buzzsaw204 Posted December 22, 2022 Share Posted December 22, 2022 hi, Is there an attribute/macro that I can pull to place in to the text box, to display that Text? for the Wall Spec > Object Info > Description. thank you. Happy Holidays Everyone!! Link to comment Share on other sites More sharing options...
DBCooper Posted December 22, 2022 Share Posted December 22, 2022 Have you tried %description%? 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted December 23, 2022 Share Posted December 23, 2022 2 hours ago, buzzsaw204 said: hi, Is there an attribute/macro that I can pull to place in to the text box, to display that Text? for the Wall Spec > Object Info > Description. thank you. Happy Holidays Everyone!! If you put %object_properties% into the text box ( it will be huge - zoom out ) you will see all the available Macros for the Wall. Even then you may need one of the macro guru's to do you a custom one.... Mick. Link to comment Share on other sites More sharing options...
robdyck Posted December 23, 2022 Share Posted December 23, 2022 16 hours ago, buzzsaw204 said: Is there an attribute/macro that I can pull to place in to the text box, to display that Text? Wouldn't it be simpler to just use a text macro? How are you going to get that information from the wall into the plan view? A referenced arrow? The wall label? A text macro will allow you to place the text in multiple views and allow you to edit all instances at one time. Text with a reference arrow...would you trust that arrow to stay connected to your desired object? Experience has taught me not to trust a referenced arrow for con docs. Link to comment Share on other sites More sharing options...
para-CAD Posted December 23, 2022 Share Posted December 23, 2022 16 hours ago, Kbird1 said: If you put %object_properties% into the text box ( it will be huge - zoom out ) you will see all the available Macros for the Wall. Even then you may need one of the macro guru's to do you a custom one.... Mick. Mac might be different...... I had to use %ObjectProperties% to make it work. No underscore. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 23, 2022 Share Posted December 23, 2022 1 hour ago, para-CAD said: Mac might be different...... I had to use %ObjectProperties% to make it work. No underscore. Its not a Mac vs. PC thing. Its based on what macros you have in your current plan. Chief's latest object properties macro is %object_properties% and reports not only standard name:value pairs but also expanded NVPublisher name:value pairs. It also works in both owner and referenced contexts. Many people are using old templates with old macros that used different naming convention and/or had different functionalities. In addition, some people have both Chief's macros and macros written by other users (which again might be named differently and have different behaviors). Link to comment Share on other sites More sharing options...
Kbird1 Posted December 23, 2022 Share Posted December 23, 2022 2 hours ago, buzzsaw204 said: either one works.... I"m guessing the Arrow isn't connected then? as you shouldn't see the macro , just it's output. As Michael mentioned %object_properties% is what you'll see in x14 chief Templates, ( where I copied it from ) though Joe Carrick has his floating around on the Forum too. M, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2022 Share Posted December 23, 2022 Some of the %object_properties% macros in the OOB Templates don't show everything. In most cases they are limited to the owner object. My versions also show sub-level objects (such as the Room). This is important for referenced macros where using a text box with an arrow. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 23, 2022 Share Posted December 23, 2022 17 minutes ago, Joe_Carrick said: Some of the %object_properties% macros in the OOB Templates don't show everything. In most cases they are limited to the owner object. My versions also show sub-level objects (such as the Room). This is important for referenced macros where using a text box with an arrow. Most people just need to update their templates. The macro Chief provides in the OOB X14 template plan includes everything. Here's what I get for a base cabinet using the OOB %object_properties% macro in an OOB X14 template plan: angle_front_left_depth ----------------------------------- 0 in ----------------------------------- Measurement angle_front_right_depth ---------------------------------- 0 in ----------------------------------- Measurement automatic_countertop ------------------------------------- --------------------------------------- NVPublisher area ------------------------------------------------- 4.693606 sq ft ------------------------- Measurement backsplash_length ------------------------------------ 0 in ----------------------------------- Measurement cabinet ---------------------------------------------- --------------------------------------- NVPublisher SEE ABOVE ---------------------------------------- --------------------------------------- front_cap_length ------------------------------------- 103.356194 in -------------------------- Measurement hole_area -------------------------------------------- 0 sq ft -------------------------------- Measurement material_data ---------------------------------------- --------------------------------------- NVPublisher description -------------------------------------- "Black-Granite" ------------------------ String formatted_size ----------------------------------- "" ------------------------------------- String manufacturer ------------------------------------- "" ------------------------------------- String quantity ----------------------------------------- 4.693606 sq ft ------------------------- Measurement source_description ------------------------------- "Countertop" --------------------------- String automatic_description ------------------------------------ "base cabinet" ------------------------- String automatic_label ------------------------------------------ "B24R" --------------------------------- String back_side ------------------------------------------------ --------------------------------------- NVPublisher actual_type ------------------------------------------ finished ------------------------------- Symbol is_default ------------------------------------------- true ----------------------------------- TrueClass items ------------------------------------------------ size = 0 ------------------------------- Collection resolved_type ---------------------------------------- auto_finished -------------------------- Symbol background_color_from_background ------------------------- true ----------------------------------- TrueClass background_color_from_layer ------------------------------ false ---------------------------------- FalseClass backsplash_area_below ------------------------------------ 0 sq ft -------------------------------- Measurement backsplash_height ---------------------------------------- 3 in ----------------------------------- Measurement backsplash_height_is_default ----------------------------- true ----------------------------------- TrueClass backsplash_material -------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 73 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "White Tile" --------------------------- String backsplash_thickness ------------------------------------- 0.5 in --------------------------------- Measurement backsplash_thickness_is_default -------------------------- true ----------------------------------- TrueClass bevel_inset ---------------------------------------------- 0 in ----------------------------------- Measurement bow_depth ------------------------------------------------ 0 in ----------------------------------- Measurement box_construction ----------------------------------------- frameless ------------------------------ Symbol box_construction_name ------------------------------------ "Frameless" ---------------------------- String box_finish_description ----------------------------------- "" ------------------------------------- String box_interior_material ------------------------------------ --------------------------------------- NVPublisher id --------------------------------------------------- 72 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Color - Snow White" ------------------- String box_material --------------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 72 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Color - Snow White" ------------------- String box_material_description --------------------------------- "Color - Snow White" ------------------- String build_bottom --------------------------------------------- auto ----------------------------------- Symbol build_top ------------------------------------------------ auto ----------------------------------- Symbol cabinet_corner_type -------------------------------------- none ----------------------------------- Symbol cabinet_corner_width ------------------------------------- 0 in ----------------------------------- Measurement cabinet_corner_width_is_default -------------------------- true ----------------------------------- TrueClass category ------------------------------------------------- standard ------------------------------- Symbol comment -------------------------------------------------- "" ------------------------------------- String component_code ------------------------------------------- "" ------------------------------------- String corner_pilaster_depth ------------------------------------ 0 in ----------------------------------- Measurement corner_pilaster_description ------------------------------ "" ------------------------------------- String counter_material ----------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 65 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Black-Granite" ------------------------ String countertop_actual_overhang_back -------------------------- 1 in ----------------------------------- Measurement countertop_actual_overhang_front ------------------------- 1 in ----------------------------------- Measurement countertop_actual_overhang_left -------------------------- 1 in ----------------------------------- Measurement countertop_actual_overhang_right ------------------------- 1 in ----------------------------------- Measurement countertop_corner_type ----------------------------------- rounded -------------------------------- Symbol countertop_corner_width ---------------------------------- 0.375 in ------------------------------- Measurement countertop_corner_width_is_default ----------------------- true ----------------------------------- TrueClass countertop_overhang -------------------------------------- 1 in ----------------------------------- Measurement countertop_overhang_back --------------------------------- 1 in ----------------------------------- Measurement countertop_overhang_back_is_default ---------------------- true ----------------------------------- TrueClass countertop_overhang_front -------------------------------- 1 in ----------------------------------- Measurement countertop_overhang_front_is_default --------------------- true ----------------------------------- TrueClass countertop_overhang_is_default --------------------------- true ----------------------------------- TrueClass countertop_overhang_is_uniform --------------------------- true ----------------------------------- TrueClass countertop_overhang_left --------------------------------- 1 in ----------------------------------- Measurement countertop_overhang_left_is_default ---------------------- true ----------------------------------- TrueClass countertop_overhang_right -------------------------------- 1 in ----------------------------------- Measurement countertop_overhang_right_is_default --------------------- true ----------------------------------- TrueClass countertop_thickness ------------------------------------- 1.5 in --------------------------------- Measurement countertop_thickness_is_default -------------------------- true ----------------------------------- TrueClass custom_fields -------------------------------------------- {} ------------------------------------- Hash custom_pattern_scale ------------------------------------- 1.0 ------------------------------------ Float depth ---------------------------------------------------- 24 in ---------------------------------- Measurement description ---------------------------------------------- "base cabinet" -------------- String door_drawer_material ------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 72 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Color - Snow White" ------------------- String door_drawer_overlay_name --------------------------------- "Full" --------------------------------- String door_handle_down_from_top -------------------------------- 1.375 in ------------------------------- Measurement door_handle_down_from_top_is_default --------------------- true ----------------------------------- TrueClass door_handle_in_from_edge --------------------------------- 1.375 in ------------------------------- Measurement door_handle_in_from_edge_is_default ---------------------- true ----------------------------------- TrueClass door_hinge_up_down_from_edge ----------------------------- 3 in ----------------------------------- Measurement door_hinge_up_down_from_edge_is_default ------------------ true ----------------------------------- TrueClass