winterdd Posted 2 hours ago Share Posted 2 hours ago Hey guys, the questions continue. This would be a first for me. Radiused exterior wall and roof. How would a builder do this or how can we break the overhang to curve with the wall if that would even look good at all? Link to comment Share on other sites More sharing options...
PitMan71 Posted 2 hours ago Share Posted 2 hours ago Roof would probably need to be segmented to create the curve. You might consider drawing something similar in a new drawing and let chief roof it for you to get the idea. As far as being built the framer would probably just bend the wall rat sill on that curve and then attach the studs and curve the top plates. Something tighter would probably require another method. Link to comment Share on other sites More sharing options...
Rookie65 Posted 2 hours ago Share Posted 2 hours ago It looks similar to a bow window. You could do small roof sections and have them come back to a straight section where the wall breaks at the curve Link to comment Share on other sites More sharing options...
winterdd Posted 1 hour ago Author Share Posted 1 hour ago Thanks guys I was hoping this tool would work after adding a break on the mid span of the roof overhang. I love this tool but aren't having any luck. Link to comment Share on other sites More sharing options...
Renerabbitt Posted 42 minutes ago Share Posted 42 minutes ago 37 minutes ago, winterdd said: Thanks guys I was hoping this tool would work after adding a break on the mid span of the roof overhang. I love this tool but aren't having any luck. 260121 (5).mp4 Link to comment Share on other sites More sharing options...
CharlesVolz Posted 20 minutes ago Share Posted 20 minutes ago 2 hours ago, PitMan71 said: Roof would probably need to be segmented to create the curve. Yes, in order to keep your fascia level (if that is your goal). Link to comment Share on other sites More sharing options...
Renerabbitt Posted 19 minutes ago Share Posted 19 minutes ago Just now, CharlesVolz said: Yes, in order to keep your fascia level (if that is your goal). yup this is what I would do Link to comment Share on other sites More sharing options...
Doug_N Posted 8 minutes ago Share Posted 8 minutes ago I tried to duplicate what you did Rene, and it does work for the plan view, but when you look at a camera view, nothing has changed, the roof still has a straight edge. Did I miss something? Link to comment Share on other sites More sharing options...
