rickyscott Posted January 23, 2018 Share Posted January 23, 2018 I am a fairly new user to chief and i am trying to figure out how to show the different phases of my project. By this i mean like Existing Plan, Demolition Plan and new wall plan.I am thinking CAD lines and using layer set but this is a little challenging for me so i am wondering if there is an easier way to accomplish this. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 23, 2018 Share Posted January 23, 2018 First thing - do the as is plan and save. Then from the as is plan do a save as and give it a name and then start your design. When I was in the business I would do accurate drawings, dimensions for the area I was going to work on but would eyeball the other areas so they looked correct. Many times only adjacent rooms etc. Usually always put a roof on it to stop "light bleed" at top of walls etc. Light bleed shows up in ray trace views. I often sent views from the as is plan just to show the transition. You can however get more complicated with layers and demo walls to overlay the new or existing design to show demo walls etc. There are threads on this you may want to search for. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 23, 2018 Share Posted January 23, 2018 There are several methods, but I think the vast majority of us do it with 3 plan files as both you and Dennis have alluded to. The basics: Draw As-Built plan. Name it "As-Built". Save. Use "As-Built" plan but Save As "Demolition". Create a CAD Detail From View of your floor plan(s), modify and delete items as necessary, put all the line work onto a unique layer, paste hold position and move to back group. This will allow you to both see and display the as-built items if desired. Modify plan as necessary to create demolition plan. Save. Use "Demolition" plan but Save As "Proposed". Modify plan as necessary to create Proposed plan. Save. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 23, 2018 Share Posted January 23, 2018 Learn to use Anno-sets, and layer sets , you don't need to use any cad except for the cad background, to do all of it. Create different walls for existing and new. Create a cad background of the existing as built plan, and put it in the background of you new remodeled plan.Too much to list all here, watch some of Chiefs remodeling videos. I have my own way of doing it, but it's similar. doing all of this, when you remove a wall the cad background wall will show up automatically and that's much cleaner than having invisible walls. It quite a process, not everything is listed here but as you go you will learn. Link to comment Share on other sites More sharing options...
lbuttery Posted January 23, 2018 Share Posted January 23, 2018 I'm contrarian I create the remodel plan first as that is what the clients want to see when that is "stable" I do "save as" for the as-built plan and take out remodel stuff and tinker as necessary to get to as-built sometimes doing non-remodel areas as "rough" and not showing unnecessary details various methods for showing demo walls etc Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted January 23, 2018 Share Posted January 23, 2018 If you are new to CA I highly recommend the New Tutorial Guide and getting to know the CA Knowledge base (KB) which has many,many tutorials too eg. one on what Michael mentioned with the CAD Detail... https://www.chiefarchitect.com/support/article/KB-02208/showing-the-as-built-in-a-remodel-plan.html https://www.chiefarchitect.com/support/database.html Tutorial Guide and Ref. Manual https://www.chiefarchitect.com/support/documentation.html ***It is recommended to Fill in your Forum Signature too...see mine for how to do yours... Link to comment Share on other sites More sharing options...
justmejerry Posted January 24, 2018 Share Posted January 24, 2018 You should check this video by dshall. Lots of good vids for new users on his Youtube. https://www.youtube.com/watch?v=ZNqVqkJOpnw 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted 12 hours ago Share Posted 12 hours ago On 1/23/2018 at 7:08 PM, justmejerry said: You should check this video by dshall. Lots of good vids for new users on his Youtube. https://www.youtube.com/watch?v=ZNqVqkJOpnw IT'S A DECENT VIDEO, BUT BOY DOES HE NEED SOME COMMUNICATION SKILLS. I BARELY LAST 2 MIN. 1 Link to comment Share on other sites More sharing options...
