Manual Dimensions for Doors & other openings.
ACADuser
5 hours ago, ACADuser said:
Trying to dimension a door opening manually, 19'-7" Nano SGD, but no snaps to the frame of the door.
What am I doing wrong? The only snap that will come close is the "On Object" snap which is only snapping to the wall MOL.
Alan,
What is a "19'-7" Nano SGD"?
If it is standard library window or door, you need Openings...Sides checked in your dimension defaults.
You can turn all snaps off as you don't need any snaps to dimension openings.
If it is a symbol or some other type of custom opening, that is a different story.
Alan,
As I said...
Quote
This also applies to a Doorway, which is a standard Chief door type.
