rfhager2169 Posted July 3, 2016 Share Posted July 3, 2016 So previously I used Chief10 and was fairly decent with it. then I changed jobs. Now I'm back to using Chief X8 on the side for a friend and trying to learn some of the upgrades and changes that have been made. Currently, I'm trying to draw a walk out bay, and I need a flat section of wall inside before the angle starts. I'm sure in 10 there was a wall tolerance that could be set for the min length of a wall (maybe not, its been a while). I cant seem to find any setting that helps, and the flat section of wall I need dives right into the angle when I set the measurement (making the flat wall disappear). any guidance? Attached file to show a pic of what I'm trying to say Link to comment Share on other sites More sharing options...
johnny Posted July 4, 2016 Share Posted July 4, 2016 I know this sort of thing can be frustrating for sure - Chief's wall snapping is tough to work with sometimes in these situations. However, in your case I didn't seem to have an issue you mention, so I am curious what I am doing you aren't. I think you should draw the bay with lines to create guild-lines to snap to - although I just entered 4" and no problem without lines. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 4, 2016 Share Posted July 4, 2016 Johnny, I think it is the inside corner that has to be 4" like this. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 4, 2016 Share Posted July 4, 2016 Sorry Rfhager, At first I did not see all the details but this is my best stab at the situation as I see it now, a little more complex with a thicker wall. Make the Cad Patch a Polyline Solid and the brickwork will look ok in 3D. Maybe someone with a little more know how can take a look at this and iron out the details for me. I am hoping there is a better way.P.S. Sorry I got a little sloppy, if the wall is 45o then the filler wall should be 1 11/16" as in previous post. Link to comment Share on other sites More sharing options...
glennw Posted July 4, 2016 Share Posted July 4, 2016 This vid may help. http://screencast.com/t/NOEMW0y6 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted July 4, 2016 Share Posted July 4, 2016 Thanks Glenn, You make that look soo easy. I am kinda embarrassed at how much I struggled to make that work with the thick wall but your technique worked for that to. Always learning. Such Finesse!! Thanks Again Glenn, Chopsaw Link to comment Share on other sites More sharing options...
glennw Posted July 4, 2016 Share Posted July 4, 2016 No worries Chop. That is one little trick I dragged up from the depths. Finesse, yeah, that's me! Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted July 4, 2016 Share Posted July 4, 2016 Glenn - That is a GREAT tip! Link to comment Share on other sites More sharing options...
rfhager2169 Posted July 4, 2016 Author Share Posted July 4, 2016 Thanks guys. I was banging my head against the desk forever trying to get that inside wall to be 4". Link to comment Share on other sites More sharing options...
Kenoeightspot Posted July 5, 2016 Share Posted July 5, 2016 Great tip. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 6, 2016 Share Posted July 6, 2016 Jesus, does the man ever stop coming up with this stuff, is he an alien. Thanks buddy, keep them coming. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 7, 2016 Share Posted July 7, 2016 Yep. Good tip Glenn. As with a lot of these wall connection issues, the solution is often in the smallest details of the operation, the order, the sequence, etc. Here's another take... If you use the right wall along with the right movement method it works fine... The more difficult problem in my mind is (as Chopper pointed out)...the outside layers in situations like that... Link to comment Share on other sites More sharing options...
Chopsaw Posted July 7, 2016 Share Posted July 7, 2016 Yes, I got the same results with Glenn's method and the Brick 4 Wall but in 3D it is essentially an overlap and does not show. So for this situation I am quite happy to do a little 2D cad touch up now that I know with the right approach this type of thing can be accomplished in Chief. Which when you think about it is really quite amazing what the software can do considering that most of the planet is still building with sticks and stones in one way or another. Link to comment Share on other sites More sharing options...
johnny Posted July 7, 2016 Share Posted July 7, 2016 I hope Glenn or Micheal (or anyone) has a solution for when sizing a wall that doesn't have something to nudge...? I'm having this problem right now. (sorry no sound to my vid as my headset broke) problem_wall.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 7, 2016 Share Posted July 7, 2016 I'm away from my computer right now, but off the top of my head, the first thing I think I might try would just be to place a break, select the little wall and change the wall type to a copy of the existing wall type. I'm sure there are other solutions but that one is usually pretty stable. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 7, 2016 Share Posted July 7, 2016 Johnny, If your movement method indicators are not available as in Michaels method ( post #12 ) I would try to back off the stubby wall, set the other, then bring the stubby one back to position with Glenn's method. Not sure but worth a try. P.S. My headset blew up last night too. Maybe the same lot # ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 7, 2016 Share Posted July 7, 2016 You know what I use for a microphone? My iPhone along with a simple app called Megaphone. Works great. Link to comment Share on other sites More sharing options...
johnny Posted July 7, 2016 Share Posted July 7, 2016 Thanks for the suggestions but neither worked. Im stuck on this. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 7, 2016 Share Posted July 7, 2016 Thanks for the suggestions but neither worked. Im stuck on this. That can't be true, my method works fine. I know it does. I use it all the time and I tested it on your plan too when I got back to the office. Maybe I'm missing what you're trying to accomplish? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 8, 2016 Share Posted July 8, 2016 Just sent you a PM Johnny, feel free to give me a call. Link to comment Share on other sites More sharing options...
johnny Posted July 8, 2016 Share Posted July 8, 2016 Perhaps I am not doing it correctly. Here is what im doing. Will call Micheal - thanks...ill wait a sec in case you have time to see the vid. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 8, 2016 Share Posted July 8, 2016 That is quite an interesting wall Johnny. Did you and Michael get it sorted? Link to comment Share on other sites More sharing options...
