mgianzero
Can I easily copy wall caps to other existing walls?
Just upgraded from HDP to Chief Architect.  I love the wall caps feature.  So I applied a new wall cap to one of my retaining walls.  Is there an easy way to copy this feature to the other existing walls, or must I do it all manually?
Here's a sample plan that I want to copy the cap from one wall over to the neighboring walls.  My walls are retaining walls.  Is there an easy way to do this or must I change each wall individually?  I thought the object eyedropper would work but it doesn't.
Marc
Multi select and do them all at once.
Next time, get one section of wall as you want, add it to the library, then choose it when drawing additional sections.
No way to copy to another wall.
Marc
Easy to do. Familiarize yourself with restrictive selections with an enabled Tool. Familiarize yourself with the Select Marquee Similar Tool in the Edit Toolbar that is enabled from an Active Selection. Also familiarize yourself with the Marquee Selection Modes in your Preferences under the Edit Panel.
Simply select all walls that you want the cap applied to and edit in the Wall Cap Panel of the wall dbx.
I'm still learning about the Marquee Selection Mode.  Read directions, still struggling to see how exactly it works in this scenario.  Perhaps you can show me how to do this in my plan?
Terrain wall caps V2.zip
20 minutes ago, solver said:
Very basic ...
Watch on YouTube: http://youtu.be/K1mpfdxhNWQ?hd=1
Hey, now that's really slick!  Never knew about that.  I haven't read the CA manual cover to cover, but learning as I go.
By the way, how do you search for such a video?  I noticed it's titled "Recording #610" so what does that mean?  Are you searching under "Videos" from CA main website, because doesn't show up for me.
Again, I'm learning how to navigate and use all the support tools (both online and written docs) for CA.  So I apologize if I'm slow here.
I just made the video, and it, like many others are hidden from direct YouTube searches since it's specific to your question. There is a link to my YouTube channel in my signature.
I imagine there are Chief videos on their website.
Here is some info on searching. I believe it shows a bit about searching the Chief website.
Wow! You've got a lot of videos on there. Many don't have descriptive titles to them, so it's hard to search.  But I'll see what I can find that I can learn from.
What software are you recording with?
https://screencast-o-matic.com
I use the Deluxe version.
There are multiple free options and probably even something already installed on your system. Would be good if you updated your signature to at least show Windows or Mac, video specs etc.
Look up Chief Skills on YouTube -- Steve has more generic videos that are less specific to individual questions, and Chief also has many good videos on their YouTube channel.
I see.  Okay  ...  didn't know if there was some embedded feature in CA for recording itself since I know it records walkthroughs.
I discovered that Catalina comes with it's embedded version of Quicktime which I've started to use.
Thanks for all the resources regarding researching / searching for answers to my CA questions.
I also updated my signature as you suggested.
Marc
By the way, is there an easy way to round the corners (like a fillet) for wall caps?
I'm trying to make some nice detail to my swimming pool - have a raised spa that I drew walls around with caps.
Again, didn't see much in the literature about this.
This was done using countertop feature.  Kinda cumbersome doing it that way.  Wanted to just use terrain walls with caps if I could.
3 minutes ago, mgianzero said:
round the corners
You can use any molding profile for a cap. The problem is the end of the wall as there are no controls that control the cap in that location.
How about creating walls with rounded corners?  Can we do that?
Radius walls, yes.
Square inside corner with round outside corner, No.
It is possible to do rounded corners like this (I can't get zero inside radius, is, square inside)  but they play havoc with some of the auto functions like auto roofs and auto foundations and chief doesn't handle them well generally.
Until Chief comes up with radius corners without using a curved wall, it's just too much trouble for me to mess with.
On 9/25/2020 at 10:31 AM, robdyck said:
Radius walls, yes.
Wait, perhaps I'm misunderstood here, but I DO want curved walls both inside and out for my raised hot tub.  I tried doing it three different ways with a certain degree of success but nothing easy and really working like I want.  See my attached pic at my attempts, along with the actual pic of the hot tub.
The easiest is to use a negative terrain rectangular feature for the hole and the I created 3D molding polylines, but there are no walls and this needs to be raised about 15 inches.
Then, I got as close as possible to what I wanted using terrain curved and straight walls.  I think this is the way to go if I can get it work properly.  I really struggle with the editing features of terrain walls.  It's so difficult to make this thing symmetrical since terrain walls always like to dynamically attached themselves to each other and so, essentially ignores my wall changes when they are close to each other.  That other model with the curved walls is almost there but not exactly the size, shape, symmetry I want.
The last model is drawing it all using straight walls, which again is almost as hard as doing curved walls.  But then I get an octagon and not truly curved walls.
Am I trying something that just isn't that easy with CA?
A pool like the last photo you attached is quite simple. Using walls with a wall cap and defining the room they make, or by using a molding polyline. One tip would be to first create the exact shape you'd like using a few polylines for referencing and to snap your walls to. Don't use retaining walls, just a regular wall that you've defined as your pool wall type.
Do not use terrain walls - there is no need to - they will only complicate the process.
Just use plain walls.
My best tip if you want to use curved and straight walls is to use the one with the 45deg corners.
Use the Change Line/Arc on the 45deg walls.
Then use the Make Arc Tangent tool where you can specify a radius during the process for the curved wall.
No need for guide lines or worrying about locating arc centres or trying to get arcs to locate.
Well, I figured out this technique on my own.  But I would have certainly saved time and frustration if I had read your post beforehand.  Thanks for the advice!
Also a very good suggestion.  I simply used the "chamfered lines" on my polyline outline of my spa and then converted each diagonal wall to a curve as you described.
Then I made my hole by lowering the flooring and adding a rounded molding on the bottom.
Now I have a rounded hot tub, with rounded corners on inside and out with a matching rounded cap.
Here's my result:
Now you can fill it with water by using the Floor Finish setting, applying a water material and making it the height of the water.
    28427
    DwightDJ
    DwightDJ
