cjanderson66 Posted March 16, 2016 Share Posted March 16, 2016 Ok guys, I know there is a way to do it and I can't keep spending time trying to find it so I am hoping that someone can help me figure this out. I am trying to do a coffered ceiling and I want the grid to be equal boxes. the way I usually do it in AutoCAd is take a line and divide that line equally to fin the centers of m beam. How can I divide a line into 4 part or distribute a line along a line. I have tried align/distribute but when I pick the line it does not give me the capability to distribute along the line just align... 1 Link to comment Share on other sites More sharing options...
Solution KenL-sdd Posted March 16, 2016 Solution Share Posted March 16, 2016 There in no need to add that extra step. Draw line at one end use multiple copy using 5 copies. That will give you your spacing. 4 Link to comment Share on other sites More sharing options...
rlackore Posted March 16, 2016 Share Posted March 16, 2016 Draw three circles (or points, or whatever - it doesn't matter). Pick the circles, then Align to Line: This won't physically divide the line into four equal segments, but it will give you the four relevant points along the line. 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted March 16, 2016 Author Share Posted March 16, 2016 There in no need to add that extra step. Draw line at one end use multiple copy using 5 copies. That will give you your spacing. Thanks Ken, I could not for the life of me remember that tool. Link to comment Share on other sites More sharing options...
KenL-sdd Posted March 16, 2016 Share Posted March 16, 2016 Glad to help!!! Link to comment Share on other sites More sharing options...
dshall Posted March 16, 2016 Share Posted March 16, 2016 There in no need to add that extra step. Draw line at one end use multiple copy using 5 copies. That will give you your spacing. You have to be kidding me.... 10 years later I learn this? Hey, thank Ken, nice job, I will give you a point, I would give you 20 points if I could. Link to comment Share on other sites More sharing options...
dshall Posted March 16, 2016 Share Posted March 16, 2016 Draw three circles (or points, or whatever - it doesn't matter). Pick the circles, then Align to Line: align2.PNG This won't physically divide the line into four equal segments, but it will give you the four relevant points along the line. Hey Racklamore, check out Ken's answer..... SWEEEEETTTTT!!!!!! Link to comment Share on other sites More sharing options...
dshall Posted March 16, 2016 Share Posted March 16, 2016 You know it is this minor little stuff that a lot of us.... or I should say me..... do not use...... I wish there was some little workshop we could go to to pick up all these little tips. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 ...I would give you 20 points if I could. I gave him an extra point on your behalf : ) Link to comment Share on other sites More sharing options...
dshall Posted March 16, 2016 Share Posted March 16, 2016 I gave him an extra point on your behalf : ) are there 18 other folks that will give him a point? Thanks Alaska. Link to comment Share on other sites More sharing options...
cjanderson66 Posted March 16, 2016 Author Share Posted March 16, 2016 Thanks again for all your help, it is the little things like this that make a huge difference and the great people on this forum. Here is what I was trying to achieve with that little tid bit of info. Link to comment Share on other sites More sharing options...
rlackore Posted March 16, 2016 Share Posted March 16, 2016 Hey Racklamore, check out Ken's answer..... SWEEEEETTTTT!!!!!! Maybe I don't understand Ken's method, but if I do, then his method requires you to know the length of the line, and use a calculator to divide it by 4, then multiple copy 5 lines with the calculated answer; and if the line length is an ugly fraction, then your calculated interval will be even uglier. I'm not saying my method is better, but the mouse/calculator clicks are about even, and mine lets Chief do the math. Link to comment Share on other sites More sharing options...
cjanderson66 Posted March 16, 2016 Author Share Posted March 16, 2016 Maybe I don't understand Ken's method, but if I do, then his method requires you to know the length of the line, and use a calculator to divide it by 4, then multiple copy 5 lines with the calculated answer; and if the line length is an ugly fraction, then your calculated interval will be even uglier. I'm not saying my method is better, but the mouse/calculator clicks are about even, and mine lets Chief do the math. no you just draw a line and then use the multiple copy and set the interval of the divided areas you would like to have. Super simple and that is what I was looking for. Link to comment Share on other sites More sharing options...
