HumbleChief Posted March 18, 2019 Share Posted March 18, 2019 The dashed line looks like a demo wall in my wall type key and would like to customize it? Any way to do so? If I had my druthers I'd just like to see an open space, like a doorway? Link to comment Share on other sites More sharing options...
kMoquin Posted March 18, 2019 Share Posted March 18, 2019 open door dialog box Options Tab Plan Display line select "Hide Top Edge" 3 Link to comment Share on other sites More sharing options...
HumbleChief Posted March 18, 2019 Author Share Posted March 18, 2019 3 minutes ago, kMoquin said: open door dialog box Options Tab Plan Display line select "Hide Top Edge" WHA!!! Had no idea, thank you thank you thank you. Link to comment Share on other sites More sharing options...
raltd9245 Posted March 18, 2019 Share Posted March 18, 2019 Did not work for me!!!!!! Link to comment Share on other sites More sharing options...
Doug_N Posted March 18, 2019 Share Posted March 18, 2019 The command to show or to hide the top edge may be a bit misleading. It only affects the edge on the swing side of the door. Here are some examples. Link to comment Share on other sites More sharing options...
kMoquin Posted March 18, 2019 Share Posted March 18, 2019 24 minutes ago, Doug_N said: The command to show or to hide the top edge may be a bit misleading. It only affects the edge on the swing side of the door. Here are some examples. Doug, Your example is an exterior door. The line you are seeing is not overhead, it is below. Link to comment Share on other sites More sharing options...
Doug_N Posted March 18, 2019 Share Posted March 18, 2019 So it is misleading! Link to comment Share on other sites More sharing options...
kMoquin Posted March 18, 2019 Share Posted March 18, 2019 It's not misleading, it controls the representation of the top edge, the line you see is at the bottom. If you try again with an interior door it will be clear to you. Link to comment Share on other sites More sharing options...
glennw Posted March 18, 2019 Share Posted March 18, 2019 Try Hide Top Edge in the door dbx AND turning off the Opening Header Lines layer. 1 Link to comment Share on other sites More sharing options...
rwaldrondesigns Posted July 18, 2020 Share Posted July 18, 2020 (edited) I have been trying to do this exact thing. I have turned off the Opening Header lines layer and have hidden the top edge and still see this. Uh yeah... ignore me. I had lines drawn behind it Edited July 18, 2020 by rwaldrondesigns Shutting myself up... 1 Link to comment Share on other sites More sharing options...
caconstruction Posted June 13, 2023 Share Posted June 13, 2023 have a way to change the opening indicator line in plan? want to make a dashed line and lighter than the door. Link to comment Share on other sites More sharing options...
DBCooper Posted June 14, 2023 Share Posted June 14, 2023 The short answer is no. If you change the line style and color for the "door" layer it will change the swing indicator but it will also change the door and the jamb lines. You might want to submit a feature request for that. Link to comment Share on other sites More sharing options...
VKB_Homes Posted January 17, 2025 Share Posted January 17, 2025 I am learning this software as I have time, so excuse my novice questions. -How were you able to modify this door to be completely dashed? - I am trained in Autocad so trying to find any of the linetypes and such is lost on me as nothing works the same Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 17, 2025 Share Posted January 17, 2025 6 hours ago, VKB_Homes said: -How were you able to modify this door to be completely dashed? Controlled by the Line Style on the Layer the door is on. Doors are placed on the Doors layer by the software, but the door(s) can be moved to a different layer if you desire doors to have different line styles. Link to comment Share on other sites More sharing options...
