HumbleChief Posted August 11, 2014 Share Posted August 11, 2014 I've invested a lot of time learning to deal with Anno/Layout sets and would be loath to re-learn a new method, however after saying that each time the Devs have changed a crucial bit of programming I've found it is usually for the better. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 11, 2014 Share Posted August 11, 2014 Joe, I personally appreciate the effort you put into posts such as these but it may assume that others use Layer/Anno Sets in a similar way. I use them in a way that I'm sure is unique to me and my work flow so that even makes it hard to relate to your suggestions. Not that the function can't be improved, and maybe in exactly the way you suggest, but maybe there are so many different ways to use them that specific suggestions that fit s specific work flow may not be the most useful. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 11, 2014 Author Share Posted August 11, 2014 Larry, If you could give a simple explanation of how you use them - I could be more specific in addressing your concerns. Without knowing how your use is unique, I can't agree or disagree with you. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 for the non-power users of Anno-sets or those (like me) who haven't used them yet the SSA videos #1305 and #1306 are informative as to how CA thought they would be used my understanding is that CA sees anno-sets as "grouped defaults" which is quicker than going to the defaults dbx and changing any of the 6 defaults that can be controlled by anno-sets concerning the "king" question it seems CA intended for both options 1. choose a layerset, then choose an anno-set that has "use active layerset" and layersets are "king" just switch among the various layersets and the anno-set remains the same with the same "grouped defaults" useful when using the same scale for various layersets 2. choose an anno-set such as electrical or framing or site plan with a specific layerset specified with the "grouped defaults" and anno-set is "king" switch to another anno-set like this and the layerset is changed this is what CA implemented in X3 since then the power-users like Joe and Scott have devised vast new combinations of usage I think my needs would lean towards CA's original intent for anno-sets more power to those who have "greater" needs Lew 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 11, 2014 Share Posted August 11, 2014 Larry, If you could give a simple explanation of how you use them - I could be more specific in addressing your concerns. Without knowing how your use is unique, I can't agree or disagree with you. I have Anno Sets set up for each 'phase' or discipline of construction. As Built Anno Set, Proposed Anno Set ( I do a lot of remodels) Foundation Set, Framing Ceiling, Framing Floor, Framing Roof, Details Set, Plot Plan, Electrical Set, Steel Columns etc. as needed. I have about 20 Anno Sets and use 6 or 7 on every plan. I just switch between Anno Sets for each discipline, which of course changes to the Layer set that is associated with the Anno Set. It's become automatic and haven't really found a need to change much. The only thing I'd like is to have Anno Sets set per floor because when I change to the foundation floor I'd like that to be Associated with my Foundation Anno Set then back to the first floor have that Associated with another Anno Set. That is probably a perfect example of the unique way I work as when I suggested that Anno Set be associated with floors not many agreed it would work for them. Again, I haven't found a real need to change the way things work now so I may not be the best candidate to continue the discussion. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 which of course changes to the Layer set that is associated with the Anno Set Larry: could some of those anno-sets be specified as "use active layerset" ? then you could change the layerset as needed and be using the same anno-set' "grouped defaults" just asking - trying to get a handle on the "simple way' to use anno-sets have Anno Sets set per floor If you have a layerset per floor and some of the anno-sets have "use active layeset" then maybe that would work for you ? Lew Link to comment Share on other sites More sharing options...
Doug_Park Posted August 11, 2014 Share Posted August 11, 2014 The original intent was to have a quick way of switching the setup of defaults for certain annoation operations (disiplines as Joe calls them). That is all. Switching from drawing a floor plan to laying out electrical is one such example that could in some cases have take dozens of clicks to input up the correct settings. So not only was it tedious, it was easy to make a mistake. I regret adding the ability to change the layer set. That option is now theoretically not such a big deal now as the annotaiton set and layer set for a view are rememberd on a per view basis. Unfortunately, it seems like annoation sets are now being viewed as a solution to problems that they were never intended to handle. Link to comment Share on other sites More sharing options...
ebdesign Posted August 11, 2014 Share Posted August 11, 2014 Lew, Jump into Anno Sets w/ both feet & get 'em wet. You're probably not gonna get your questions answered in any real detail until you make that effort. Even w/ all the debate & discussion, one thing is a given: Anno Sets are HUGE timesavers for those who need to create complete plan sets. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 Jim: I'm retired and don't do CD's anymore my friend/partner is still doing some projects mainly 3D elevations and roof fixes he doesn't use anno-sets either just trying to get a handle on them - in case the need arises I see all the "confusion" and decided to go back to CA's original intent which seems to be missing from all the discussion and debate on these posts I'm sure new users are reading these posts and deciding anno-sets are way too confusing and avoiding them like the plague If my understanding is correct they can be used in CA's "simple mode" without all the extra "hoopla" while "power users" may need more I suspect the average user can get along fine with the way CA intended them so I'm trying to understand what suggestions are improvements versus those that are complete "re-writes" of the original logic Lew Link to comment Share on other sites More sharing options...
