Summers Posted May 16, 2017 Share Posted May 16, 2017 I want to create basic detail notes and sheet notes which follow a letter or number outline. For example: 1. Alphabetical sheetnotes are not referenced in the plan; Numeric sheetnotes are referenced in the plan." The second line of text should indent flush with the first line of text. Can this basic set of notes be created in Chief (without importing a PDF from another program)? Also, is there any way to create columns of text? Thanks all. LS Link to comment Share on other sites More sharing options...
jorgearaya Posted May 17, 2017 Share Posted May 17, 2017 Use rich text and tabs Then again nothing close to using a text editor for best control and formatting. Link to comment Share on other sites More sharing options...
glennw Posted May 17, 2017 Share Posted May 17, 2017 This is easy to do with Chiefs Paragraph Option settings. Columns of text are a little harder. Link to comment Share on other sites More sharing options...
jorgearaya Posted May 17, 2017 Share Posted May 17, 2017 Unfortunately to get good results and fit text around is best to import .pdf The downside is the way Chief "Caches" the external files, I hope to see this improved sooner than later... Link to comment Share on other sites More sharing options...
ACADuser Posted May 17, 2017 Share Posted May 17, 2017 I don't think he was the one asking the question. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 17, 2017 Share Posted May 17, 2017 13 hours ago, glennw said: This is easy to do with Chiefs Paragraph Option settings. Columns of text are a little harder. Yep. There is A LOT more that can be done with the various paragraph options too. Also, for those who don't realize this, a person can also copy and paste tables from a spreadsheet or word processor into a Rich Text box. With regard to the columns. Glenn is correct. This is a bit harder but it is doable. There are at least 3 ways that come to mind but they do all require a little maintenance and proof checking from time to time if notes are added or changed. Option 1: Use multiple text boxes. This is probably the easiest. Option 2: Use a single row table in a Rich Text box. Fill up your first box (column) as far as you'd like and then just move to the next box to start your next column. Option 3: Use a single long text box and break it up in layout by using multiple layout boxes. Just resize the layout boxes so that they take a snapshot of different sections of the text box and then move them so that they are side by side. I use this method for schedules as well. Link to comment Share on other sites More sharing options...
Summers Posted May 17, 2017 Author Share Posted May 17, 2017 Thanks for your help everyone, but I still haven't figured it out. I'm using Rich Text, but I can't seem to find the solution in the Paragraph Options settings. Michael: You showed justified text in your post. Did you create it by pasting from your spreadsheet or word processor, or did you create it using Chief? Regards all, LS Link to comment Share on other sites More sharing options...
Summers Posted May 17, 2017 Author Share Posted May 17, 2017 To clarify: I created semi-justified text as Michael described, but using tabs. It's not very neat. I created three columns of text using multiple text boxes, which takes too long and is not very neat either. It appears the better choice for now is to use the word processor and import a pdf. I believe this shouldn't be necessary. Link to comment Share on other sites More sharing options...
BenPalmer Posted May 17, 2017 Share Posted May 17, 2017 I do this just fine within chief. I just create a new text box for the next column. Not very intuitive on doing the indentation, bullets, alignment etc, but once you know how to do it, it's pretty easy. Within Chief hit F1 to bring up help and search 'indent' and it will bring you to the section that shows you how to do it. Again, new column, new text box. Link to comment Share on other sites More sharing options...
glennw Posted May 18, 2017 Share Posted May 18, 2017 9 hours ago, Summers said: Thanks for your help everyone, but I still haven't figured it out. I'm using Rich Text, but I can't seem to find the solution in the Paragraph Options settings. I assume that you are referring to the numbered paragraphs. In the Rich Text dbx, hilite the text you want the formatting to apply to. Select Paragraph Options...Bullets...Type...select Numbers. There is a way to do columns in a rich text box. The text can also be formatted in many different ways. Open Excel or another spreadsheet program. Copy the number of blank cells you want. Paste into a rich text box. Or...you can do all the text in Excel and copy and paste the cells into a rich text box. I don't know of any other easy way to get editable columns into a text box. This is a rich text box in Chief after copying 3 rows and 2 blank columns from Excel and then all the text and formatting in Chief. Link to comment Share on other sites More sharing options...
