dskogg Posted September 25, 2019 Share Posted September 25, 2019 i have added a few different columns to the hvac sched and renamed them, how do i get this info into each column? Link to comment Share on other sites More sharing options...
robdyck Posted September 25, 2019 Share Posted September 25, 2019 @dskogg Can you post a plan? Link to comment Share on other sites More sharing options...
Dermot Posted September 26, 2019 Share Posted September 26, 2019 Basically, you have to open the Note Specification dialog and enter the information on the Object Information panel (OIP) for the columns you renamed. Link to comment Share on other sites More sharing options...
dskogg Posted September 28, 2019 Author Share Posted September 28, 2019 On 9/26/2019 at 4:19 PM, Dermot said: Basically, you have to open the Note Specification dialog and enter the information on the Object Information panel for the columns you renamed. Expand Dermit only thing is those fields never appear to load text into.. I must be missing some thing.. Link to comment Share on other sites More sharing options...
robdyck Posted September 28, 2019 Share Posted September 28, 2019 On 9/28/2019 at 5:26 PM, dskogg said: Dermit only thing is those fields never appear to load text into.. I must be missing some thing.. Expand You just need to examine which fields you're entering text into, and ensure those fields are included in your schedule. Link to comment Share on other sites More sharing options...
dskogg Posted September 28, 2019 Author Share Posted September 28, 2019 When I open object those fields are not there to load info into? i must be missing something. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 28, 2019 Share Posted September 28, 2019 On 9/28/2019 at 5:57 PM, dskogg said: When I open object those fields are not there to load info into? i must be missing something. Expand Remember you are using a note schedule, so you need to use the OIP fields for the note. If you want to do it the other way you would need a Fixture schedule. Link to comment Share on other sites More sharing options...
dskogg Posted September 28, 2019 Author Share Posted September 28, 2019 On 9/28/2019 at 6:04 PM, Chopsaw said: Remember you are using a note schedule, so you need to use the OIP fields for the note. If you want to do it the other way you would need a Fixture schedule. Expand Dumb question oip? Link to comment Share on other sites More sharing options...
robdyck Posted September 28, 2019 Share Posted September 28, 2019 On 9/28/2019 at 6:41 PM, dskogg said: Dumb question oip? Expand No such thing. Object Information Panel You should post a screenshot of one of your notes with the dbx open. Or the plan. You'll get timely and accurate help! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 28, 2019 Share Posted September 28, 2019 Better yet, "Post the Plan" Link to comment Share on other sites More sharing options...
dskogg Posted September 29, 2019 Author Share Posted September 29, 2019 here is a couple of pics , there is no extra fields to input text, Link to comment Share on other sites More sharing options...
Gawdzira Posted September 29, 2019 Share Posted September 29, 2019 Oh, that is a U18 error. The problem is the user 18" from the screen is not posting the plan. Ehh. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 29, 2019 Share Posted September 29, 2019 On 9/29/2019 at 4:40 PM, dskogg said: here is a couple of pics , there is no extra fields to input text, Expand I see a blank Manufacture field but that is not the schedule you originally posted. Looks like you also created custom fields in your original posting. Link to comment Share on other sites More sharing options...
Dermot Posted September 29, 2019 Share Posted September 29, 2019 "i have added a few different columns to the hvac sched and renamed them, how do i get this info into each column?" So this all depends on what columns you added and renamed. For example, if you added the "manufacturer" column, then it is very easy to add your own custom info to the manufacturer data on the Object Information panel. But if you added a column that does not appear on the Object Information panel, then you may or may not be able to add any custom info. You can also add your own custom fields and columns. It would be much easier for someone to figure out what you did if you post a plan demonstrating what you did. Link to comment Share on other sites More sharing options...
dskogg Posted September 29, 2019 Author Share Posted September 29, 2019 here is an example, i changed the field names in the note schedule specifications, looking to load text into them but they dont show up even though i have added them to schedule...i must be missing something? note sched example.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted September 29, 2019 Share Posted September 29, 2019 David you need to create the fields in the note DBX and then apply them in the schedule DBX. Take a look at the revised plan file and I hope it makes some sense or you may have to hook up with someone live. note sched example Chopped.planFetching info... 1 Link to comment Share on other sites More sharing options...
dskogg Posted September 30, 2019 Author Share Posted September 30, 2019 On 9/29/2019 at 6:29 PM, Chopsaw said: David you need to create the fields in the note DBX and then apply them in the schedule DBX. Take a look at the revised plan file and I hope it makes some sense or you may have to hook up with someone live. note sched example Chopped.planFetching info... Expand I will try this.. how would I create fields? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 30, 2019 Share Posted September 30, 2019 I did not fix the Airflow Column in the test plan as it must have been something that was already giving a value of "1". Try adding that to the Note Specification OIP and then re apply it in the Schedule DBX. Enter your values in the Note DBX. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 30, 2019 Share Posted September 30, 2019 On 9/30/2019 at 12:28 AM, Chopsaw said: it must have been something that was already giving a value of "1" Expand It's the Renamed Qty. Column Chop so it's likely using the %automatic_count% macro so not very useful here as we don't have access to it AFAIK. David..... it's better to not use QTY and use a renamed Code or Comment Column ( old method ) to Airflow ( see pic) or create your Own Custom Fields for Airflow2 (in this case) or CFM if that is what the Column is for , then in the Schedule add the New CFM or Airflow2 Columns ( see pics) , from the available list, to the Columns to include. 1 Link to comment Share on other sites More sharing options...
