ACADuser 143 Posted November 25, 2020 When a column or other solid penetrates a slab there are no lines at the base when you send to layout. How do most of you deal with this? I was thinking holes in the sidewalk might be the cleanest. Share this post Link to post Share on other sites
Dermot 573 Posted November 25, 2020 "I was thinking holes in the sidewalk might be the cleanest." That should work but it sounds like a lot of manual work. Why don't you just raise the bottom so that it sits on top of the slab instead of going through it? And just out of curiosity, why do you have arrows on your roofs? Share this post Link to post Share on other sites
joey_martin 364 Posted November 25, 2020 20 minutes ago, Dermot said: why do you have arrows on your roofs? Drainage planes and direction. Share this post Link to post Share on other sites
Dermot 573 Posted November 25, 2020 Is this something that is becoming commonly used in 3D views? Share this post Link to post Share on other sites
Chopsaw 635 Posted November 25, 2020 2 hours ago, ACADuser said: When a column or other solid penetrates a slab there are no lines at the base when you send to layout. How do most of you deal with this? You can create a division line by making a copy of your material. It does not have to be different in any way other than the name. Share this post Link to post Share on other sites
Dermot 573 Posted November 25, 2020 "You can create a division line by making a copy of your material. It does not have to be different in any way other than the name" I believe this trick only helps when you have two parallel surfaces that are merged into one. For example, if you have two slabs bumped up tight against each other they will look like one unless you make one slab a different material. In Alan's case, it looks like he has two surfaces inside each other. The program is not currently smart enough to detect this situation and add the extra lines for you. The simplest solution is to make sure your surfaces are not conflicting with each other. Creating a hole in the slab for the columns should work (and might more accurately reflect how it will be built IRL). I just think pulling the columns up is easier. Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted November 25, 2020 31 minutes ago, Chopsaw said: You can create a division line by making a copy of your material. It does not have to be different in any way other than the name. As Dermot pointed out, this really only helps for coplanar faces, not so much for intersecting faces. Share this post Link to post Share on other sites
ACADuser 143 Posted November 25, 2020 2 hours ago, Dermot said: "I was thinking holes in the sidewalk might be the cleanest." That should work but it sounds like a lot of manual work. Why don't you just raise the bottom so that it sits on top of the slab instead of going through it? And just out of curiosity, why do you have arrows on your roofs? I was preparing a view to send to the structural people as they can not seem to understand the desired slope of the roof. So I made it obvious with the arrows. They can be hard headed at times. I took the columns down to the foundation pads as they don't rest on the sidewalk. Can you snap to the poly solid surface? I could copy in place & drag the bottom to snap to the surface. Share this post Link to post Share on other sites
Chopsaw 635 Posted November 25, 2020 1 minute ago, ACADuser said: I was preparing a view to send to the structural people as they can not seem to understand the desired slope of the roof. So I made it obvious with the arrows. They can be hard headed at times. You would think they might be able to figure it out by the eavestrough placement but I guess "structural people" are sadly not as observant as they should be sometimes. Likely they are more familiar with notes from other less illustrative software programs. Share this post Link to post Share on other sites
Chrisb222 221 Posted November 25, 2020 2 hours ago, ACADuser said: Can you snap to the poly solid surface? I would raise the column by opening the dialog box for the slab, referencing the slab top location, then entering that for the column bottom. Share this post Link to post Share on other sites
rgardner 145 Posted November 25, 2020 In the interest of keeping your model accurate and thus not having to do custom cad details to make it look right I would consider changing to a slightly skewed color of the same item so that say your vertical concrete items are concrete 2 and your flat & horizontal is concrete 1. Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted November 25, 2020 1 minute ago, rgardner said: In the interest of keeping your model accurate To be fair, there is no scenario where an accurate model has columns and slab occupying the same space. Either the posts sit on the slab or the slab is poured around the posts. Share this post Link to post Share on other sites
rgardner 145 Posted November 25, 2020 2 minutes ago, Alaskan_Son said: To be fair, there is no scenario where an accurate model has columns and slab occupying the same space. Either the posts sit on the slab or the slab is poured around the posts. You do have a fair point there, to be 100% accurate he would need to cut holes at each post in the slab. I guess I was referring to the point where the advice was to pull the column/post up to sit on top of the slab to show the vector line for the transition where as he was embedding that post/column down to the footer as he mentioned. Share this post Link to post Share on other sites
solver 1569 Posted November 26, 2020 Watch on YouTube: http://youtu.be/g8i-x4Xea0A?hd=1 Share this post Link to post Share on other sites
ACADuser 143 Posted November 26, 2020 Eric, Nice solution, very accurate. Thanks Share this post Link to post Share on other sites
