cbucks Posted April 25, 2022 Share Posted April 25, 2022 Good day what’s the best way to show Huberwood Zip System and Advantech Subfloor? Link to comment Share on other sites More sharing options...
joey_martin Posted April 25, 2022 Share Posted April 25, 2022 Build your wall layers exactly like the product. Don't over think it. NOTE: The 1/16" layer I use just as the ZIP outer layer showing the material, and it gives me the 1/2" sheeting layer. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 25, 2022 Share Posted April 25, 2022 For the subfloor, which looks like anybody's OSB, you just call it out in specs and point to it in a CAD detail. Link to comment Share on other sites More sharing options...
rgardner Posted April 25, 2022 Share Posted April 25, 2022 42 minutes ago, GeneDavis said: For the subfloor, which looks like anybody's OSB, you just call it out in specs and point to it in a CAD detail. Just to add to this good advice, you can if you need to for your material takeoff for example copy the OSB material and rename it Advantech 3/4" T&G Subflooring. If you really were specific enough you can actually get a picture and just create it from scratch as well but I don't think I would ever see a need to actually see the advantech logo on a rendering or 3d view. Maybe if you were doing a 3d detail or something I guess. But it is doable. Link to comment Share on other sites More sharing options...
rgardner Posted April 25, 2022 Share Posted April 25, 2022 1 hour ago, rgardner said: Just to add to this good advice, you can if you need to for your material takeoff for example copy the OSB material and rename it Advantech 3/4" T&G Subflooring. If you really were specific enough you can actually get a picture and just create it from scratch as well but I don't think I would ever see a need to actually see the advantech logo on a rendering or 3d view. Maybe if you were doing a 3d detail or something I guess. But it is doable. Had a minute and thought might as well play with Gimp which I recently downloaded and hadn't tried yet. Here is a 3/4" 4x8 sheet size 1/2 offset Advantech subflooring material. Advantech .75%22 Subflooringcalibz.calibz 2 Link to comment Share on other sites More sharing options...
DG1949 Posted April 25, 2022 Share Posted April 25, 2022 3 hours ago, rgardner said: Had a minute and thought might as well Thank you for sharing this. Excellent! Link to comment Share on other sites More sharing options...
SNestor Posted April 25, 2022 Share Posted April 25, 2022 Fantastic... Link to comment Share on other sites More sharing options...
javatom Posted April 25, 2022 Share Posted April 25, 2022 Why would it be important to have a material like this. Link to comment Share on other sites More sharing options...
cbucks Posted April 25, 2022 Author Share Posted April 25, 2022 7 hours ago, rgardner said: Just to add to this good advice, you can if you need to for your material takeoff for example copy the OSB material and rename it Advantech 3/4" T&G Subflooring. If you really were specific enough you can actually get a picture and just create it from scratch as well but I don't think I would ever see a need to actually see the advantech logo on a rendering or 3d view. Maybe if you were doing a 3d detail or something I guess. But it is doable. Works great! Thank you! Out of curiosity how did you make that? Link to comment Share on other sites More sharing options...
rgardner Posted April 26, 2022 Share Posted April 26, 2022 2 hours ago, cbucks said: Works great! Thank you! Out of curiosity how did you make that? Found a picture of a sheet online and used a photo editor to make a scaled continuous material. Then just set the different specifications in the material dbx. https://www.chiefarchitect.com/support/article/KB-00767/creating-a-new-material.html check out this article for the basics. 1 Link to comment Share on other sites More sharing options...
NRST8TRKR Posted April 27, 2022 Share Posted April 27, 2022 Thaks Ryan, Always nice to have that little extra just because! have a great week, Ken Link to comment Share on other sites More sharing options...
