X16 PBR
kwhitt
The introduction of Area Lights and Translucency in PBR is a game changer in X16.  I feel like we have almost everything we now need to create high quality images within Chief without the use of 3rd party renderers.  I have more shaders and features on my wish list, but I have to say I am very pleased with this release.  Thanks Chief!
One of the first things I’d have Chief implement is an Area Light fixture tool.  Right now, I must create a face of the appropriate size (in an elevation view) and point it in the right direction to be used as a fill light.  This can be a little tricky as I can’t figure out a way to rotate a face manually in plan view.  Were I to use a 3 solid, all sides with normals would emit light – not ideal.
The second feature I’d implement is the ability to adjust emitter intensity per camera view.  It would also be nice to open and close doors automatically as needed per camera view.
The images below underwent only minor curve adjustments in Photoshop – that’s it.
  • Upvote 3
What is this?  Is it the same as when I put a spot light behind my camera to lighten up a room more?
Very realistic pictures, I am almost getting there.  I def. would like everything to be out of the box, instead of going to a 3rd party site, for those quick jobs and for those clients who don't need to have it look so real.
 Are the wall cabinet doors different on purpose?  How'd you do that?
2 hours ago, DBCooper said:
@kwhitt Yes, nice pictures.  You might want to post the things you want on the suggestions forum though.  Might also want to add a couple more outlets to that kitchen.
@basketballman How are those other area lights different from Chief's area lights?
Thanks DB.  That's an excellent suggestion and I will follow through after Thanksgiving.  We don't use electrical devices at standard placement on kitchen backsplashes.  We use a slanted rough-in box to hide all devices beneath the wall cabinets.
I don't think Bob was saying that Chief's area lights were any different - only that we have them now.
Thanks Michael.  It is just a face that can be sized parametrically and can be rotated/tilted in plan view for convenience - like what i had to create manually.  It is used to simulate a soft light box like they use in interior photography.  Yes, the beadboard was intentionally placed this way.  I used a normal map that I created in Substance Designer.  It's attached if you want to use it.  I had to lower the resolution to be uploaded to the forum but i can send you a high-res version.  The normal made the most sense as opposed to modeling every door size independently.  The normal allows you to resize the doors without "stretching" the beadboard.
I guess I don’t need so many beadboard planks as the pattern is tillable (seamless) but when I created it I used it for a T & G ceiling and I wanted variation in the woodgrain so that the texture didn’t repeat too much.  This image was created prior to the introduction of area lights and could be much improved with the new features.  I’ll make a smaller version once I’ve caught up on my projects.
Quote
Well there you go, I learned something new today.  Now I am glad I didn't give you a hard time about the star light fixture.  ;)
55 minutes ago, kwhitt said:
I don't think Bob was saying that Chief's area light were any different - only that we have them now.
we've had area lights for as far back as I can remember. So I am as confused as DB about the request to add them. Have you used them and you didnt like them? Or you were unaware that we had them, in which case, congrats, we have them, haha :)
Renee – In X15 and prior, an emissive material assigned to an object such as a sphere would not illuminate the scene using PBR.  Attached is such a sphere with Lighting White applied in a room with the auto-light turned off and there is no illumination.  In X16 you can now do the same thing, and the sphere will light the room.  Prior to X16 we did not have real area lights.  Attached is an excerpt from the X16 features list.
LOL.  It was not my first choice nor was the whole country scene!  The client had specifics!
I am referring to the add light tool which is more closely related to other rendering software's area lights as it is not a shadow catcher or receiver like what you have shown:
Chief’s “Add Light” is not an Area Light, nor do they call it that.  It is merely a point or spotlight that lights an area.  Every physically based rendering engine calls object-based emitters “Area Lights”.  This would apply to Vray and Corona Renderer (the standards in the visualization market) – both of which I have used for many years among others.  Below is a definition from the PBR Book.
https://www.pbr-book.org/3ed-2018/Light_Sources/Area_Lights#:~:text=Area%20lights%20are%20light%20sources,each%20point%20on%20the%20surface
It’s a huge leap to equate Chief’s “Add Light” with an Area Light and would be inaccurate.
15 minutes ago, basketballman said:
Here is area lights in Lumion.
  Placement is as a dimensionable rectangle either on ceiling or vertically outside a window or glass door ..
That’s exactly what I’m asking for – a predefined emitter object.  As stated in the original post, I am now using a face and assigning an emissive material to simulate this behavior.  I am sure it will be added eventually.
Sorry kwhitt you're  absolutely right about the distinction of a function of an area light in terms of its lighting quality. I was more speaking to the function of a add light tool such that it is an invisible light source and has the ability to turn off shadows.
I would add that it would be nice if the add light tool could specify a shape so that it was not a shadow catching object or receiving object which we can do in some of the high end rendering softwares. Would be nice to set an object shape and size in the add light tool
Are you asking for something like an added area light (where it produces light but isn't necessarily a visible part of the model), or just the ability to more easily create area lights of basic shapes?
Can you do the work to create an emissive face/rectangle with a specific orientation once and then add it to the library for future use?
This isn't my post, but I just did that and compared a scene using a 'face' versus and added light. The emissive properties of the face did create much better scene lighting, even if the added light did not cast shadows and have the same lumens as the 'face' material.
My 'face' was 24"x24", top at 88" above the floor (the room had a high ceiling), and I used the material 'Lighting - White' with no adjustments.
For me, the ability to turn off visibility, shadows, and reflections of a light source is not needed.  I can; however, see a place for it in product visualizations.  I’ve had this ability available to me in Corona Renderer for years and have never used it.  I guess I see this as a cheat and not physically accurate.  Then again, the very act of using a computer to create a image is the ultimate cheat.  My take is that a well-placed fill light would accomplish the same and would be more accurate, but you are right, most high-end engines offer it.
Ryan - that is what I am exploring today - making a library of various sized planes to simulate softboxes and other studio lighting.  I think for now that is the best solution.
Rob - that's why I say that area lights are a game changer for rendering within Chief.  There is absolutely no comparison to be made between object-base lighting (area light) and the Add Light feature (which is only a point or spotlight emanating from a single point in space).  Area lights more closely resemble lighting in the real world.  I really think this is going to take Chief to a whole new level and I look forward to seeing what users are able to create with it.
so...I have been pondering this for awhile as a lot of my PBR are "dim" or dark, and I say to myself, "this does not look like real life". so I add more lights or change some of the settings.
But, I assume, there is also no such thing as area lights in real life in someone's house. If CA has the model, the backdrop, the sunshine, shouldnt it look like real life without the area lights?
Or are area lights required in order to make it look better in the render than it will actually look like in real life (kind of like taking celebrity pictures with the makeup and the lights to make them look better than they actually d, or like lighting movie sets so we can see the actors face more). But those are done for a purpose which is not..buying a house
And if one adds area lights to a render, how does one know how many actual lights to build the house with to make it look at least close to the render?
Chief X16:
