Evolution Posted August 28, 2019 Share Posted August 28, 2019 Since upgrading to X11 months ago, every bonus catalogue I have down loaded defaults to X10 and I haven't found the key to changing that default apparently? I open X11, go to libraries, additional content on line, select the files, then select the X11 version but no matter my selection after the down load completes the message shows opening in X10. Where is the default setting to change these down loads to save in X11? If I select save as, go to program files select X11 the error messages states I don't have permission to save in this location. I definitely am tech-dumb, if someone would share the formula to fix this? I just attempted to down load the Bonus Materials Fabric / Wallpaper and selected open the file and it opens in X10 even though I selected X11. Do I need to delete X10 from my machine? Link to comment Share on other sites More sharing options...
Greg_NY61 Posted August 28, 2019 Share Posted August 28, 2019 In Preferences >General > Folders... if this is what you looking for. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted August 28, 2019 Share Posted August 28, 2019 You most likely need to tell windows to use X11 and not X10 when opening this file type. Go to Windows settings, select "Apps", select "Default Apps", near the bottom select " Choose Default Apps by File Type". On the right side move down until you see the ".calib & .calibz" file extension. Change the associated app to X11. 1 Link to comment Share on other sites More sharing options...
tommy1 Posted August 28, 2019 Share Posted August 28, 2019 Bob, this is what I do and never have a problem. Go to catalog downloads from Chief's website. Down load the library and save it to my downloads folder on my laptop. Open X11 and go to Library>import library .calibz> look for the library I downloaded >select it>hit okay. Should bring it inti your X11 library. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 28, 2019 Share Posted August 28, 2019 X10 has a bad habit of taking back the File associations from X11 if you open a plan in X10 again , particularly if you use Right Click Menu Item.... Open With... However X11 now has a Button in Preferences>File Management>File Association to take it back for you....... ***note in pic it is grayed out as my Associations as active for X11 currently............ The other advice is to Use the Library>Import Library Menu in X11 to Import the Bonus Library , not the double click method from your downloads folder..... Link to comment Share on other sites More sharing options...
Evolution Posted August 29, 2019 Author Share Posted August 29, 2019 23 hours ago, TheKitchenAbode said: You most likely need to tell windows to use X11 and not X10 when opening this file type. Go to Windows settings, select "Apps", select "Default Apps", near the bottom select " Choose Default Apps by File Type". On the right side move down until you see the ".calib & .calibz" file extension. Change the associated app to X11. Thanks Graham! That did it. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted August 29, 2019 Share Posted August 29, 2019 14 minutes ago, Evolution said: Thanks Graham! That did it. You are welcome. If it happens again it would be worth checking out the suggestion provided by Mick(Kbird1), I had no idea that X11 had this file association reset option in the Preferences DBX, would accomplish the same thing but with fewer clicks, Link to comment Share on other sites More sharing options...
Kbird1 Posted August 29, 2019 Share Posted August 29, 2019 58 minutes ago, solver said: You can also drag a library into an open Chief window. I haven't seen it happen in X11 but I no longer do it that way as in previous versions I found the library would import without the Textures sometimes , which never happened if you use the Library Menu>Import Library. M. Link to comment Share on other sites More sharing options...
Evolution Posted September 11, 2019 Author Share Posted September 11, 2019 I thought it was resolved but I need to download DWG file, and it keeps saving it as X10 file. I did go to Windows, apps, default apps to see if I could set the DWG file association with X11 but to my surprise X11 is not available as a default app for this file type? Any body know why? Link to comment Share on other sites More sharing options...
BrownTiger Posted September 12, 2019 Share Posted September 12, 2019 Oh no .... Windows issues again LOL. Let me try one last time. Hilight you DWG file with the mouse. Holding shift key > Right click and select "Open With" > See if X11 showing on that list If available select your CA X11 check the checkbox Always use this App to open DWG files... Done If not select "Choose another app" ... Scroll to the bottom to "More Apps" ... "Look for another Apps on this PC" Navigate C:\Program Files\Chief Architect\Chief Architect Premier X11 (64 bit)\Chief Architect Premier X11.exe Now check the checkbox Always use this App to open DWG files... Even if you didn't, after opening file in X11 you will get Chief architect X11 added to the list of available applications. BT Link to comment Share on other sites More sharing options...
glennw Posted September 12, 2019 Share Posted September 12, 2019 I am not sure about windows, but on a mac, I don't think you can associate a .dwg file with Chief because the .dwg file has to be imported into Chief, not opened in Chief. Link to comment Share on other sites More sharing options...
BrownTiger Posted September 12, 2019 Share Posted September 12, 2019 Odd, if you do this in Windows you will get Import Drawing Assistant 020500_ramboard-detail-drawings-instructions_rev1-051517.dwg Link to comment Share on other sites More sharing options...
tommy1 Posted September 12, 2019 Share Posted September 12, 2019 I agree with Glenn. Why not just download the DWG file and save it, then just import it into Chief. That's what I do. No problems. Link to comment Share on other sites More sharing options...
