 when i mess with the center railing and increase the spacing or set post size to zero it reconnects the whole railing. i will keep trying Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 30, 2020 Share Posted January 30, 2020 Did you reverse the wall direction as suggested above? That prevents the walls from rejoining. Notice the location of the "exterior layer" indicator: Link to comment Share on other sites More sharing options...
SNestor Posted January 30, 2020 Share Posted January 30, 2020 2 minutes ago, ChiefUserBigRob said: when i mess with the center railing and increase the spacing or set post size to zero it reconnects the whole railing. i will keep trying After you break the railing...select the center section and reverse it. This will keep it from re-joining the other rails. You could also just change its “wall type” and that would also keep it from re-joining. Link to comment Share on other sites More sharing options...
winterdd Posted January 30, 2020 Author Share Posted January 30, 2020 this is a fun one. reversing the wall worked to avoid rejoining. however this happened. let me change wall types, and see. Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 30, 2020 Share Posted January 30, 2020 2 minutes ago, ChiefUserBigRob said: this is a fun one. reversing the wall worked to avoid rejoining. however this happened. That's an issue with your wall definition. The technique works if your wall def is set up right, but as Eric said, so do doorways without having to reverse. Link to comment Share on other sites More sharing options...
winterdd Posted January 30, 2020 Author Share Posted January 30, 2020 and the winner goes tooooooooooooooooooooooooo, not reversing the wall type but changing the wall type. outer rails are "railing/fence. center rail wall is "interior railing". thanks guys, i would have never guessed those suggestions on my own. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 30, 2020 Share Posted January 30, 2020 6 minutes ago, ChiefUserBigRob said: this is a fun one. reversing the wall worked to avoid rejoining. however this happened. let me change wall types, and see. looks like you have Brick as the exterior wall material currently? try changing it to concrete and make the interior side the brick instead. ( since wall is reversed ) M. Link to comment Share on other sites More sharing options...
SNestor Posted January 30, 2020 Share Posted January 30, 2020 2 hours ago, solver said: And experiment with placing a doorway in the railing. Sometimes it's the simplest way. actually, Eric is right. Just place a doorway into the railing wall and size it how you need to space the posts. 3-4 clicks and - DONE. Link to comment Share on other sites More sharing options...
javatom Posted January 30, 2020 Share Posted January 30, 2020 Use various clever ideas to place posts where you want them - 15 min. Place them manually - 2 min. Link to comment Share on other sites More sharing options...
robdyck Posted January 30, 2020 Share Posted January 30, 2020 @ChiefUserBigRob There might be something in this post that helps... Link to comment Share on other sites More sharing options...
tommy1 Posted January 30, 2020 Share Posted January 30, 2020 9 hours ago, javatom said: Place them manually - 2 min. This is what I do and makes it easier to dimension for engineer. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 30, 2020 Share Posted January 30, 2020 17 hours ago, javatom said: Place them manually - 2 min. This works great for condocs, but during the design phase, when the client still isn't quite sure what they want, the auto railings and posts sure work quick to represent different design ideas. Link to comment Share on other sites More sharing options...