rlackore Posted March 16, 2016 Share Posted March 16, 2016 no you just draw a line and then use the multiple copy and set the interval of the divided areas you would like to have. Super simple and that is what I was looking for. Your OP stated, in part: "How can I divide a line into 4 parts or distribute a line along a line." So, I'm assuming you already have a line drawn, and you need to divide it into 4 equal parts. Using your method, doesn't this require you to first know the length of the line , and then to calculate it's quarter-points? How else will you know what interval to use when you Multiple Copy? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 Your OP stated, in part: "How can I divide a line into 4 parts or distribute a line along a line." So, I'm assuming you already have a line drawn, and you need to divide it into 4 equal parts. Using your method, doesn't this require you to first know the length of the line , and then to calculate it's quarter-points? How else will you know what interval to use when you Multiple Copy? You don't use an interval. You just set the number of copies and distribute from one end of the line to the other. Link to comment Share on other sites More sharing options...
rlackore Posted March 16, 2016 Share Posted March 16, 2016 You don't use an interval. You just set the number of copies and distribute from one end of the line to the other. Okay, I explored the Multiple Copy tool some more. Are you referring to this function?: It works as you described, but I'd never used it before. Now I'm smarter. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 Okay, I explored the Multiple Copy tool some more. Are you referring to this function?: align3.PNG It works as you described, but I'd never used it before. Now I'm smarter. Yep. That's the one. Link to comment Share on other sites More sharing options...
country Posted March 16, 2016 Share Posted March 16, 2016 OMG. That is great. I'm with Scott on needing a class just for these little, but oh so important tips. I gave Ken a point too. Link to comment Share on other sites More sharing options...
cjanderson66 Posted March 16, 2016 Author Share Posted March 16, 2016 Here is an example of what I was trying to do to create my coffered ceiling and how it was created by the answer I got. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 FWIW, If your items are already drawn, variations of the method Robert mentioned would actually be faster. Link to comment Share on other sites More sharing options...
Gawdzira Posted March 16, 2016 Share Posted March 16, 2016 Scott, time for another workshop. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 Here is an example of what I was trying to do to create my coffered ceiling and how it was created by the answer I got. There are actually quite a few methods a person could use to get those sorts of numbers without even having a line. For example, you could place point markers at both corners and then drop 3 more in between. While the point marker tool is still active, Control or Shift select them, click Align/Distribute Objects and select space evenly in both directions. Link to comment Share on other sites More sharing options...
country Posted March 16, 2016 Share Posted March 16, 2016 I just tried Ken's method with my deck posts and it worked perfectly. 2 fantastic time savers in one. Great day! Edit....I actually meant rlacklore's method. I spaced the posts along the beam. No time at all to do it once you know how. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 16, 2016 Share Posted March 16, 2016 I just tried Ken's method with my deck posts and it worked perfectly. 2 fantastic time savers in one. Great day! I obviously haven't seen your plan, but for things like deck posts all you often times have to do is group select them and use Align/Distribute Objects...Space Evenly or Distribute Centers Evenly. Often times no need for drawing any extra lines at all. Align/Distribute Along Line (using a wall or some other existing object) could work equally well for that situation too. Link to comment Share on other sites More sharing options...
glennw Posted March 16, 2016 Share Posted March 16, 2016 How about this way which actually breaks the line into 4 parts. Make sure Midpoint Snaps are toggled on. Select the line. Select the Break Line tool on the Edit toolbar. Select Sticky Mode. Snap to the centre of the line. Snap to the centre of the new left hand section. Snap to the centre of the right hand section. this gives you a polyline broken into 4 equal parts. You can even use the Complete Break option as well if you want 4 individual lines instead of a polyline. Link to comment Share on other sites More sharing options...
