DTCBuild Posted February 5, 2016 Share Posted February 5, 2016 In X7 in the Roof dbx you could change the roof material. In X8 I can't see it anywhere. I can see soffit, Fascia and other materials but not the actual roof material. Any idea where it went. Thanks, Dennis Link to comment Share on other sites More sharing options...
glennw Posted February 5, 2016 Share Posted February 5, 2016 Roof Plane Specification dbx...Structure panel...Roof Layers...Surface...Edit. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 5, 2016 Share Posted February 5, 2016 "Edit - Default Settings - Materials - Roof" and what Glenn said DJP Link to comment Share on other sites More sharing options...
DTCBuild Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks, got it! Wish they would stop moving things Progress I suppose. Dennis Link to comment Share on other sites More sharing options...
mtldesigns Posted February 13, 2016 Share Posted February 13, 2016 glad you already asked this question.. I can keep going. Link to comment Share on other sites More sharing options...
DougMaddox Posted February 13, 2016 Share Posted February 13, 2016 That makes no sense. Should be in "materials". My two cents Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 13, 2016 Share Posted February 13, 2016 That makes no sense. Should be in "materials". My two cents Just one man's opinion, but I think they've done the right thing. They've set it up to work more like wall and room definitions where multiple layers can be assigned. I think it makes for better organization and stability under the structure tab where they have it now. Link to comment Share on other sites More sharing options...
norryboy Posted February 19, 2016 Share Posted February 19, 2016 Changing the default material does not update the roof planes like it used to. I think it's fine to have the roof layers brook down the way they do, but you should be able to change the material default and have the roof surface change they way it used to. Now you need to either "edit all roof planes" or rebuild roof. Rebuilding roof is fine if you don't have any manually drawn roofs. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 19, 2016 Share Posted February 19, 2016 Changing the default material does not update the roof planes like it used to. I think it's fine to have the roof layers brook down the way they do, but you should be able to change the material default and have the roof surface change they way it used to. Now you need to either "edit all roof planes" or rebuild roof. Rebuilding roof is fine if you don't have any manually drawn roofs. Just use the material painter. Link to comment Share on other sites More sharing options...
norryboy Posted February 19, 2016 Share Posted February 19, 2016 I have not had good results using the material painter for roofs. It sometimes gives unintended results when applying to a roof with cape dormers. It was just as easy to open materials and change the default for roof and ridge cap. Now the only thing that adjusts with this method is the ridge cap. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 19, 2016 Share Posted February 19, 2016 Not at my computer to test right now, but have you tried the match properties tool? Link to comment Share on other sites More sharing options...
mrscott Posted May 23, 2016 Share Posted May 23, 2016 I've tried the floor and plan painter to fix sash and trim colors but it changes the whole window. If I want brite white interior and exterior sash and brute white interior trim and dark grey exterior trim when I set these on one window and click the painter eye dropper and select say the exterior trim and click on the another exterior trim piece everything on all windows turn grey. What am I doing wrong? Link to comment Share on other sites More sharing options...
ShaneK Posted May 23, 2016 Share Posted May 23, 2016 Got to window dbx and change each material there or change window defaults. Link to comment Share on other sites More sharing options...
ShaneK Posted May 23, 2016 Share Posted May 23, 2016 pic Link to comment Share on other sites More sharing options...
