djhplanning Posted January 27, 2016 Share Posted January 27, 2016 What is the best way to add horizontal siding to the above grade portion of an ICF foundation wall. See attached photos. I used a wall material region and painted on siding but I am getting these vertical streaks showing. I believe there are walls on the interior of the foundation where these streaks are showing. What is happening here? Is there another better way to show siding on this portion of the ICF foundation wall? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 27, 2016 Share Posted January 27, 2016 Just a guess, maybe you need to increase the thickness of the siding material region. Graham Link to comment Share on other sites More sharing options...
dshall Posted January 27, 2016 Share Posted January 27, 2016 Just a guess, maybe you need to increase the thickness of the siding material region. Graham I seriously doubt that Link to comment Share on other sites More sharing options...
dshall Posted January 27, 2016 Share Posted January 27, 2016 I bet there are some invisible walls that are causing the break in siding. I wonder how many posts it will take to solve this. I am betting we get to number 13 without an answer. This is number 4. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 27, 2016 Share Posted January 27, 2016 I think it could be a wall connection going all the way through the wall. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 27, 2016 Share Posted January 27, 2016 I seriously doubt that That's why I covered my butt by saying "just a guess". Looking closer the siding breaks do appear to align with the interior wall intersects as you noted. If the plan was posted then maybe it could be resolved in less than 13 posts. Only 7 postings left to go after this one. Graham Link to comment Share on other sites More sharing options...
rlackore Posted January 27, 2016 Share Posted January 27, 2016 Instead of Material Regions have you considered defining a Wall Type with your desired exterior siding material? That's the method I use for ICF construction, though it probably won't fix the issue shown in your post. Link to comment Share on other sites More sharing options...
javatom Posted January 27, 2016 Share Posted January 27, 2016 My wild guess would be a left over attic wall that now needs to be deleted. Link to comment Share on other sites More sharing options...
djhplanning Posted January 27, 2016 Author Share Posted January 27, 2016 The streaks will go away for a while if I apply the siding again or if I open the wall material region dialog box, change nothing and hit ok to close. Then after a while they will appear again. ??? I have also tried unchecking the cut finish layers of parent object box in dialog box. Link to comment Share on other sites More sharing options...
Evolution Posted January 27, 2016 Share Posted January 27, 2016 Wonder what would happen IF you post the plan? Link to comment Share on other sites More sharing options...
NRST8TRKR Posted January 27, 2016 Share Posted January 27, 2016 I say the interior walls are somehow showing through the applied siding. Make a new wall type as suggested above. Have a great week,Ken Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 27, 2016 Share Posted January 27, 2016 Looks like that but I played with a simple model and could not replicate it no matter what I did with the interior walls. They always snapped properly to the inside face as they should. Even extended an invisible wall through and it did not disrupt the siding finish. Played with the wall material region, changed thickness, cut finish on/off, etc, everything worked as it should. The problematic plan needs to be posted. This was done on X7. Graham Link to comment Share on other sites More sharing options...
Rosco2017 Posted January 27, 2016 Share Posted January 27, 2016 Please post the plan and I bet we can solve this in no time. If you're uncomfortable posting the plan, then feel free to contact customer support. See photo below. 1 Link to comment Share on other sites More sharing options...
javatom Posted January 28, 2016 Share Posted January 28, 2016 And just like that, Scott is the winner. Post #13 and no solution. Link to comment Share on other sites More sharing options...
