SHCanada2 Posted August 13 Share Posted August 13 (edited) anyone seen this behaviour? Updating the layout causes window labels to show then not show Screen Recording 2026-08-13 150124.mp4 he layout boxes seems to cause different window/door lables to appear, but never all of them at the same time Edited August 13 by SHCanada2 Link to comment Share on other sites More sharing options...
robdyck Posted August 15 Share Posted August 15 I've also noticed inconsistency with the automatic label display and have to frequently select items and set the label to 'show' in the view. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 15 Author Share Posted August 15 ...interesting.... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 15 Share Posted August 15 I suspect that's just a screen issue for the type of render being used. If you print to a pdf all the labels should b displayed properly. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 16 Author Share Posted August 16 (edited) hmmm, still doesn't print correctly. it's weired because it is not the same window(s) every time Edited August 16 by SHCanada2 Link to comment Share on other sites More sharing options...
HMK_RD Posted August 20 Share Posted August 20 On 8/15/2026 at 10:23 PM, SHCanada2 said: hmmm, still doesn't print correctly. it's weired because it is not the same window(s) every time I ran into this issue today, so not just you. Mine was where half where labeled and half weren't. Link to comment Share on other sites More sharing options...
joey_martin Posted August 20 Share Posted August 20 Report it. It's a bug. We have 8 licenses in the the office and we are all having this issue after the latest update. Our cabinet fills are also all messed up now in our template. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 21 Author Share Posted August 21 i did and they said to, as Robert says, "select items and set the label to 'show' in the view." Link to comment Share on other sites More sharing options...
joey_martin Posted August 21 Share Posted August 21 We have those set to show, but they randomly disappear then reappear with no real rhyme or reason. Link to comment Share on other sites More sharing options...
DBCooper Posted August 21 Share Posted August 21 Quote We have those set to show, but they randomly disappear then reappear with no real rhyme or reason. Yeah, I have noticed some funky behavior that seems to be related to camera angles. My guess is that you don't really have them set to "show" and you are still using "automatic". In camera views, labels can be set to "show", "hide", or "automatic". When they are set to automatic, they will sometimes show and sometimes not. If they are showing and you don't want them to, then just force them to hide. If they are not showing and you want them to, then just force them to show. When you use the edit toolbar button, I think it will either force them to show or hide and it should turn off the automatic behavior. If they are not doing what you want when you have them set to automatic, you still might want to send this to Chief and "suggest" that they make the automatic behavior work better. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 21 Author Share Posted August 21 2 hours ago, DBCooper said: If they are not doing what you want when you have them set to automatic, you still might want to send this to Chief and "suggest" that they make the automatic behavior work better they appear and don't appear simply by updating the view. sound like a bug vs an intended design needing an improvement suggestion Link to comment Share on other sites More sharing options...
KilianDrafting Posted September 16 Share Posted September 16 I have this problem when I have an elevation that I previously sent to a layout open. When I have it zoomed in to an area and some of the windows are out of view, it seems when you force the update in the layout with that tab still open, it removes the labels that are outside the current view area. If you close the tab first or zoom out to the extents to make sure all the windows are in view, and then force the layout to update, the labels should display automatically per your display options. Definitely a bug. Link to comment Share on other sites More sharing options...
KilianDrafting Posted September 16 Share Posted September 16 (edited) On 8/13/2026 at 5:32 PM, SHCanada2 said: anyone seen this behaviour? Updating the layout causes window labels to show then not show Screen Recording 2026-08-13 150124.mp4 10.95 MB · 0 downloads he layout boxes seems to cause different window/door lables to appear, but never all of them at the same time @SHCanada2 Try zooming out on the view or close the tab, then update. When you zoom in and update an open elevation tab, for whatever reason it hides the labels on any windows out of the current view. Edited September 16 by KilianDrafting Link to comment Share on other sites More sharing options...
