Wall Niches
kendra11
Go to solution Solved by Dennis_Gavin,
Why not use a door, set door thickness and material? No need to add a p-line solid
Yes,  I think I did a  vid on this.  It might be the best solution to date.  The key here is to use your own door,  that has been made of two psolids,  one on the front and one on the back, by doing this,  you can have different materials on the front and the back.  (just reviewed this and by some miracle I guess the default door had two sides to it.)
This solution works well in render,but in vector view,  you get a few extra lines.
But again,  probably the best simplest solution to date.
Casings will show up with the pass thru as well, not sure how you get around that one.
Don't use casings.
Use a custom Symbol with whatever "Surround Features" and insert it into the opening.  Ooops!  We're right back to using a Custom Window Symbol and a "Back Fill Symbol" to match.  :D LOL
