CreativeDrafting Posted December 11, 2023 Share Posted December 11, 2023 Hello! I am new to drafting and am trying to start on the best foot. I plan to use 2 monitors. What size and quality monitor would you recommend? Thank you. 1 Link to comment Share on other sites More sharing options...
Hammer7 Posted December 11, 2023 Share Posted December 11, 2023 I'm still using two Samsung 32" TVs, I will probably next try a larger curved monitor. I had a 55" third TV but that took some cord gymnastics rigged up by someone else to get set up. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted December 11, 2023 Share Posted December 11, 2023 As a general rule, bigger is better, but only up to a point. The resolution and refresh rate also matter. A larger monitor with the same resolution may not look better when your face is only 2' from it. If the refresh rate is not fast enough the screen flicker might even be noticeable. And if you are getting two, I recommend that you you match them otherwise it can be a bit annoying going from one to the other. Here is some good info from Chief about system specs: https://www.chiefarchitect.com/blog/computer-for-design-and-gaming/ 1 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 11, 2023 Share Posted December 11, 2023 36 minutes ago, CreativeDrafting said: What size and quality monitor would you recommend? You need to first determine what ppi (pixel density) your video card is sending to the monitor. Then buy a monitor that matches that or exactly half that ppi. Or your system won’t be optimized, that is you’ll have unwarranted lag. The formula is out there, but as an example a 34” monitor with 3440x1440 resolution = 110 ppi. So you would pair that with a video card that is sending out 110 ppi or 220 ppi., ideally. I actually returned a 4K monitor and replaced it with a lower 1440p monitor which increased not only speed but clarity. I was getting “fuzzy” characters with the 4K monitor. This is what I learned from the googles after much research. And believe me there aren’t many people talking about this little known and bizarre predicament which effects both Mac and PC’s. Everyone wants to sell you the highest definition monitor and that’s all they know. And that’s not always the best choice. Many people have such beasts as machines so it’s hard to detect the lag if you don’t know it’s there. You don’t know what you don’t know, like my grandpa used to always say… 1 Link to comment Share on other sites More sharing options...
para-CAD Posted December 11, 2023 Share Posted December 11, 2023 Orientation also matters 2 Link to comment Share on other sites More sharing options...
DRyeHD Posted January 24, 2025 Share Posted January 24, 2025 @para-CADI just watched this video. Lots of good information. Thanks for posting. I'm trying to determine the best way to incorporate a 2nd monitor. Link to comment Share on other sites More sharing options...
raltd9245 Posted January 24, 2025 Share Posted January 24, 2025 It is all in the eyers of the beholder. I have two 27 inch and find it ok. My draftsman has six 27 inch monitors and is a heavy producer Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 24, 2025 Share Posted January 24, 2025 I have 2- 43" 4k monitors and love it. of course, my eyes need them. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted January 24, 2025 Share Posted January 24, 2025 A 50" (which I have) is the very largest. I would recommend 45" to 48". My neck hurts if I look at the top menu too much. (Vertically stacked monitors is a bad idea.) I put my toolbars on the bottom and sides. I use an adjustable TV stand so that the bottom of the monitor is level with the top of my 3'x6' desk and the monitor is 3'+ away from me. 4k is great. But you have to adjust the text size. Refresh rates are not important since you are not watching movement like sports, but I recommend 60 Hz minimum. The lower refresh rate will save you money. TV Stand.pdf Link to comment Share on other sites More sharing options...
