Designer1
Brick Sill
Does anyone know how to get the brick sill to move inside towards the window versus just sticking outside the wall?  I do have the recessed into wall selected.
Thanks in advance!
Chad
Chief won't do this for you - their window sill functionality is woefully inadequate for cases like this. If it's important enough, you can use a Molding Polyline. The added difficulty with an angled sill is that as you raise it into position you have to account for the bottom edge of the wall opening poking through:
...and when you raise it enough to obscure the wall edge, it will intrude on the bottom of the window jamb, so if you really want it to look nice, you need to thicken the bottom jamb so everything appears even all the way around the window:
Good luck.
This a sill from the library, not a molding polyline.
Post a simple plan showing the problem please.
Thanks in advance!
Chad
Don't use a sill. Make a symbol for the brick, then use -treatements, exterior millwork below casing. You will need to find the best origin and stretch areas to make it look right. Your signature doesn't say what version you are using? In X9 and later
I make the symbol how I think it works and open a 3D view. If it looks wrong then I open the symbol in the library and make an adjustment- in X9 and above you can then just drag the revised symbol onto the old one and it (usually) replaces the old one. IF it doesn't then you have to use the dbx to re-select the symbol.
Screen shot show the original symbol on the right and corrected origin on the left. Once I have a window I'm happy with I add it to the library and rename it. Then go to the next one of the same size that needs to be replaced, select, replace from library, replace all identical in plan. Presto
I have a library of brick molding profiles that I use and apply it to the sill profile.
Eric, that doesn't look like any sill I have in my default Library:
The problem I can't solve with Chief's sill is that if I use a profile for a brick sill as built IRL (15 degree angle), I get a gap in the wall beneath the sill (presumably because Chief uses the profile's bounding box to calculate the opening, not the actual cross-section depth of the profile where it intersects the wall):
Have you found a way to overcome this?
Do you have "apron" unchecked in dbx? That is what usually gives me the gap below. When I uncheck apron it goes away.
This is how I do my sills also; seems to work much better. I also use my own profiles for the lintels when needed. I never could get CA's to look right when using brick.
It's one I made, but don't think it is anything special.
Here is the plan. I placed the profile just in front of the window.
b-sill.zip
Here is a related suggestion I made, don't remember the specifics, but i think moving the window frame in causes a problem.
b-sill.zip
Eric, I can't open X10. But, I'm confused - in this post:
you imply that you're not using a molding polyline, but in your second post you state "I placed the profile just in front of the window". Which is it: a molding polyline with a profile, or a profile specified in the window dbx?
Yes,. apron is unchecked.
The sill profile is part of the window itself, and just to verify, Eric's example has the same problem you mentioned earlier but its not noticeable due to the thickness of his siding.
Yes, I too have a large library for lintels. I do a lot of historical homes and lintels for different looks.
It's a profile specified in the window dbx.
I placed the profile I chose in the plan for others to see, just in front of the window.
Oh, placed in plan. Obviously, that's what confused me about your post. Since I can't open X10, I can't see the profile.
I think like so many things in Chief, what you see depends on multiple variables.
Eric, thanks for posting an X9 plan.  Your less aggressive sill slope (7 degrees) and fatter wall (4" masonry cavity) results in a less noticeable bottom gap in the wall opening. For the OP's wall - an IRL brick sill slope of 15 degrees and a 1" to 2" EIFS thickness - I believe a molding polyline is a better solution if accuracy in Cross-Section and Ortho/3D views are important.
If you takes Eric's profile and make the bottom flat...change the pitch to 15 degrees if you prefer...save this profile in your library and attach it as a sill it fills the gap.  I don't think it's worth the time or trouble to use molding PL to create a "perfect" brick sill...to time consuming.
attached is the revised plan with the new sill.  Yea...it's not perfect but if you have to draw a section of a standard typical brick sill in exact detail for a brick mason...maybe you need new mason?
Erics modified b-sill X9.plan
Yes, sure. And there are more important issues Chief needs to fix, but in the quest for an accurate model, a window sill should be modeled with reasonable accuracy. The wall opening that is cut should be based off the cross-section of the sill profile - not the sill profile's bounding box. (There are several instances where Chief gets lazy and uses bounding boxes to determine things instead of the actual geometry of the object).
Wow Im blown away at all the responses... I havent been able to get back on Chieftalk for two days and a ton of information...thanks for the replies!
The reason I used the brick sill is because Chief came out with a special help article on how to make a brick sill molding.  For years Ive used this molding and have had zero issues.  Ive read all the feedback but realize that chief must have changed something in X9 (thats what Im currently using) because the same method as previous versions using the brick sill dont work.  Here is a pictures of a design I started in 2014... I cant remember what version of chief was out in 2014 but I had no problems with the sill and you just selected recessed into wall and it was great.
Years back chief came out with a custom brick molding you could use for a sill... I just did a search for it but couldnt find the sill but the soldier course trim here it is...
https://www.chiefarchitect.com/support/article/KB-00797/creating-a-soldier-course.html
I had a few questions based on some of your comments...
1. Eric- how did you get that sill when I didnt see that in any of my standard sill profiles?  Was it a custom you made?
2.  Tommy- sounds like a great variety of window sill you have... did you custom make those or was it an outside manufacture you got those from?
If you compare the two sill pictures I have on here you can see how correct the same exact molding profile displayed back in 2014 chief and the same sill displays in X9....Im not happy with the results.  Maybe a chief technical support person will chime in here and let us know if there were any software changes made to affect this option or perhaps a new way of selecting something else in the dbx that can achieve the same results.
One I made. Don't remember why. It's in the files I posted above.
I'd be very curious to see that first plan.  I suspect you did something differently.  Too many variables to guess at though.
BTW, this kind of thing can totally be done with the sill but it requires some relatively advanced symbol manipulation techniques.  I don't have time to get into it right now, but here's a quick sample plan that includes the 5 symbol generations it took to create the final 3D molding symbol (polyline solids>fixture>1/2 height fixture using bounding box>molding symbol>molding symbol with modified origins and bounding box)...
5a7bf7f856c08_pic3.thumb.jpg.b7467a252a070c095e44e83eeb38dfe6.jpg5a7bf7f951181_pic4.thumb.jpg.77b40f6b1f661929fd8f33ee342807ba.jpg5a7bf7fa2812a_pic5.thumb.jpg.e0fdd783e48a9fb0d97fe187cca8bd70.jpg5a7bf7f66448e_pic1.thumb.jpg.ef1322feda375b49a0a5cab236be2437.jpg5a7bf7f75ec76_pic2.thumb.jpg.29272fae0610c7494905868a38cf675c.jpg
Sill example.plan
Michael, your brick sill looks a lot better then mine! ;)  I made my sill many years ago when chief just first came out with the tutorial for this. Yours looks cleaner and less grout lines.  Eric and Michael the sample sills you posted are they for us chiefers to use?  I dont assume things posted are gifts for others to use without asking the creators of the symbols first!
I appreciate you asking but if I post it here in the forum you can always assume you’re free to use and share it unless I specifically state otherwise.  On a side note though, I also do welcome and appreciate donations if you ever find any of my offerings valuable enough to you.  It helps to offset the time it’s takes to answer questions, post tips, create custom content, and produce tutorial videos amongst other things.  Anyway, there’s my plug.  Have a good rest of your night :)
    27469
    THDesign
    THDesign
