Ed_Orum Posted Monday at 06:43 PM Share Posted Monday at 06:43 PM Hello again, I would like to show the room divider as a single line, but after I draw the divider (I draw it in the center of the wall I want to divide), it shows up as two lines, and the two lines line up with what the program generates as basically a wall. I want a true divider, so I can place it where I want it in relation to say the end cap of a wall, and it will actually show up where I place it, and as a single line, not as a double line. I checked all of my default settings, wall settings, etc. and I can't see anywhere it is a double line. But that's what shows up. How do I fix this? Thanks, Lane Link to comment Share on other sites More sharing options...
Chrisb222 Posted Monday at 07:35 PM Share Posted Monday at 07:35 PM 43 minutes ago, Ed_Orum said: I would like to show the room divider as a single line, but after I draw the divider, it shows up as two lines I normally see that when there's a change in the ceiling or floor height relative to the adjacent room, the single line will become a double line full thickness wall. In those cases there's no way that I know to change it back to a single line. 50 minutes ago, Ed_Orum said: (I draw it in the center of the wall I want to divide) When I tried this, the room divider remained a single line, but the rooms have the same floor and ceiling heights. If you don't have a difference in the floor or ceiling height in the room, maybe post the plan so we can take a look. Link to comment Share on other sites More sharing options...
PitMan71 Posted Wednesday at 11:28 PM Share Posted Wednesday at 11:28 PM (edited) This used to baffle me as well..... In my experience that happens when an attic wall is generated above for some reason such as in situations like @Chrisb222 said. Edited Wednesday at 11:29 PM by PitMan71 Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 11:46 PM Share Posted Wednesday at 11:46 PM You can always try using a new wall type that is only 1/16" thick. Might not be structurally accurate for all situations but would look how you want in a plan view. 1 Link to comment Share on other sites More sharing options...
