V. 15 - Cannot resize walls, cannot place objects
mattbeckman
Hello All,
Getting desperate here for an answer that for some reason, I cannot solve on my own.
We have been in V 15 for a month now and I had to upgrade my computer for an adequate graphics card.
Since then, I don't know if I am dealing with computer issues or CA issues in order to trouble shoot.
Today I got started in a new plan and drew a wall- cannot click the wall>>click measurement>>resize. I can only open the object, change length.
Also - cannot go to the door parent tool>>click door>>hover over wall>>place object. It lets me choose the object but does not show the shadowy door over the wall for me to place.
I am sure there is an answer somewhere but I am coming up empty handed.
6 hours ago, mattbeckman said:
cannot click the wall>>click measurement ... can only open the object, change length
Wouldn't be a locked layer if it can be selected and opened.
Definitely sounds like the program isn't drawing selection line-type things - no temporary dimensions, no placement overlay. Certainly sounds like a graphic problem to me.
TeaTime is probably right but it *could* be other things too.
Temp dimensions could be turned off.
Your "selection line" color in your preferences could be white or fully transparent.
If it's not any of those things, then I would look into your video card or driver.  You might want to try updating the drivers to see if that helps.  If not, then I would probably contact tech support (like Ben suggested).
...or the Selection Line color could be the same as your Background color.
If these 2 colors are the same, you will not see the door placement preview and when you select a wall, the dimensions will disappear.
Go to Preferences and make them different colors.