door_swing ----------------------------------------------- "R" ------------------------------------ String drawer_handle_distance_from_top -------------------------- 0 in ----------------------------------- Measurement drawer_handle_horizontal_position ------------------------ use_default ---------------------------- Symbol drawer_handle_in_from_edge ------------------------------- 0 in ----------------------------------- Measurement drawer_handle_vertical_position -------------------------- use_default ---------------------------- Symbol drawing_group -------------------------------------------- default:_31_-_base_cabinet ------------- Symbol elevation_reference -------------------------------------- from_floor_finish ---------------------- Symbol elevation_reference_to_bottom ---------------------------- 0 in ----------------------------------- Measurement fill_color_from_background ------------------------------- false ---------------------------------- FalseClass fill_color_from_layer ------------------------------------ false ---------------------------------- FalseClass fill_line_weight ----------------------------------------- 1 -------------------------------------- Integer filler_back_left_size ------------------------------------ "" ------------------------------------- String filler_back_right_size ----------------------------------- "" ------------------------------------- String filler_front_left_size ----------------------------------- "" ------------------------------------- String filler_front_right_size ---------------------------------- "" ------------------------------------- String floor_number --------------------------------------------- 1 -------------------------------------- Integer foot_always_present -------------------------------------- false ---------------------------------- FalseClass foot_depth_offset ---------------------------------------- 0 in ----------------------------------- Measurement foot_depth_offset_is_default ----------------------------- true ----------------------------------- TrueClass foot_description ----------------------------------------- "" ------------------------------------- String foot_retain_toekick -------------------------------------- false ---------------------------------- FalseClass foot_size ------------------------------------------------ "" ------------------------------------- String foot_stretch_to_fit -------------------------------------- false ---------------------------------- FalseClass foot_width_offset ---------------------------------------- 0 in ----------------------------------- Measurement foot_width_offset_is_default ----------------------------- true ----------------------------------- TrueClass formatted_size ------------------------------------------- "24"x24"x36"" -------------------------- String framed_separation ---------------------------------------- 0.75 in -------------------------------- Measurement framed_separation_is_default ----------------------------- true ----------------------------------- TrueClass front_pilaster_depth ------------------------------------- 0 in ----------------------------------- Measurement front_pilaster_description ------------------------------- "" ------------------------------------- String front_side ----------------------------------------------- --------------------------------------- NVPublisher actual_type ------------------------------------------ has_face ------------------------------- Symbol is_default ------------------------------------------- false ---------------------------------- FalseClass items ------------------------------------------------ size = 5 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher appliance ------------------------------------ NIL ------------------------------------ NilClass height --------------------------------------- 0.75 in -------------------------------- Measurement is_door -------------------------------------- false ---------------------------------- FalseClass is_drawer ------------------------------------ false ---------------------------------- FalseClass type ----------------------------------------- separation ----------------------------- Symbol width ---------------------------------------- 22.5 in -------------------------------- Measurement [1] ---------------------------------------------- --------------------------------------- NVPublisher appliance ------------------------------------ NIL ------------------------------------ NilClass height --------------------------------------- 5 in ----------------------------------- Measurement is_door -------------------------------------- false ---------------------------------- FalseClass is_drawer ------------------------------------ true ----------------------------------- TrueClass type ----------------------------------------- drawer --------------------------------- Symbol width ---------------------------------------- 22.5 in -------------------------------- Measurement [2] ---------------------------------------------- --------------------------------------- NVPublisher appliance ------------------------------------ NIL ------------------------------------ NilClass height --------------------------------------- 0.75 in -------------------------------- Measurement is_door -------------------------------------- false ---------------------------------- FalseClass is_drawer ------------------------------------ false ---------------------------------- FalseClass type ----------------------------------------- separation ----------------------------- Symbol width ---------------------------------------- 22.5 in -------------------------------- Measurement [3] ---------------------------------------------- --------------------------------------- NVPublisher appliance ------------------------------------ NIL ------------------------------------ NilClass height --------------------------------------- 23.25 in ------------------------------- Measurement is_door -------------------------------------- true ----------------------------------- TrueClass is_drawer ------------------------------------ false ---------------------------------- FalseClass type ----------------------------------------- door_-_right --------------------------- Symbol width ---------------------------------------- 22.5 in -------------------------------- Measurement [4] ---------------------------------------------- --------------------------------------- NVPublisher appliance ------------------------------------ NIL ------------------------------------ NilClass height --------------------------------------- 0.75 in -------------------------------- Measurement is_door -------------------------------------- false ---------------------------------- FalseClass