dshall Posted January 28, 2016 Share Posted January 28, 2016 And just like that, Scott is the winner. Post #13 and no solution. lol, it really was not too difficult to predict a solution could not be had without a plan. The really difficult part is predicting the number of guesses without a plan. But I will take the winner's medal and put it on my mantle next to my "Jerk of the Month" award. But on to more important topics, who will win the Super Bowl? My prediction.... Denver, they have the best defense and the most experienced quarterback. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 28, 2016 Share Posted January 28, 2016 What is the best way to add horizontal siding to the above grade portion of an ICF foundation wall. See attached photos. I used a wall material region and painted on siding but I am getting these vertical streaks showing. I believe there are walls on the interior of the foundation where these streaks are showing. What is happening here? Is there another better way to show siding on this portion of the ICF foundation wall? Hey Dan, As the others have said, it would really best to attach the plan file. Its too difficult to tell simply based on screenshots exactly how you've constructed your model. There are just a ton of little variables that come into play. It looks like your problem is probably rooted in your wall definitions though. Again, attach a plan for a more accurate answer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 28, 2016 Share Posted January 28, 2016 I don't want to sound like a jerk Dan, I'm really just trying to be helpful...truth is that if you're not willing to help us help you by posting a plan that you're pretty quickly gonna burn some bridges around here. It may not be your intention, but as a group we end up spending an inordinate amount of time guessing at problems that are more often than not solved very quickly when a plan is attached. I've seen countless threads answered in mere minutes when plans are attached. I've also seen a ton of 10-15 post threads where the problem is never solved because there's no plan to look at. Link to comment Share on other sites More sharing options...
djhplanning Posted January 28, 2016 Author Share Posted January 28, 2016 Here is the plan file for the project I am working on. Addition 1-28-16.plan 1 Link to comment Share on other sites More sharing options...
dshall Posted January 28, 2016 Share Posted January 28, 2016 Here is the plan file for the project I am working on. I opened in X8, I made no changes, I did full overview, I do not see problem, I cannot explain why you are having a problem. Link to comment Share on other sites More sharing options...
dshall Posted January 28, 2016 Share Posted January 28, 2016 Try reopening and check again, maybe it was fixed when you opened and closed the file. Link to comment Share on other sites More sharing options...
rlackore Posted January 28, 2016 Share Posted January 28, 2016 When I open/close the Material Region dbx, the problem vanishes until I close/open the plan file. I don't know what's up with the Material Regions, but you can eliminate the problem using Wall Types. 1) Delete the Material Regions. 2) Define a Wall Type for ICF with the siding: 3) Select the appropriate walls and define them as pony walls: 4) Enjoy the result: Link to comment Share on other sites More sharing options...
djhplanning Posted January 28, 2016 Author Share Posted January 28, 2016 I just closed and reopened the plan and I get the same problem. Maybe this is something that was fixed in X8? I am currently using X7 and have not upgraded yet. Link to comment Share on other sites More sharing options...
djhplanning Posted January 28, 2016 Author Share Posted January 28, 2016 When I open/close the Material Region dbx, the problem vanishes until I close/open the plan file. I don't know what's up with the Material Regions, but you can eliminate the problem using Wall Types. 1) Delete the Material Regions. 2) Define a Wall Type for ICF with the siding: icf1.PNG 3) Select the appropriate walls and define them as pony walls: icf2.PNG 4) Enjoy the result: icf3.PNG Thanks for the help with setting up a wall type for this. I figured there was a better way but have not been working with Chief for very long. Link to comment Share on other sites More sharing options...
dshall Posted January 28, 2016 Share Posted January 28, 2016 I just closed and reopened the plan and I get the same problem. Maybe this is something that was fixed in X8? I am currently using X7 and have not upgraded yet. I can confirm, I opened in x7 and I see the problem, I do not have problem in x8. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 28, 2016 Share Posted January 28, 2016 Thanks for attaching the plan...I gave you a reputation point as a token of my appreciation : ) As Robert pointed out, the biggest problem is your wall definition. In X7 you can open those 2 exterior walls and without making any changes just click OK and close the wall dbx and the problem sort of goes away. Better wall definition still the way to go though. Even adding another zero thickness exterior foam layer fixes the problem. I think the issue arises because all you have is main layers. Therefore, there's no "buffer" between your interior walls and the exterior of your exterior wall. The material region automatically cuts for doors, windows, and wall changes, and because of that lack of a "buffer", it gets confused. This is just a guess though. Another possible solution would be to build a separate furring wall instead of using a material region (or pony wall). 1 Link to comment Share on other sites More sharing options...
