CBRF23 Posted February 15, 2018 Share Posted February 15, 2018 So for whatever reason, I haven't quite figured out yet, Chief doesn't like to apply my default wall color to the custom exterior wall types I've created. I always end up with just a plain drywall finish ( no paint). It's a real PITA to go back in and have to paint each wall individually, so I was wondering if there was a quick way to apply an interior material finish/wall color to ALL walls? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 15, 2018 Share Posted February 15, 2018 Add a thin layer of paint to your wall definitions. Then all you have to do is edit that "paint" material to the color you want. 1 Link to comment Share on other sites More sharing options...
dshall Posted February 15, 2018 Share Posted February 15, 2018 Post a small plan with the walls and what you are trying to do, somebody will help. 1 Link to comment Share on other sites More sharing options...
CBRF23 Posted February 19, 2018 Author Share Posted February 19, 2018 Joe - you were correct, there was no paint layer. Which is odd, because I thought I had set them all up with a paint layer. Must have been deleted somehow. Thanks!! Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 19, 2018 Share Posted February 19, 2018 Don’t the default wall types included in chief already have a default paint layer? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 19, 2018 Share Posted February 19, 2018 I find that sometimes that o paint layer screws thing up and I have deleted them all 2 Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 19, 2018 Share Posted February 19, 2018 On 2/15/2018 at 8:44 AM, CBRF23 said: So for whatever reason, I haven't quite figured out yet, Chief doesn't like to apply my default wall color to the custom exterior wall types I've created. I always end up with just a plain drywall finish ( no paint). It's a real PITA to go back in and have to paint each wall individually, so I was wondering if there was a quick way to apply an interior material finish/wall color to ALL walls? It's easy to change the drywall color to whatever you want, without a paint layer, using the Adjust Material Definition tool. Just click the tool on the drywall in a camera view. Applies to all walls with "Drywall" material: That won't work if you want multiple colors in a plan, but for that you could set up additional drywall materials with different colors. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 19, 2018 Share Posted February 19, 2018 On 2/19/2018 at 6:05 AM, Michael_Gia said: Don’t the default wall types included in chief already have a default paint layer? Not that I noticed in X9 or X10, (Ceilings do though) but a 0" layer is easy enough to add , it will also give you the Sqft for the Paint that way. Doing it on the Interior side seems to work okay , Exteriors seem to have Issues sometimes for whatever reason. 18 hours ago, Chrisb222 said: It's super easy to change the drywall color to whatever you want, without a paint layer, using the Adjust Material Definition tool. I use this method too it's easy to change the Texture for the Drywall either that way or through the Wall Definition where it usually says "no texture" , assuming all the Drywall has the same paint, but you can "paint" individual walls if needed or change the Material for those Walls, the Paint Can tool can have weird Effects at times. M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 20, 2018 Share Posted February 20, 2018 If anyone has a problem with something not showing in 3d ,then just delete that pesky zero layer and it will show again. Had that problem many times. Link to comment Share on other sites More sharing options...
parkwest Posted February 20, 2018 Share Posted February 20, 2018 5 minutes ago, DRAWZILLA said: If anyone has a problem with something not showing in 3d ,then just delete that pesky zero layer and it will show again. Had that problem many times. What would happen if you used .003 for the paint layer? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 20, 2018 Share Posted February 20, 2018 40 minutes ago, parkwest said: What would happen if you used .003 for the paint layer? Don't know b/c I delete those zero layers, and why does Chief include those layers anyway. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2018 Share Posted February 20, 2018 1 hour ago, DRAWZILLA said: Don't know b/c I delete those zero layers, and why does Chief include those layers anyway. Chief doesn't on walls just ceilings, there is a Line outside the Drywall but no Layer , like on Ceilings......is that what you mean? maybe they figured it out like you cos I don't see a "layer" in x9 or x10. ......0.003" just becomes 0" in Chief's DBX's , it's not even 1/10th of a mm (0.08mm) ..... in most DBX's 1/128th is the smallest, some won't go below 1/64th or even 1/32" Link to comment Share on other sites More sharing options...
