mrscott Posted June 19, 2015 Share Posted June 19, 2015 CT Guru's. I guess I just don't get CA Foundation tool so I have elected to create my own manually. Frankly, I need to be able to do this anyway as I have a Structural Engineer wanting me to do some CAD layouts for him. So my question is two fold. 1) my current plan has a Foundation level but I have all default "Footings" unchecked. You can't delete them so I can only think to hide them and do my own. 2) If I were creating just a Foundation plan and not a model, I would then need to Create the foundation on level 1 Okay, Blank Sheet. Created my corner footings from a polyline box with no footings checked in the DBX.. Layer is "FOUNDATION, FOOTINGS") Material is Concrete and fill is Concrete so they look like concrete in plan view Take an Elevation or Back Clip view and nothing displays (LAYER IS CHECKED - I GOT THAT MUCH) Take 3D Floor Perspective view and all looks great. (WITH ONLY THE Layer "FOUNDATION, FOOTINGS" CHECKED) What am I doing wrong that the Elevation view are blank. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 19, 2015 Share Posted June 19, 2015 Learn to use the foundation tools given to you by chief, they work good for me. Then it will work for you Link to comment Share on other sites More sharing options...
mrscott Posted June 19, 2015 Author Share Posted June 19, 2015 Perry, You are absolutely right (LEARN) is the key word. I am learning but there is much to be done in the process of learning all the processes with CA. You, and this community, are an invaluable resource and one I do not take lightly. Many have said there is no single way to do things in CA so I am appealing to all for input. Thanks again, Link to comment Share on other sites More sharing options...
HumbleChief Posted June 19, 2015 Share Posted June 19, 2015 Try the 'All On' Layer just in case, and go up/down a floor in your elevation view in case you're on the wrong floor. Or...post the plan and someone will fix it instantly. Link to comment Share on other sites More sharing options...
mrscott Posted June 19, 2015 Author Share Posted June 19, 2015 Okay Gurus! Here is the plan. Appreciate your help figuring out why the Footings won't display. Added Plan file. Sorry Studio.zip Link to comment Share on other sites More sharing options...
jbaehmer Posted June 19, 2015 Share Posted June 19, 2015 I downloaded it and only see materials.....no plan file. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 19, 2015 Share Posted June 19, 2015 Ahhhh MrScott you forgot to put the plan in your Zip file lots of lovely textures though Link to comment Share on other sites More sharing options...
Gawdzira Posted June 19, 2015 Share Posted June 19, 2015 Close down the Chief program then zip the plan file. Link to comment Share on other sites More sharing options...
AndyGump Posted June 19, 2015 Share Posted June 19, 2015 Turn on the "slab"' layer. Andy. Link to comment Share on other sites More sharing options...
AndyGump Posted June 19, 2015 Share Posted June 19, 2015 The plan is there. Andy. Link to comment Share on other sites More sharing options...
jbaehmer Posted June 19, 2015 Share Posted June 19, 2015 Turn on the "slab"' layer. Andy. Andy got it. I turned on slab and it showed up. Link to comment Share on other sites More sharing options...
mrscott Posted June 21, 2015 Author Share Posted June 21, 2015 thanks guys! Link to comment Share on other sites More sharing options...
HumbleChief Posted June 21, 2015 Share Posted June 21, 2015 Scott, Don't forget the 'All On' layer, it can fix problems like this quickly. Link to comment Share on other sites More sharing options...
