winterdd Posted August 25, 2021 Share Posted August 25, 2021 One thing I have have not yet mastered is manipulating wall breaks in elevation views. Aren't we supposed to be able to add a break, grab a grip and pull to the desired shape? It has never worked for me. Also, Can you add a break on stairs in plan view and pull grips? The pic below shows what I am trying to do. Bring down the wall to an angle leaving some exposed treads and then extend the tread widths to be flush over the angled wall. I normally just add a wall flush under the stairs and chief angles it for me. I don't want to do that on this home though. Link to comment Share on other sites More sharing options...
rgardner Posted August 25, 2021 Share Posted August 25, 2021 Pony Wall with solid below and railing above set to follow stairs for first part. Regular wall for last part with the break in the stairs lengthening those stairs over the wall. Link to comment Share on other sites More sharing options...
glennw Posted August 25, 2021 Share Posted August 25, 2021 Rob, With regards to the wall breaks. They only work on the tops of the wall, not sides or bottom. So you need to manipulate the location of the break and edit the top of the wall to get the shape you want. It is a bit tricky until you understand how it works. With this wall, you can see where I have placed breaks in the 2 top sections of the wall - one horizontal and one sloping. Link to comment Share on other sites More sharing options...
winterdd Posted August 26, 2021 Author Share Posted August 26, 2021 Thanks guys, adding a complete break in the stairs worked, which broke it into two stairs basically. I mean if it works it works I guess. lol. Now onto the wall breaks. I will be glad to figure that out since dormer walls can sometimes be a pain in the same sense. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 26, 2021 Share Posted August 26, 2021 Link to comment Share on other sites More sharing options...
winterdd Posted August 26, 2021 Author Share Posted August 26, 2021 I was just thinking. If I widened the treads I simply extend the wall to the bottom tread and essentially answered my own question if you look back at my first post. "Let chief angle the wall". duh! Thanks for the help guys. Of course now the damn wall stud is exposed lol. whatever!!! Link to comment Share on other sites More sharing options...
winterdd Posted August 26, 2021 Author Share Posted August 26, 2021 On 8/26/2021 at 12:08 AM, Chopsaw said: Expand I see he had the same issue with his wall end. Link to comment Share on other sites More sharing options...
mtldesigns Posted August 26, 2021 Share Posted August 26, 2021 On 8/26/2021 at 12:09 AM, ChiefUserBigRob said: Of course now the damn wall stud is exposed lol. whatever!!! Expand This happens all the time in this situation. Always have to add a solid to cover and paint... One of the many issues with pony/railing walls. Link to comment Share on other sites More sharing options...
robdyck Posted August 26, 2021 Share Posted August 26, 2021 On 8/26/2021 at 12:17 AM, ChiefUserBigRob said: I see he had the same issue with his wall end. Expand An invisible wall, 1/2" thick, using your drywall material is very helpful for these situations. Place it at the same location as the break in the stairs, set to through wall at start and end. Break the 2x4 wall, and reverse the layers of one side. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 26, 2021 Share Posted August 26, 2021 if you move the full height wall edge around a little it will fill in the drywall, but you have to get it just right Link to comment Share on other sites More sharing options...
winterdd Posted August 26, 2021 Author Share Posted August 26, 2021 thanks again guys for all the input. Link to comment Share on other sites More sharing options...
