Why Are Two Rooms Showing Up As The Same Room?
DB-Designs
Hello Everybody! I have a house plan with a walk out basement that leads to a patio at the same basement floor level. The basement is partially finished with an unfinished mechanical room on the other side of the basement. When I double click in the exterior patio to open the room specifications, the mechanical room is attached to it too. So when I change finishes in the exterior patio, the same changes happen in the mechanical room. Any idea of why this would be happening? Thanks everybody.....for all the help!!!
What's so confusing is that the two areas are just about on opposite sides of the house. One is interior and one is exterior. There are a few different rooms between the two areas and they act as their own rooms. There are no walls labeled "no room definition" and I went around detached and reattached all the walls. I will keep messing with it and if there are more suggestions, please share. Thanks again everybody..........for all your help!!
