Radiused exterior wall
winterdd
Hey guys, the questions continue. This would be a first for me. Radiused exterior wall and roof. How would a builder do this or how can we break the overhang to curve with the wall if that would even look good at all?
image.thumb.png.b560d5cc195f75a0e0f30dc25513732e.pngimage.thumb.png.d739fe02c10c1c5adfe99b32c3b1b8e4.png
Roof would probably need to be segmented to create the curve. You might consider drawing something similar in a new drawing and let chief roof it for you to get the idea. As far as being built the framer would probably just bend the wall rat sill on that curve and then attach the studs and curve the top plates. Something tighter would probably require another method.
I tried to duplicate what you did Rene, and it does work for the plan view, but when you look at a camera view, nothing has changed, the roof still has a straight edge.  Did I miss something?
Select the roof plane and use the union tool. You may have selected the polyline and used the union tool
14 hours ago, Renerabbitt said:
Thanks man, I tried it but couldn't get it to work on mine but I did get it to work on another easier roof. Segments got it to work although I don't think it is 100% perfect. It does build really nice framing to what I did though. Upvotes to all who helped......
Rene was right, it matters what to order of selection is.  In this view, two roof planes were created to reduce the slope of the roof in the curved roof area so that the lowest edge of the roof was not too low.
Being able to curve the roof base is not subject to the curve tool.
It's a little appreciated fact that roof planes
can be shaped like 3D Solids using Chief's
Boolean tools.
@Bill_Emery taught me this technique
about 10 years ago. Create a 3D Solid
containing the curve you want the roof to
follow. Over lap the two where you want
the roof cut and using Solid Subtraction
select the roof plane and subtract the 3D
Solid from it.
Boolean tools.
Solid from it.
This worked beautifully and cleaner than segments.
As a retired contractor, I try not to add design elements that are costly and add too much to the construction costs (although some clients don't care about cost to realize their vision). My concern with a radius wall is that windows want to be attached to a flat surface. The other is fabricating top and bottom plates that are curved.
If the builder is on board with the design, it will be great...if not, it may be back to the drawing board. I mean computer!
I try to warn clients of extravagant stuff like this but if they have the money and demand it I do it.
