Michael_Gia Posted December 26, 2020 Share Posted December 26, 2020 I’ve always just assumed it was a bug but the measuring tape tool always wants to snap to things even when “object snaps” is turned off. Is there any way to have the measuring tape tool NOT snap? I usually end up drawing a cad line and checking its length. Cadlines don’t snap when snap is turned off. (Which is the way it should work) Link to comment Share on other sites More sharing options...
Chopsaw Posted December 26, 2020 Share Posted December 26, 2020 There is a big problem when the Tape Measure tool is used with Grid Snaps turned on since the tool will then snap to the grid rather than what you are trying to measure. Not sure how snapping to objects would present a problem though? It has to snap to something to give you a measurement. Maybe it is snapping to the wrong thing ?? Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 26, 2020 Author Share Posted December 26, 2020 53 minutes ago, Chopsaw said: It has to snap to something to give you a measurement. Maybe it is snapping to the wrong thing ?? I actually would like it not to snap to anything. It happens quite often that I measure the distance between two objects and get a wrong measurement. Link to comment Share on other sites More sharing options...
MarkMc Posted December 26, 2020 Share Posted December 26, 2020 15 minutes ago, Michael_Gia said: I actually would like it not to snap to anything. Hold the Command key (Ctrl on windows) Link to comment Share on other sites More sharing options...
Kbird1 Posted December 26, 2020 Share Posted December 26, 2020 36 minutes ago, MarkMc said: Hold the Command key (Ctrl on windows) Ctrl on windows ....works for me...... M. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 26, 2020 Share Posted December 26, 2020 1 hour ago, Michael_Gia said: I actually would like it not to snap to anything. Like the other guys said, you can use the Control or Command key to override all snaps but you could also probably just turn off Grid Snaps along with the Object Snaps that you're already turning off. With both Object Snaps and Grid Snaps turned off my Tape Measure tool won't snap to anything. Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 26, 2020 Author Share Posted December 26, 2020 1 hour ago, MarkMc said: Hold the Command key (Ctrl on windows) It still wants to snap to stuff even when holding the command button. maybe it’s a Mac bug? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 26, 2020 Share Posted December 26, 2020 17 minutes ago, Michael_Gia said: It still wants to snap to stuff even when holding the command button. maybe it’s a Mac bug? Might be Option not Command on some MACs..... ( keyboard differences???) M. Link to comment Share on other sites More sharing options...
rgardner Posted December 26, 2020 Share Posted December 26, 2020 23 minutes ago, Kbird1 said: Might be Option not Command on some MACs..... ( keyboard differences???) M. Unless you have changed your shortcut it should be Cmd and works fine for me as well. Whatever the key is to override snaps/bumping when you are moving something should be the same key. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 26, 2020 Share Posted December 26, 2020 2 minutes ago, rgardner said: Unless you have changed your shortcut it should be Cmd and works fine for me as well. Whatever the key is to override snaps/bumping when you are moving something should be the same key. You are probably right ...never owned a MAC..... I maybe thinking of the MAC ALT Key issue ( use Option) , some Clients have had..... M. Link to comment Share on other sites More sharing options...
glennw Posted December 26, 2020 Share Posted December 26, 2020 I can confirm that even with all snaps turned off, Command does not stop the tape measure from locating objects. It appears as though it is not snapping because you don't see the snap indicators. But have a close look and you will see the dimension extension line appear when it is locating an object. When the tape measure is not locating an object, the end of the dimension is a cross, then, when it locates an object, the end of the dimension displays as an extension line identified as extension 2. Even so, there still seem to be some random locations that the tape measure wants to locate. 1 Link to comment Share on other sites More sharing options...
