winterdd Posted yesterday at 10:21 PM Share Posted yesterday at 10:21 PM Hey guys, the questions continue. This would be a first for me. Radiused exterior wall and roof. How would a builder do this or how can we break the overhang to curve with the wall if that would even look good at all? Link to comment Share on other sites More sharing options...
PitMan71 Posted yesterday at 10:36 PM Share Posted yesterday at 10:36 PM Roof would probably need to be segmented to create the curve. You might consider drawing something similar in a new drawing and let chief roof it for you to get the idea. As far as being built the framer would probably just bend the wall rat sill on that curve and then attach the studs and curve the top plates. Something tighter would probably require another method. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted 23 hours ago Share Posted 23 hours ago It looks similar to a bow window. You could do small roof sections and have them come back to a straight section where the wall breaks at the curve 1 1 Link to comment Share on other sites More sharing options...
winterdd Posted 23 hours ago Author Share Posted 23 hours ago Thanks guys I was hoping this tool would work after adding a break on the mid span of the roof overhang. I love this tool but aren't having any luck. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 22 hours ago Share Posted 22 hours ago 37 minutes ago, winterdd said: Thanks guys I was hoping this tool would work after adding a break on the mid span of the roof overhang. I love this tool but aren't having any luck. 260121 (5).mp4 2 Link to comment Share on other sites More sharing options...
CharlesVolz Posted 22 hours ago Share Posted 22 hours ago 2 hours ago, PitMan71 said: Roof would probably need to be segmented to create the curve. Yes, in order to keep your fascia level (if that is your goal). 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 21 hours ago Share Posted 21 hours ago Just now, CharlesVolz said: Yes, in order to keep your fascia level (if that is your goal). yup this is what I would do 1 Link to comment Share on other sites More sharing options...
Doug_N Posted 21 hours ago Share Posted 21 hours ago I tried to duplicate what you did Rene, and it does work for the plan view, but when you look at a camera view, nothing has changed, the roof still has a straight edge. Did I miss something? 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted 21 hours ago Share Posted 21 hours ago That's pretty cool. Did not realize roof and regular polylines can be added together. Thanks for the tip! 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted 19 hours ago Share Posted 19 hours ago 2 hours ago, Doug_N said: I tried to duplicate what you did Rene, and it does work for the plan view, but when you look at a camera view, nothing has changed, the roof still has a straight edge. Did I miss something? Select the roof plane and use the union tool. You may have selected the polyline and used the union tool 1 Link to comment Share on other sites More sharing options...
winterdd Posted 8 hours ago Author Share Posted 8 hours ago 14 hours ago, Renerabbitt said: 260121 (5).mp4 3.47 MB · 0 downloads Thanks man, I tried it but couldn't get it to work on mine but I did get it to work on another easier roof. Segments got it to work although I don't think it is 100% perfect. It does build really nice framing to what I did though. Upvotes to all who helped...... Link to comment Share on other sites More sharing options...
Doug_N Posted 5 hours ago Share Posted 5 hours ago Rene was right, it matters what to order of selection is. In this view, two roof planes were created to reduce the slope of the roof in the curved roof area so that the lowest edge of the roof was not too low. Being able to curve the roof base is not subject to the curve tool. Link to comment Share on other sites More sharing options...
