olyconstruction Posted November 11, 2016 Share Posted November 11, 2016 Hi Chiefs, I keep getting these lines in my elevation views that I don't know how to get rid of. They are not graphics issues because they are printing. In the attached PDF I have circled the lines I am talking about. I am attaching my plan too. The ones on the elevation sheet just show and I am not sure where they are coming from. One on the roof plane seems to be a wall poking through the roof, but in 3d it looks fine. In elevation the circled line does not show up in plan but is in layout and prints. It is not a cad line in layout. Whats up with that? Please let me know if you have had any luck eliminating lines like these and what I might do to do the same. Thank you for your help! question set.pdf HOUSE CONCEPT 2- 10-31-16.plan Link to comment Share on other sites More sharing options...
mattyt12 Posted November 11, 2016 Share Posted November 11, 2016 havent looked at the model to see as to why the lines are appearing but you can delete or edit unwanted lines with the edit Layout Lines Tool Link to comment Share on other sites More sharing options...
Chopsaw Posted November 11, 2016 Share Posted November 11, 2016 Alex, Some of those lines are almost impossible to figure out so if you are in a rush to get a set of drawings printed, then you will need to learn how to use this tool . Just as Matty says. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 11, 2016 Share Posted November 11, 2016 Hi Chiefs, I keep getting these lines in my elevation views that I don't know how to get rid of. They are not graphics issues because they are printing. In the attached PDF I have circled the lines I am talking about. I am attaching my plan too. The ones on the elevation sheet just show and I am not sure where they are coming from. One on the roof plane seems to be a wall poking through the roof, but in 3d it looks fine. In elevation the circled line does not show up in plan but is in layout and prints. It is not a cad line in layout. Whats up with that? Please let me know if you have had any luck eliminating lines like these and what I might do to do the same. Thank you for your help! I fight extra lines in elevations constantly and a lot of the time I give up trying to figure out where they come from and edit them out as suggested. The only problem is that any refresh of the elevation and you have to edit them out again, and again. Link to comment Share on other sites More sharing options...
country Posted November 11, 2016 Share Posted November 11, 2016 Have you looked at it in a glass house view? Quite often that shows the cause of these extra lines. Link to comment Share on other sites More sharing options...
Evolution Posted November 11, 2016 Share Posted November 11, 2016 Alex, see my attached sketch for the wall sections the lines I've marked appear to be the bump outs that you created in the area you call the "Squirrels Nest". If you move your section camera in and out you will see what I mean. I have to get back to work, and am not sure what the lines are in your Elevations. What I have found in the past, when similar conditions show up in my plans, I have stray line that was caused by some drawing action I did, some causes I found, some I never did! Hope this helps some? I did do the glass house and that's what led me to look at the bump outs. I moved your camera position and they disappeared, when I move it back they reappeared. ALEX QUESTION ON CA.pdf Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 11, 2016 Share Posted November 11, 2016 A lot of the lines ,but not all, you see will go away when printed to pdf, just look bad when viewing a plan. Try technical illustration for your elevations, that might help a bit. I don't get very many extra lines these days. There is usually something you have done that causes it. Link to comment Share on other sites More sharing options...
johnny Posted November 11, 2016 Share Posted November 11, 2016 This is one of my most hated elements of Chief - these sorts of "artifact" left-overs. I know we can tinker with the models to eliminate some of these lines, but I spend WAY too much time messing with it. Honestly, this issue may eventually make me leave using Chief it annoys me that much. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 11, 2016 Share Posted November 11, 2016 This is one of my most hated elements of Chief - these sorts of "artifact" left-overs. I know we can tinker with the models to eliminate some of these lines, but I spend WAY too much time messing with it. ...me too. Link to comment Share on other sites More sharing options...
glennw Posted November 11, 2016 Share Posted November 11, 2016 The vertical line on the end gable is caused by the interior wall on level 3. You don't have any external walls to define the areas in the roof space on level 3. Draw the external walls to enclose the spaces. Link to comment Share on other sites More sharing options...