is_drawer ------------------------------------ false ---------------------------------- FalseClass type ----------------------------------------- separation ----------------------------- Symbol width ---------------------------------------- 22.5 in -------------------------------- Measurement resolved_type ---------------------------------------- has_face ------------------------------- Symbol full_overlay_reveal -------------------------------------- 0.0625 in ------------------------------ Measurement full_overlay_reveal_is_default --------------------------- true ----------------------------------- TrueClass glass_material ------------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 127 ------------------------------------ Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Glass Standard" ---------------------- String hardware_material ---------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 71 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Aluminum Brushed" --------------------- String has_appliance_or_sink ------------------------------------ false ---------------------------------- FalseClass has_backsplash ------------------------------------------- false ---------------------------------- FalseClass has_backsplash_at_sides ---------------------------------- false ---------------------------------- FalseClass has_box_material ----------------------------------------- true ----------------------------------- TrueClass has_closed_toe ------------------------------------------- false ---------------------------------- FalseClass has_countertop ------------------------------------------- true ----------------------------------- TrueClass has_custom_countertop ------------------------------------ false ---------------------------------- FalseClass has_cutting_board ---------------------------------------- false ---------------------------------- FalseClass has_diagonal_face ---------------------------------------- true ----------------------------------- TrueClass has_doors ------------------------------------------------ true ----------------------------------- TrueClass has_double_drawers --------------------------------------- false ---------------------------------- FalseClass has_finish_material -------------------------------------- false ---------------------------------- FalseClass has_flat_back -------------------------------------------- true ----------------------------------- TrueClass has_flat_sides ------------------------------------------- true ----------------------------------- TrueClass has_glass_doors ------------------------------------------ false ---------------------------------- FalseClass has_left_extended_stile ---------------------------------- false ---------------------------------- FalseClass has_oven ------------------------------------------------- false ---------------------------------- FalseClass has_right_extended_stile --------------------------------- false ---------------------------------- FalseClass has_stile_between_double_doors --------------------------- false ---------------------------------- FalseClass has_toekick ---------------------------------------------- true ----------------------------------- TrueClass has_undercounter_appliance ------------------------------- false ---------------------------------- FalseClass height --------------------------------------------------- 36 in ---------------------------------- Measurement include_in_schedule -------------------------------------- true ----------------------------------- TrueClass inserts -------------------------------------------------- size = 0 ------------------------------- Collection inset_overlay_clearance ---------------------------------- 0.0625 in ------------------------------ Measurement inset_overlay_clearance_is_default ----------------------- true ----------------------------------- TrueClass is_angled_front_cabinet ---------------------------------- false ---------------------------------- FalseClass is_bow_front_cabinet ------------------------------------- false ---------------------------------- FalseClass is_corner_cabinet ---------------------------------------- false ---------------------------------- FalseClass is_lazy_susan -------------------------------------------- false ---------------------------------- FalseClass label ---------------------------------------------------- "B24R" --------------------------------- String layer ---------------------------------------------------- cabinets,__base ------------------------ Symbol layer_is_default ----------------------------------------- true ----------------------------------- TrueClass layer_line_color ----------------------------------------- 1751754495 ----------------------------- Integer layer_line_style ----------------------------------------- 2 -------------------------------------- Integer layer_line_weight ---------------------------------------- 25 ------------------------------------- Integer layer_set ------------------------------------------------ " Working Layer Set" ------------------- String layer_text_style ----------------------------------------- "Default Text Style" ------------------- String left_extended_stile_size --------------------------------- "" ------------------------------------- String left_side ------------------------------------------------ --------------------------------------- NVPublisher actual_type ------------------------------------------ finished ------------------------------- Symbol is_default ------------------------------------------- true ----------------------------------- TrueClass items ------------------------------------------------ size = 0 ------------------------------- Collection resolved_type ---------------------------------------- auto_finished -------------------------- Symbol manufacturer --------------------------------------------- "" ------------------------------------- String max_left_extended_stile ---------------------------------- 0 in ----------------------------------- Measurement max_right_extended_stile --------------------------------- 0 in ----------------------------------- Measurement moldings ------------------------------------------------- size = 0 ------------------------------- Collection num_corner_pilasters ------------------------------------- 0 -------------------------------------- Integer num_doors ------------------------------------------------ 1 -------------------------------------- Integer num_drawer_glides ---------------------------------------- 2 -------------------------------------- Integer num_drawers ---------------------------------------------- 1 -------------------------------------- Integer num_feet ------------------------------------------------- 