Bob_Johnston Posted April 23, 2022 Share Posted April 23, 2022 I'm doing a story and a half plan with the north wall being a very large gable with balloon framing at the stairs. I want to do a full framing elevation of the entire wall but the "Open Wall Detail" will only allow me to select one section (1st floor or 2nd floor) at a time and I can't get a wall detail of the attic walls at all. Is there a way to accomplish this that I'm not aware of? As an example, here's the 1st floor wall detail and a shot of the entire elevation. How do I show the entire north wall framing? Thx Link to comment Share on other sites More sharing options...
Solution robdyck Posted April 23, 2022 Solution Share Posted April 23, 2022 I don't want to try to influence your methods but wall framing details should be separated by the floor they sit on. But if you must show a framing elevation view, then simply take a back clipped elevation camera view and use a custom layer set. Make a copy of the layer set that you use for 3d framing views and then adjust it as you see fit. Note that in X13 you will not be able to snap to framing members in this type of view. Another option would be to stack / align the separate wall detail drawings on the layout page. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2022 Share Posted April 23, 2022 I'd try making my own back clipped View say 8" and a dedicated Layerset that doesn't show anything except the Wall Framing and perhaps a few other components eg Rim Joists as needed. And possibly Send View to a Cad Detail if needed. * great minds think alike M. Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 Here's an example of a walkout basement using the 3D Framing layer set. Easy peasy. Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 Thanks for the responses. Here's the back-clipped view. I think this is helpful. I just wish I could get the attic walls to show because I will probably want to run those studs full length. Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 10 minutes ago, Bob_Johnston said: I just wish I could get the attic walls to show. The attic wall or the attic wall framing? Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 Just now, robdyck said: The attic wall or the attic wall framing? framing Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 Just now, Bob_Johnston said: framing So why can't you? Do you have attic walls framed? Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2022 Share Posted April 23, 2022 1 minute ago, robdyck said: Do you have attic walls framed? Would be my 1st thought too assuming Attic Walls layer is On , not just Walls, Normal M. Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 If they are framed, and if you have not changed, and then turned off the display of the layer of the wall framing, they will show in that view. Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 19 minutes ago, Bob_Johnston said: because I will probably want to run those studs full length. Wall structure , balloon through ceiling. Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 4 minutes ago, Kbird1 said: Would be my 1st thought too assuming Attic Walls layer is On , not just Walls, Normal M. I built my wall framing. I don't see a spot in the dialog box where I can just do the attic walls. Link to comment Share on other sites More sharing options...
robdyck Posted April 23, 2022 Share Posted April 23, 2022 Select the attic walls, then select Build Framing For Selected Object(s) Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 6 minutes ago, robdyck said: Select the attic walls, then select Build Framing For Selected Object(s) Got it. I may have to do this manually, I don't see any reason to break this wall with plates (and I obviously need to get my framing reference set correctly for the 1st and 2nd floors to get those studs lined up). Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2022 Share Posted April 23, 2022 9 minutes ago, Bob_Johnston said: I don't see any reason to break this wall with plates Your Framer, especially his Back may disagree , but Eng. may disagree with Him too Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 1 minute ago, Kbird1 said: Your Framer, especially his Back may disagree , but Eng. may disagree with Him too I am the framer Link to comment Share on other sites More sharing options...
Gawdzira Posted April 23, 2022 Share Posted April 23, 2022 Did you select this wall you want to balloon and check this button? Link to comment Share on other sites More sharing options...
Bob_Johnston Posted April 23, 2022 Author Share Posted April 23, 2022 17 minutes ago, Gawdzira said: Did you select this wall you want to balloon and check this button? No I did not and that is exactly what I needed. I checked the box and deleted the attic walls and this is the result. Still a little funkiness going on but I can live with it. Thank you everyone for all your help. Link to comment Share on other sites More sharing options...
para-CAD Posted April 23, 2022 Share Posted April 23, 2022 Can all the components be dimensioned? I would do that in auto cad, when I was a full time framer and create a cut drawing. it would be cool if Chief could do that. 1 Link to comment Share on other sites More sharing options...
rgardner Posted April 23, 2022 Share Posted April 23, 2022 1 hour ago, para-CAD said: Can all the components be dimensioned? I would do that in auto cad, when I was a full time framer and create a cut drawing. it would be cool if Chief could do that. Have you tried it? 1 Link to comment Share on other sites More sharing options...
para-CAD Posted April 24, 2022 Share Posted April 24, 2022 I'm asking. Why do you do that? I asked about a deck once and that was your answer...a question. No help at all. If it doesn't do that, then why would I waste time to find out. Someone could just say....nope......or yep.......and that would be that. Autocad DOES it. That's what I use. Maybe someone else can ANSWER my question - not with a question. 1 Link to comment Share on other sites More sharing options...
rgardner Posted April 24, 2022 Share Posted April 24, 2022 5 minutes ago, para-CAD said: I'm asking. Why do you do that? I asked about a deck once and that was your answer...a question. No help at all. If it doesn't do that, then why would I waste time to find out. Someone could just say....nope......or yep.......and that would be that. Autocad DOES it. That's what I use. Maybe someone else can ANSWER my question - not with a question. Yep 1 Link to comment Share on other sites More sharing options...
rgardner Posted April 24, 2022 Share Posted April 24, 2022 6 minutes ago, para-CAD said: I'm asking. Why do you do that? I asked about a deck once and that was your answer...a question. No help at all. If it doesn't do that, then why would I waste time to find out. Someone could just say....nope......or yep.......and that would be that. Autocad DOES it. That's what I use. Maybe someone else can ANSWER my question - not with a question. Sorry if asking a question offended you. What I was trying to get across was that it is a very simple thing to search or even just test quickly in Chief. In fact would have taken a lot less time to search the question or try it in Chief. In answer to your question yes you can dimension to framing members. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 24, 2022 Share Posted April 24, 2022 I have not put it to the test but x14 has a cut list for framing members. Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 24, 2022 Share Posted April 24, 2022 According to the video I watched on new features, X14 will dimension the cut length, but angled cuts are measured to the center of the angle. I never heard a framer reference the center of an angle cut, it's always to the "long" or to the "short." I can't WAIT to see the reactions when they're given the center of the angle... on second thought, I don't want to be around; hammers may be thrown. 1 Link to comment Share on other sites More sharing options...