KenL-sdd Posted August 11, 2014 Share Posted August 11, 2014 Scott, You are in fact missing something. The Annoset is responsible for the Text size because it uses a Defaults. IOW: For 1"=10' you have one set of Defaults that control the sizes of Text, Dimensions, etc. For 1"=20' you have another set of Defauts that control the sizes of Text, Dimensions, etc. For 1"=20' you have one set of Defaults that control the sizes of Text, Dimensions, etc. For 1"=60' you have another set of Defauts that control the sizes of Text, Dimensions, etc. For Architectural Plans I need 3 Annosets and 1 LayersetFor Structural Plans I need 3 Annosets and 1 Layerset For Electrical Plans I need 3 Annosets and 1 Layerset Annosets specify the Defaults that control the size of Annotations Layersets specify what's displayed - and anything that you don't want to adhere to Defaults. I use annosets all of the time. Learned from Scott, Use more like Joe. Annosets are KING. They work perfectly the way I use them now. Same as Joe I believe. Link to comment Share on other sites More sharing options...
HumbleChief Posted August 11, 2014 Share Posted August 11, 2014 which of course changes to the Layer set that is associated with the Anno Set Larry: could some of those anno-sets be specified as "use active layerset" ? then you could change the layerset as needed and be using the same anno-set' "grouped defaults" just asking - trying to get a handle on the "simple way' to use anno-sets have Anno Sets set per floor If you have a layerset per floor and some of the anno-sets have "use active layeset" then maybe that would work for you ? Lew Lew, I'll answer your question with a big MAYBE. I don't understand the use of active Layer Set 'feature' and may spend some time learning them but it's hard to change when habits get so ingrained. I watched the videos you linked to and they were quite interesting. Didn't really know what CA intended for Anno Sets. The way I use Anno Sets came about from the initial discussion when they were first introduced and I've honed my methods since then. The more I read the more I see that I may use them in ways they were not intended but ain't that grand? I haven't seen a way to deal with Anoo Set (Active Laters or Not) on a per floor basis. Chief simply doesn't allow for changing Layer/Anno Sets per floor. I'm not sure your exact status as far as working with CA but if you have aversion with Anno Sets and you want to learn them post a question or 2 and i'm you'll get a lot of help. Once understood they are essential IMO. Link to comment Share on other sites More sharing options...
KenL-sdd Posted August 11, 2014 Share Posted August 11, 2014 Annosets are the new powerhouse in Chief. You should use them the the MAX. I have taught others on how to use annosets. I will try to post a video in the next week on How I use them. Good Luck Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 11, 2014 Author Share Posted August 11, 2014 Active Layerset is very simply what happens when the Layerset specified for the Current Annoset has been changed by the user. IOW, it's not the Default Layerset for that Annoset. We have the ability to change things on the fly. Annosets have made it easier to get everything with one click (actually 2 clicks) but the implementation has complicated things in other ways. It can be simpler. Link to comment Share on other sites More sharing options...
ebdesign Posted August 11, 2014 Share Posted August 11, 2014 "Use Active Layer Set" is found in the Anno Sets dbx & is the default setting for most of the OOB anno sets that come w/ Chief. When "Use Active Layer Set" is selected for a particular anno set & then that anno set is activated, the layer set that is current at that time will remain the same. IOW, layer sets & anno sets can be selected from their respective dbx's w no effect on the other. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 11, 2014 Author Share Posted August 11, 2014 Unfortunately, it seems like annoation sets are now being viewed as a solution to problems that they were never intended to handle. Doug, If you make it work a certain way then that's the way it's going to be used - even if you didn't intend it to be used that way. Currently, the quickest way to get the desired Layerset, Defaults & CAD Layer is to select an Annoset that has those settings. The unfortunate part is that it's too much control in the wrong spot. Consequently it results in a need for a Layerset for almost every Annoset. It also means that we have to have an Annoset for each scale. That's a lot of complexity and not really that easy to set up. Added to that is the fact that we have to have Defaults for the various annotation objects for each scale and Text Styles for each scale and you wind up with a very large matrix of possibilities. Naturally that leads to confusion and frustration. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 Larry: select the 1/4" anno-set and have "use active layerset" specified then change the layerset on the toolbar as needed and each chosen layerset will use the 1/4" anno-set a basic/standard user probably won't have need for more than the anno-sets provided by CA OOB the "power-users" need what they need Lew Link to comment Share on other sites More sharing options...
