payettedesigns Posted October 26, 2015 Share Posted October 26, 2015 Does anyone have a detail of how a deck connects to web floor truss. Link to comment Share on other sites More sharing options...
HumbleChief Posted October 26, 2015 Share Posted October 26, 2015 http://www.woodbywy.com/document/tj-4000/ Link to comment Share on other sites More sharing options...
Greg_NY61 Posted October 26, 2015 Share Posted October 26, 2015 Since floor trusses dont have a typical rim joist to what you usually attach your deck ledger, in most cases you would do a free standing deck...or you hire an engineer to design an appropriate connection detail. Link to comment Share on other sites More sharing options...
HumbleChief Posted October 26, 2015 Share Posted October 26, 2015 ..or look on page 8 in the PDF linked above - look for, of all things, the detail titled 'exterior deck attachment'. Might be what you're looking for. Link to comment Share on other sites More sharing options...
JJohnson Posted October 26, 2015 Share Posted October 26, 2015 Does anyone have a detail of how a deck connects to web floor truss. Hand drawn (you can make your own CA cad detail) detail showing a deck connected to house floor framing with HDs. and threaded rods. From a project two years ago drawn by a local architect. Link to comment Share on other sites More sharing options...
rlackore Posted October 26, 2015 Share Posted October 26, 2015 Does anyone have a detail of how a deck connects to web floor truss. Do you mean an open web truss, or an i-joist? The previous answers address an i-joist scenario. If we're talking about an open web truss, then the answer depends on whether the deck attaches perpendicular to the trusses or parallel to the trusses, as well as how the end bearing condition is fabricated/detailed. Open web trusses provide superior cantilever lengths and options, depending on the depth of the truss. Can you post a drawing or picture of what you are trying to achieve? Link to comment Share on other sites More sharing options...
GaryOhmer Posted October 26, 2015 Share Posted October 26, 2015 Up here in Southeast Alaska we don't use ledger boards anymore to attach decks - we use the Maine Deck Bracket http://deckbracket.com/ - here in Ketchikan our record rainfall is over 202" Link to comment Share on other sites More sharing options...
joey_martin Posted October 26, 2015 Share Posted October 26, 2015 Ketchikan!? With the bush people my kids love to watch on TV? Link to comment Share on other sites More sharing options...
HumbleChief Posted October 26, 2015 Share Posted October 26, 2015 Up here in Southeast Alaska we don't use ledger boards anymore to attach decks - we use the Maine Deck Bracket http://deckbracket.com/ - here in Ketchikan our record rainfall is over 202" That's a pretty cool product Gary. Did you run into any code or engineering problems when spec'ing that bracket? I live in CA and never know what to expect if I were to spec that product on a job. Link to comment Share on other sites More sharing options...
GaryOhmer Posted October 26, 2015 Share Posted October 26, 2015 Same place - but I never watch it - to fake - never had a code problem with the brackets - The claims are at 8' on center is 1000 lbs. capacity. Link to comment Share on other sites More sharing options...
GaryOhmer Posted October 26, 2015 Share Posted October 26, 2015 Here's more info http://www.icc-es.org/reports/pdf_files/icc-es/esr-1331.pdf Link to comment Share on other sites More sharing options...
joey_martin Posted October 26, 2015 Share Posted October 26, 2015 Consider this scenario if the ledger won't work. I have spec'ed open joist trusses that do provide for a 1 1/8" LVL rim joist, but most do not. Link to comment Share on other sites More sharing options...
rlackore Posted October 26, 2015 Share Posted October 26, 2015 I have spec'ed open joist trusses that do provide for a 1 1/8" LVL rim joist, but most do not. In my experience the ribbon board can be specified for any depth - the bigger problem is that they are primarily for alignment, so if you spec a bigger ribbon board and need it for structural attachment of an exterior ledger, then you also need to specify to the framer how to attach the ribbon board to the trusses. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted October 27, 2015 Share Posted October 27, 2015 I have that bracket made, if anyone needs it for your drawing details, help yourself. Deck Ledger Bracket.calibz Link to comment Share on other sites More sharing options...
