Ntsako Posted March 19, 2022 Share Posted March 19, 2022 please help Link to comment Share on other sites More sharing options...
MoeGia Posted March 19, 2022 Share Posted March 19, 2022 Sounds like you might want to use a metric template and set your defaults to metric, not inches. Only a guess! Link to comment Share on other sites More sharing options...
rgardner Posted March 19, 2022 Share Posted March 19, 2022 Or perhaps it is your design process/workflow? If you are getting non even numbers it is up to you to place the walls in the place you want them. Maybe this article (https://www.chiefarchitect.com/support/article/KB-01116/moving-walls-using-dimensions.html) will help? 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted March 19, 2022 Share Posted March 19, 2022 Another thing that may be helpful is to set your "Snap Grid" to 1000 mm in General Plan Defaults. If you can be more specific as to where and when you need this there may be other suggestions. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted March 19, 2022 Share Posted March 19, 2022 One metre increments are very big steps. Do you mean that you want to design in metric then using a metric template is a good place to start. This is available when you first launch CA. Click on the "New From Template" and you will be given a choice of which template to start your drawing from. Hope this helps 1 Link to comment Share on other sites More sharing options...
baduka Posted March 19, 2022 Share Posted March 19, 2022 Thank you very much Mr,I really appreciate it..I will surely try that..thanks a lot Link to comment Share on other sites More sharing options...
baduka Posted March 19, 2022 Share Posted March 19, 2022 4 hours ago, Chopsaw said: Another thing that may be helpful is to set your "Snap Grid" to 1000 mm in General Plan Defaults. If you can be more specific as to where and when you need this there may be other suggestions. Thanks a lot,will try that. Link to comment Share on other sites More sharing options...
Doug_N Posted March 19, 2022 Share Posted March 19, 2022 A snap grid of 1m is way too big. I can't imagine that being used for anything practical in designing houses. Link to comment Share on other sites More sharing options...
baduka Posted March 20, 2022 Share Posted March 20, 2022 Thanks Mr Doug...I'll try 100cm Link to comment Share on other sites More sharing options...
Gawdzira Posted March 20, 2022 Share Posted March 20, 2022 I am no Canadian but I have played one on T.V.. I don't think 100cm is going to solve this problem. Maybe try 1000 mm? Edit, I watched a Canadian on T.V.. I played a Rastafarian on T.V.. I get them confused. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted March 20, 2022 Share Posted March 20, 2022 1 hour ago, Gawdzira said: I am no Canadian but I have played one on T.V.. I don't think 100cm is going to solve this problem. Maybe try 1000 mm? Edit, I watched a Canadian on T.V.. I played a Rastafarian on T.V.. I get them confused. 1000 mm grid snaps would make your cursor jump 39.37 inches at a time. How would this be useful? It takes more than playing a Canadian to be a Canadian. You have to have maple syrup for blood. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 20, 2022 Share Posted March 20, 2022 1 minute ago, Doug_N said: How would this be useful? There is still no reference as to what this is being used for. For all we know they may be laying out a subdivision on a 1000 hectare development. Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 20, 2022 Share Posted March 20, 2022 1 hour ago, Gawdzira said: 100cm is going to solve this problem. Maybe try 1000 mm? 100cm IS 1000mm Link to comment Share on other sites More sharing options...
Chopsaw Posted March 20, 2022 Share Posted March 20, 2022 3 minutes ago, jasonn1234 said: 100cm IS 1000mm I guess you don't know Alan because technically it is not. All of his comments made more sense when he was using his previous avatar. Link to comment Share on other sites More sharing options...
Doug_N Posted March 20, 2022 Share Posted March 20, 2022 38 minutes ago, Chopsaw said: There is still no reference as to what this is being used for. For all we know they may be laying out a subdivision on a 1000 hectare development. And property boundaries would all be in even metre increments? It would be useful to know the need though. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 20, 2022 Share Posted March 20, 2022 6 minutes ago, Doug_N said: And property boundaries would all be in even metre increments? Well definitely not on any old survey done in Canada but quite possibly on a brand new layout in an area that uses Metric. Link to comment Share on other sites More sharing options...
baduka Posted March 21, 2022 Share Posted March 21, 2022 Thank you very much family!...Chief talk is really the best..now I managed to get what I wanted..I love you all guys..well I'm Baduka From South Africa Link to comment Share on other sites More sharing options...
stephenbc Posted March 21, 2022 Share Posted March 21, 2022 On 3/19/2022 at 9:17 PM, Doug_N said: You have to have maple syrup for blood. That means I'm a vampire.... Link to comment Share on other sites More sharing options...
baduka Posted March 23, 2022 Share Posted March 23, 2022 How do I apply those lines a the top level of the house Fam?...please help Link to comment Share on other sites More sharing options...
Chopsaw Posted March 23, 2022 Share Posted March 23, 2022 Have a look in the Roof Plane Specifications DBX Shadow Boards Panel The settings on the Shadow Boards panel allow you to specify one or more fascia shadow board profiles that follow the selected roof plane’s eaves. See Shadow Boards. The settings on this panel are like those on the Moldings panel found in many dialogs in the program. See Moldings Panel. Also it is best practice to start a new thread for a completely new subject. Link to comment Share on other sites More sharing options...
baduka Posted March 23, 2022 Share Posted March 23, 2022 Thanks Mr ChopSaw Link to comment Share on other sites More sharing options...
Ntsako Posted March 23, 2022 Author Share Posted March 23, 2022 eix,i failed to add shadow boards can ypu please show me steps to do it? Link to comment Share on other sites More sharing options...
rgardner Posted March 23, 2022 Share Posted March 23, 2022 6 hours ago, Ntsako said: eix,i failed to add shadow boards can ypu please show me steps to do it? Best to start your own thread or better yet a quick search for how to do something. googled: chief architect shadow board and got this video as top response here it is talking about frieze board which is the next nearly identical panel down from shadowboard in the roof dbx. https://www.chiefarchitect.com/videos/watch/708/frieze-molding.html Link to comment Share on other sites More sharing options...
baduka Posted March 23, 2022 Share Posted March 23, 2022 Thanks Mr rgardner Link to comment Share on other sites More sharing options...