rlackore Posted August 11, 2014 Share Posted August 11, 2014 Larry: select the 1/4" anno-set and have "use active layerset" specified then change the layerset on the toolbar as needed and each chosen layerset will use the 1/4" anno-set But with this method, aren't you're placing ALL your annotations on the same layers (as defined by the annoset) for EVERY 1/4" drawing. What do you do when you're producing 1/4" floor plans, 1/4" reflected ceiling plans, 1/4" framing plans, etc? I don't understand. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 Robert: if those various 1/4 views/details use different "grouped defaults" then you would need an anno-set for each one that is different for views/details that use the same "grouped defaults" they can share the same anno-set watch CA's video's #1305 and #1306 some users may need more - others can use what CA provides OOB it's not a one-size fits all What works for Joe and Scott and other "power-users" may not be needed for some (like me) I can see a newbie suffering "brain-melt" trying to understand/implement "power-user" anno-sets when all they need is a basic set Lew Link to comment Share on other sites More sharing options...
HumbleChief Posted August 11, 2014 Share Posted August 11, 2014 Larry: select the 1/4" anno-set and have "use active layerset" specified then change the layerset on the toolbar as needed and each chosen layerset will use the 1/4" anno-set a basic/standard user probably won't have need for more than the anno-sets provided by CA OOB the "power-users" need what they need Lew Lew, Thanks for the advice but I probably didn't make myself clear. I am perfectly fine with the way Anno Sets are set up and have been using them productively since X3. NEVER used 1/4" Anno set of any kind as I was never trained classically as an architect so I have no need for 1/4" anything. I've named and cutomized around 20 different Anno Sets that suit my work flow just fine. I'm not looking for anything to change or any tips as my work flow suits me just fine. Not saying there's nothing for me to learn just nothing I want to change right now. I'll let Joe deal with the changes he thinks are needed. Link to comment Share on other sites More sharing options...
lbuttery Posted August 11, 2014 Share Posted August 11, 2014 I've named and cutomized around 20 different Anno Sets Larry: I'm trying to learn can you share your 20 anno-sets ??? Lew Link to comment Share on other sites More sharing options...
ebdesign Posted August 11, 2014 Share Posted August 11, 2014 Unfortunately, it seems like annotation sets are now being viewed as a solution to problems that they were never intended to handle. Can we make that a "sticky"? Link to comment Share on other sites More sharing options...
HumbleChief Posted August 12, 2014 Share Posted August 12, 2014 I've named and cutomized around 20 different Anno Sets Larry: I'm trying to learn can you share your 20 anno-sets ??? Lew Tried to take a screen shot of the drop down box but can't figure that out. I use 7 or 8 on every plan and create them as I need them for special sets and construction techniques. I have new plan where the homeowner wants a raingutter plan, I'll create a new Anno Set for that one. As follows; Anno As Built Set Anno Demo Set Anno Detail Set Anno Elelctrical Set Anno Elevation Set Anno Foundation Set Anno Framing Floor Set Anno Framing Ceiling Set Anno Patio Cover Set Anno Roof Framing Set Anno Framing Set Anno Framing Steel Set Anno Plot Plan BMP's Set Anno Plot Plan Elevation Set Anno Plot Plan Set Anno Proposed Set Anno Proposed Set Bare Bones Anno Roofing Set Anno Section Set Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 12, 2014 Author Share Posted August 12, 2014 Larry, Why not just a new Layer Set? Is it because you want to have a different CAD Layer or a different "Locate Object" setting in Dimensions that you need an Annoset to select everything at once? Link to comment Share on other sites More sharing options...
lbuttery Posted August 12, 2014 Share Posted August 12, 2014 Larry: thanks for posting trying to learn - why would you need a different set for raingutters ? what would be different from the other anno sets ??? what's different among the various framing anno-sets ??? Lew Link to comment Share on other sites More sharing options...
HumbleChief Posted August 12, 2014 Share Posted August 12, 2014 Mostly it's just habit and easy for me to remember but if i do a raingutter set of plans I would like all the 'defaults' to be set what I choose to set them. Text, Callouts, Arrows, Dimensions, and the raingutters themselves. I might be able to use just a Layer Set but I don't understand that method and this is so easy for me to remember and all my settings will be consistent through all future plans as well. Lew, A Framing Ceiling Anno Set is mostly controlled by the Layer Set (Joe's point above perhaps?) and I just find it easier to have the Anno Set control the Layer Set and the differences would be (obvious once you delve in) that a ceiling framing set shows the ceiling framing and the roofing set shows the roofing framing etc. each along with its annotation text set to separate layer etc. Link to comment Share on other sites More sharing options...