jorgearaya Posted May 18, 2017 Share Posted May 18, 2017 To me this has been a great post to follow, watching all the attempts to make it work, how some have come up with ways to work around it, how some are now experimenting, what we did so many years ago, the best we could do was to keep making suggestions on the subject, knowing we would encounter some users that see the suggestions in a negative way. its been a good year for Chief, considering they get all of our fair and valid effort, to better the software at no cost. Importing formatted tables and comma separated values works great to a point, once the tables are in, there's no way to delete rows or columns, to re-organize them, to insert in between, and so on. I must praise Chief here, many other big boys out there can't i.e. ArchiCAD. (However it excels in .pdf) Chief knows the limitations, they also know that .pdf files don't update as they should, that saving them in plan does, but loses quality (virtually unreadable). The text in Chief is great for small tagging only, and it is widely used for that. When it comes to legends, key notes, general notes, etc then the current text does not work in a production setup. Link to comment Share on other sites More sharing options...
glennw Posted May 18, 2017 Share Posted May 18, 2017 Quote I don't think he was the one asking the question. Thanks for pointing that out. My apologies - I got a bit muddled and have deleted my post. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 18, 2017 Share Posted May 18, 2017 23 hours ago, Summers said: To clarify: I created semi-justified text as Michael described, but using tabs. It's not very neat. You shouldn't have to use tabs at all. Here's a quick primer on the subject... 6 Link to comment Share on other sites More sharing options...
ACADuser Posted May 18, 2017 Share Posted May 18, 2017 Very informative Michael, Thanks Link to comment Share on other sites More sharing options...
dshall Posted May 18, 2017 Share Posted May 18, 2017 3 hours ago, Alaskan_Son said: You shouldn't have to use tabs at all. Here's a quick primer on the subject... Flat out awesome!!! Great vid Michael, thank you very much. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 18, 2017 Share Posted May 18, 2017 Thanks Michael, that's pretty cool. We could even use text macros in the list items. Something more to think about. Link to comment Share on other sites More sharing options...
Northriver Posted May 18, 2017 Share Posted May 18, 2017 I never import PDF files into Chief Architect anymore. Adobe allows you to convert PDF's to a word document then I copy and paste into a text box . Any details on PDF's I convert to a DWG file and bring into Chief. Link to comment Share on other sites More sharing options...
BenPalmer Posted May 19, 2017 Share Posted May 19, 2017 I'd like to have auto numbering callouts...or numbers that are circled or square or triangles, for key notes and schedules. Is there an app for that? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 19, 2017 Share Posted May 19, 2017 25 minutes ago, BenPalmer said: I'd like to have auto numbering callouts...or numbers that are circled or square or triangles, for key notes and schedules. Is there an app for that? Based on your enormous smile I can't be sure if you're serious or not, but I have several different options that meet this description and might be able to help you out. I just sent you a PM. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 19, 2017 Share Posted May 19, 2017 Thanks for the video, Michael - very helpful. +1 Link to comment Share on other sites More sharing options...
dshall Posted May 19, 2017 Share Posted May 19, 2017 16 hours ago, Northriver said: I never import PDF files into Chief Architect anymore. Adobe allows you to convert PDF's to a word document then I copy and paste into a text box . Any details on PDF's I convert to a DWG file and bring into Chief. Jeff, It would be awesome if you were able to do a vid showing your process or better yet, a GOTOMEETING that I would be willing to host. 1 Link to comment Share on other sites More sharing options...
glennw Posted May 20, 2017 Share Posted May 20, 2017 You don't even have to convert to a Word document. Open a .pdf in Acrobat Reader or any other .pdf reader. Hilite the text, right click, Copy. Paste into a text box in Chief. In fact, you really don't even need to paste the text into a text box. Just Paste it directly into the plan and Chief will automatically paste it into a plain text box. You can then convert it to Rich Text with one click if that's what you need. But wait!.... There's more. If it's a .pdf of a drawing (like a survey, detail, etc) you can copy and paste directly into Chief. During the Paste, you are asked if you want to paste it in as a Backdrop, Image, Material or Picture. 2 Link to comment Share on other sites More sharing options...
Northriver Posted May 25, 2017 Share Posted May 25, 2017 On 5/19/2017 at 8:56 AM, dshall said: Jeff, It would be awesome if you were able to do a vid showing your process or better yet, a GOTOMEETING that I would be willing to host. Scott, I do not know how to make a video. I am not as computer savvy as some of you guys. The program we use to convert DWG is http://www.backtocad.com/pdf-to-dwg-converter.html. Recognizes both Vector and Raster lines along with text. Still figuring out all the options this program offers but have limited time as of lately. I am sure the person I hired to take over my responsibilities will figure it out. Glenn, thanks for sharing your methods and will I pass those along. Link to comment Share on other sites More sharing options...
