ThomasM Posted November 15, 2018 Share Posted November 15, 2018 Hello All, by mistake I built the upper floor first and finally found out how to make that floor 2 but now when I build floor 1 I am having a hard time lining it up with the floor above. any pointers would be great. both floors are different shapes and size. thank you Tom Link to comment Share on other sites More sharing options...
javatom Posted November 15, 2018 Share Posted November 15, 2018 There is a function to "align with below" for the walls. That would be a start. Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 7 minutes ago, javatom said: There is a function to "align with below" for the walls. That would be a start. what I did was build stairs going up and just build around them lol. at this point I think I will continue but will also look into what you said. thank you. Tom Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 5 minutes ago, solver said: What is the problem with alignment? i dont know the tech terms but everything was off center. I think I found an ok way to work around my mistake. i am sure there is a better way.. maybe create the lower floor in a new plan and join the two plans. thank you Link to comment Share on other sites More sharing options...
CharlesVolz Posted November 15, 2018 Share Posted November 15, 2018 If everything is sized correctly and the entire floor is offset from the floor above/below, then you might want to use "Edit Area" to align them. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2018 Share Posted November 15, 2018 2 hours ago, ThomasM said: i dont know the tech terms but everything was off center. I think I found an ok way to work around my mistake. i am sure there is a better way.. maybe create the lower floor in a new plan and join the two plans. thank you One way is to find a common point between the Floors like a Corner, turn on the Reference Layer (F9) ,select everything on one floor and use the Point to Point move tool ( ignore error messages) and use the Corner to move everything selected..... some Clean Up maybe required afterwards. Try in a Save As Version of your Plan to Practice 1st..... M Link to comment Share on other sites More sharing options...
AvoyeDesign Posted November 15, 2018 Share Posted November 15, 2018 If you ever make this mistake again, my suggestion would be to start the 1st floor by copying the exterior walls from the 2nd floor, as well as any important walls such as those around stairs. This will give you all your walls perfectly aligned, and you can change their properties after. Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 15, 2018 Share Posted November 15, 2018 Paste hold position, an invaluable tool Link to comment Share on other sites More sharing options...
lbuttery Posted November 15, 2018 Share Posted November 15, 2018 Note: align with walls feature only works if the walls are off by a little Lew Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 5 hours ago, solver said: What is the problem with alignment? the floor above didnt align with the floor below... terribly off center. I do advertising for Manhattan real estate and love working with and trying to learn chief architect whenever I get the chance. my layouts are all done by eye to try and give my customers the best idea of the layout and what they can do to the property. thank you Tom Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 i read all the comments and thank you all very much. im going to get back into it and hope I finish it tonight. thank you again. Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 when I opened the plan the lower floor was some how lost lol.. so I will be doing as some of you have said. Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 in searching for help with the stairwell the paste and hold position that I found just came in handy. Link to comment Share on other sites More sharing options...
ThomasM Posted November 15, 2018 Author Share Posted November 15, 2018 got the railing around the stairs :)... Link to comment Share on other sites More sharing options...
ACADuser Posted November 16, 2018 Share Posted November 16, 2018 You probably figured out that there is a command to swap floors. Also, Walls of different types are aligned by Chief via the align with below or align with above based on the outer surface of the "Main Layer": of the wall. NOT the Outer surface of the Exterior surface. This is regardless of the outer covering or the wall thickness. So if you have stucco as an outer layer it must be the same thickness for both wall types. Link to comment Share on other sites More sharing options...
