pazzfam Posted June 30, 2015 Share Posted June 30, 2015 Hi I have taken DHall advise and started experimenting with wall layer to create a monolithic foundation and show all the steel ect. which is all cad I am not going to cad detail trying to keep foundation attached to main house. Problem you have to constantly keep using the tab key to get to my cad lines ect and not select whole wall and doors . Am I missing something I seem to remember back in an old version of chief you would hit a icon to switch to cad mode so I would only be selecting cad is there a way to do that in these new versions Thanks in advance Adam Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 30, 2015 Share Posted June 30, 2015 The fix, don't waste you time trying to have accurate steel, in the footings, in sections, just address this with cad details. A lot of trouble, if you ask me. Link to comment Share on other sites More sharing options...
pazzfam Posted June 30, 2015 Author Share Posted June 30, 2015 Problem we have to show all the steel for slab and beam in Florida The attached plan is for a 24 stall horse barn knopp 2015 ida final 6-2-2015-Layout.pdf Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 30, 2015 Share Posted June 30, 2015 Can't a detail work? Link to comment Share on other sites More sharing options...
pazzfam Posted June 30, 2015 Author Share Posted June 30, 2015 I wish it could but all vertical bars are the x have to show where everything goes doors windows The building departments expect it. The problem I go to foundation turn off all layers except main when I am adding cad to the main walls they do not snap because they are not cad. It works well when I convert the whole floor plan to a cad detail I can go pretty quick. It is better to be attached for changes. This barn I was drawing 249 ft was completely done when owner realized he needed to take 5 feet off it changed everything on plan 6 inch form each stall ect. I am changing whole plan (getting paid) but I give huge discount Link to comment Share on other sites More sharing options...
ShaneK Posted July 1, 2015 Share Posted July 1, 2015 Keep the customer happy, nice print. I do as Perry does, detail it in cad and save for future use. Link to comment Share on other sites More sharing options...
pazzfam Posted July 1, 2015 Author Share Posted July 1, 2015 I guess there is no way to just be in a cad mode and select just cad Thanks for your help Link to comment Share on other sites More sharing options...
glennw Posted July 1, 2015 Share Posted July 1, 2015 I guess there is no way to just be in a cad mode and select just cad Thanks for your help Start the Draw Line tool. Instead of drawing a line, left click to select only cad objects. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2015 Share Posted July 1, 2015 can't you lock every layer except Cad,Default ( or whatever you use) and maybe text too if you want to change notes? so you can't select them. M. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 1, 2015 Share Posted July 1, 2015 Create a new Layerset and lock all layers except the ones you want to edit; makes it easy to switch back and forth that way. Mike Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2015 Share Posted July 1, 2015 Create a new Layerset and lock all layers except the ones you want to edit; makes it easy to switch back and forth that way. Mike a better idea Link to comment Share on other sites More sharing options...
pazzfam Posted July 1, 2015 Author Share Posted July 1, 2015 I will try that thanks Link to comment Share on other sites More sharing options...
pazzfam Posted July 1, 2015 Author Share Posted July 1, 2015 Locking the wall normal worked great Thank You Link to comment Share on other sites More sharing options...
glennw Posted July 1, 2015 Share Posted July 1, 2015 What? You didn't like my "Cad mode" technique? Link to comment Share on other sites More sharing options...
MickeyToo Posted July 2, 2015 Share Posted July 2, 2015 Great tip, Glenn. Where is that in the Ref. Manual? Link to comment Share on other sites More sharing options...
glennw Posted July 2, 2015 Share Posted July 2, 2015 Great tip, Glenn. Where is that in the Ref. Manual? Ref Manual? You mean there is a ref manual? Link to comment Share on other sites More sharing options...
MickeyToo Posted July 2, 2015 Share Posted July 2, 2015 Ha! I would have thought you wrote it. Link to comment Share on other sites More sharing options...
Statewide Posted August 12, 2020 Share Posted August 12, 2020 On 7/1/2015 at 5:11 PM, pazzfam said: Locking the wall normal worked great Thank You Thank you, (maybe a 5yr old thread but helped me a lot today) I was having the same issue, placing dowels in the wall. I went from v9.54 to X11. Lot of nice new stuff, but miss a lot of old stuff. Now hopefully I will remember later that it's locked and not wonder why I can't move my walls. LOL Link to comment Share on other sites More sharing options...
pazzfam Posted August 12, 2020 Author Share Posted August 12, 2020 you know it is funny reading this thread I was doing everything in cad This thread had helped me more than anything with the program. I did not even know you could turn off and on wall layers I would go to cad detail windows and have to zoom in just to make sure every measurement was on the main layer OMG Still learning Link to comment Share on other sites More sharing options...
