Michael_Gia Posted 20 hours ago Share Posted 20 hours ago When I order trusses or floor systems I usually send a pdf of the plans generated in Chief. I want to change that and instead send an AutoCAD layout file instead of a PDF. This is to avoid errors of miscommunications when for example a dimension is missing etc. If they have the AutoCAD file then they can measure whatever they want. Anyone else do this? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 19 hours ago Share Posted 19 hours ago Can't say that I do, BUT I'm 99% certain AutoCAD has built in functionality for both converting vector based PDFs to DWG and for snapping to underlying PDF vectors. Most PDF editors have snapping and measuring capabilities as well. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted 19 hours ago Share Posted 19 hours ago 1 hour ago, Michael_Gia said: If they have the AutoCAD file then they can measure whatever they want. Anyone else do this? some engineers and interior designers ask for this from me. I just export it from CA and send it along. For the truss people, they have never asked for a DXF or DWG file. ...that said they have made mistakes more than once, but it wasnt because it wasn't dimensioned, it was just that they missed it or in one case, got an off angle wall incorrect Link to comment Share on other sites More sharing options...
para-CAD Posted 19 hours ago Share Posted 19 hours ago (edited) I used to use AC as a 2D crutch. Gone. I make sure truss guys get span and pitch....and vault if part of the design...on my plans. Framer's get the the truss plans...or if stick framed I send cut sheets to builders I trust who trust me. Now I use SU as a 3D tool because I can 100% correctly model complex framing, something CA doesn't always do. AC LT isn't too bad of a subscription....cross platform too. Edited 18 hours ago by para-CAD Link to comment Share on other sites More sharing options...
