DefinedDesign Posted August 3, 2023 Share Posted August 3, 2023 Using X12 Looking to get the %room.volume% in a custom Room Schedule. My callouts for this Room Schedule have this macro: %room.schedule_number%. The room label defaults are this: %room.dimensions% Finished Ceiling Height: %room.height.ceilingfinish% Room Area: %room.area.standard% Room Volume: %room.volume% How do I get the %room.volume% from the label default in this new custom schedule? The Schedule Specification Columns does not provide a Room Volume option. Link to comment Share on other sites More sharing options...
robdyck Posted August 3, 2023 Share Posted August 3, 2023 I've used a customized note type and a customized note schedule. I kept the actual note on a layer that did not display in my con docs. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2023 Share Posted August 3, 2023 Add a Custom Field named "Volume" Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 3 minutes ago, robdyck said: I've used a customized note type and a customized note schedule. I kept the actual note on a layer that did not display in my con docs. My apologies, I'm not understanding. How do I make a custom note schedule? Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 1 minute ago, Joe_Carrick said: Add a Custom Field named "Volume" Again I apologize, I'm not comprehending. In the schedule dialog box I can create a Custom Category but where I don't see Volume is under columns even if I uncheck the box next to limit to included categories. Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 Schedule columns are based on the information the can gather from the objects the schedule is set to include. If the Schedule only includes Notes, then only Note information can be gathered and displayed. Open a Note spec and you'll see Object Information has a Custom Fields section. Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 2 minutes ago, TeaTime said: Open a Note spec Do you mean the Callout I created? If no, I'm sorry I don't understand what a Note spec is. Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 1 minute ago, DefinedDesign said: Do you mean the Callout I created? If no, I'm sorry I don't understand what a Note spec is. Yes sry it was Rob that mentioned Notes. But same thing for both--really anything that can be in a Schedule will have Object Information where you can create custom fields for. Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 Sorry correction -- its not the same for both because Callouts can't be in a Schedule which is why Rob said he uses Notes. Use Notes. Place a note in a room, open the Note, add a "Volume" field and set it's field value to %room.volume% Place a Note Schedule and add the Volume column Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 2 minutes ago, TeaTime said: Yes sry it was Rob that mentioned Notes. But same thing for both--really anything that can be in a Schedule will have Object Information where you can create custom fields for. This is my callout, where do I find the custom field to add the Volume for the schedule? Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 2 minutes ago, TeaTime said: Place a Note Schedule Thanks, is a custom schedule the same as note schedule? Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 Yeah, technically all schedules are the same. A "note schedule" is just set to include notes by default. Custom Schedules are just not set to include anything automatically so you can do whatever you want with em. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2023 Share Posted August 3, 2023 Lisa, If you have X15 there's a "Volume" Colum. But it appears you are still using X12. 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 1 minute ago, TeaTime said: Yeah, technically all schedules are the same. A "note schedule" is just set to include notes by default. Custom Schedules are just not set to include anything automatically so you can do whatever you want with em. Thank you, I created the Note and it doesn't seem to be linking to my custom schedule, the note doesn't show a number and their is no field for the Volume in the schedule. Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 3 minutes ago, Joe_Carrick said: it appears you are still using X12 Yes I am Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 5 minutes ago, DefinedDesign said: Thank you, I created the Note and it doesn't seem to be linking to my custom schedule, the note doesn't show a number and their is no field for the Volume in the schedule. It has no number because it's not linked to that schedule, likewise with the Volume column. If you select the Note there's an Edit button on the bottom toolbar to "Create Note Schedule from Note" - that'll make one that inherently includes that Note type. That schedule should have a Volume column to include (so long as you added one to the selected note) Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 3, 2023 Share Posted August 3, 2023 1 hour ago, TeaTime said: Sorry correction -- its not the same for both because Callouts can't be in a Schedule which is why Rob said he uses Notes. Use Notes. Place a note in a room, open the Note, add a "Volume" field and set it's field value to %room.volume% Place a Note Schedule and add the Volume column Just going to drop this here for you in case you feel like supporting the cause 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 13 minutes ago, Renerabbitt said: supporting the cause Yes! Nothing better than established, consistent standard inputs, and clarity to reduce confusion. I liked your request, thanks for suggesting it. Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 1 hour ago, TeaTime said: It has no number because it's not linked to that schedule, likewise with the Volume column. If you select the Note there's an Edit button on the bottom toolbar to "Create Note Schedule from Note" - that'll make one that inherently includes that Note type. That schedule should have a Volume column to include (so long as you added one to the selected note) Thank you! Now to figure out why the volume isn't calculating correctly??? Is there anyway to get the volume to round up? I'm clueless. Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 28 minutes ago, DefinedDesign said: anyway to get the volume to round up? I found this CA KB-01897 article but I can't get it to work... Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 3, 2023 Share Posted August 3, 2023 3 minutes ago, DefinedDesign said: I found this CA KB-01897 article but I can't get it to work... Hard for some of us to provide support for older versions. How did you get a reported value for volume? Was it a predefined macro? Are you including a macro in a custom field that is reporting to the schedule in columns to include? Or was there a volume column to include? Link to comment Share on other sites More sharing options...
DefinedDesign Posted August 3, 2023 Author Share Posted August 3, 2023 1 minute ago, Renerabbitt said: How did you get a reported value for volume? Was it a predefined macro? Are you including a macro in a custom field that is reporting to the schedule in columns to include? Or was there a volume column to include? Created a Note and then >Note Specification >Object Information >Custom Object Fields >Custom Field: Volume >Field Value: %room.volume% CAD >Text >Text Macro Management RoomVolume - (internal_area * (ceiling_elevation - floor_elevation) ).to_cu_ft Copied the RoomVolume per the KB article and created this: roomVolumeRounded: vol = internal_area * (ceiling_elevation - floor_elevation) vol.round(2) Went back to Note Specification and added Room Volume Rounded with a field value: %roomVolumeRounded% Gives me an #Evaluation Error# Link to comment Share on other sites More sharing options...
TeaTime Posted August 3, 2023 Share Posted August 3, 2023 Huh, as far as I know that should work the same - make sure "Evaluate" is checked and Context is "Owner" ? Link to comment Share on other sites More sharing options...
DG1949 Posted August 4, 2023 Share Posted August 4, 2023 13 hours ago, DefinedDesign said: volume isn't calculating correctly If you change to "interior dimensions" in your schedule, instead of "standard dimensions", it may help. I think the "volume" calculation uses interior numbers. Link to comment Share on other sites More sharing options...
robdyck Posted August 4, 2023 Share Posted August 4, 2023 15 hours ago, DefinedDesign said: Room Volume Rounded with a field value: %roomVolumeRounded% Gives me an #Evaluation Error# Use this: %room.volume.round% You will need to add the units at the end of the text or in the column title of your schedule. Link to comment Share on other sites More sharing options...
