Importing CAD file
stager386
When an architect wants to send me a CAD file, what format should I ask for? DWG?
I have already built the house in Chief but there are updates, and he wants to send me his whole file rather than list changes (such as created dormer, moved windows, added a foot to the bathroom etc....).  My job for the client is to create renderings for the project, as well as collaborate on some layout designs.
Thank you!
Yes DWG is preferred but chief can import DXF from sources other than AutoCad.  This will give you the ability to measure things that are not dimensioned and some snap points to work with but not much else unfortunately.   I often ask for a reference PDF when I am being sent a DWG file that can come in handy when there are issues.
Thank you!
 I haven't dealt with this before, so please tell me what I should be expecting. I've imported the DWG file and it appears in the floorplan as a drawing, not in the format where I can use camera views.  Does that sound right?  I thought I was getting a file that would look like a finished product that I could render.
Kate,
I don't know of any file type that can be imported into Chief to do that.  Perhaps a 3D file like SKP or OBJ but from AutoCAD you can't get that.
You are unfortunately going to need to build the model in order to do a rendering.  Tracing over the DWG using walls, doors, windows, etc will get you close.
48 minutes ago, Joe_Carrick said:
Kate,
Excellent. That makes perfect sense. Thanks again!
@stager386 The dwg or dxf files are almost like an etch a sketch.  Just lines that you can trace and measure. The first thing you need to do is to import it into it's own file not into your drawing. Then check to be sure it's at the correct scale. sometimes it may be correct but most of the times it needs to be resized times 48 or 96.
3 hours ago, basketballman said:
How about just a plain, old .PDF
probably as easy to trace over as a .DWG ?
Not at all. Tracing a PDF is a little more useful than just printing it and using that as reference. DWG/DXF is literal CAD data that you can snap onto.