0 -------------------------------------- Integer num_front_pilasters -------------------------------------- 0 -------------------------------------- Integer num_openings --------------------------------------------- 2 -------------------------------------- Integer panels --------------------------------------------------- size = 2 ------------------------------- Collection [0] -------------------------------------------------- --------------------------------------- NVPublisher cabinet ------------------------------------------ --------------------------------------- NVPublisher SEE ABOVE ------------------------------------ --------------------------------------- description -------------------------------------- "door - Framed Panel" ------------------ String formatted_size ----------------------------------- "23 7/8"x24 5/16"" --------------------- String hinge -------------------------------------------- --------------------------------------- NVPublisher cabinet -------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- count ---------------------------------------- 2 -------------------------------------- Integer description ---------------------------------- "hidden hinge" ------------------------- String formatted_size ------------------------------- "" ------------------------------------- String pull --------------------------------------------- --------------------------------------- NVPublisher cabinet -------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- count ---------------------------------------- 1 -------------------------------------- Integer description ---------------------------------- "knob" --------------------------------- String formatted_size ------------------------------- "1"" ----------------------------------- String [1] -------------------------------------------------- --------------------------------------- NVPublisher cabinet ------------------------------------------ --------------------------------------- NVPublisher SEE ABOVE ------------------------------------ --------------------------------------- description -------------------------------------- "drawer" ------------------------------- String formatted_size ----------------------------------- "23 7/8"x6 1/16"" ---------------------- String hinge -------------------------------------------- NIL ------------------------------------ NilClass pull --------------------------------------------- --------------------------------------- NVPublisher cabinet -------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- count ---------------------------------------- 1 -------------------------------------- Integer description ---------------------------------- "knob" --------------------------------- String formatted_size ------------------------------- "1"" ----------------------------------- String pattern_angle -------------------------------------------- 0.0 ------------------------------------ Float pattern_color_from_background ---------------------------- false ---------------------------------- FalseClass pattern_color_from_layer --------------------------------- false ---------------------------------- FalseClass pattern_horizontal_spacing ------------------------------- 2 in ----------------------------------- Measurement pattern_vertical_spacing --------------------------------- 2 in ----------------------------------- Measurement provides_back_left_filler -------------------------------- false ---------------------------------- FalseClass provides_back_right_filler ------------------------------- false ---------------------------------- FalseClass provides_front_left_filler ------------------------------- false ---------------------------------- FalseClass provides_front_right_filler ------------------------------ false ---------------------------------- FalseClass right_extended_stile_size -------------------------------- "" ------------------------------------- String right_side ----------------------------------------------- --------------------------------------- NVPublisher actual_type ------------------------------------------ finished ------------------------------- Symbol is_default ------------------------------------------- true ----------------------------------- TrueClass items ------------------------------------------------ size = 0 ------------------------------- Collection resolved_type ---------------------------------------- auto_finished -------------------------- Symbol room ----------------------------------------------------- --------------------------------------- NVPublisher background_color_from_background --------------------- true ----------------------------------- TrueClass background_color_from_layer -------------------------- false ---------------------------------- FalseClass base_moldings ---------------------------------------- size = 1 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "5200 - Interior trim material" -------- String angle ---------------------------------------- 0.0 ------------------------------------ Float comment -------------------------------------- "" ------------------------------------- String component_code ------------------------------- "" ------------------------------------- String component_moldings --------------------------- size = 0 ------------------------------- Collection custom_fields -------------------------------- {} ------------------------------------- Hash depth ---------------------------------------- 0 in ----------------------------------- Measurement description ---------------------------------- "base molding: Default Base Molding" --- String formatted_size ------------------------------- "5/8"x3 1/2"" -------------------------- String height --------------------------------------- 3.5 in --------------------------------- Measurement length --------------------------------------- 512 in --------------------------------- Measurement manufacturer --------------------------------- "" ------------------------------------- String material_list_category ----------------------- "Interior Trim" ------------------------ String room ----------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- supplier ------------------------------------- "" ------------------------------------- String width ---------------------------------------- 0.625 in ------------------------------- Measurement cantilever_underside_material ------------------------ --------------------------------------- NVPublisher id ----------------------------------------------- 11 ------------------------------------- Integer is_default --------------------------------------- true ----------------------------------- TrueClass name --------------------------------------------- "Color - Bone" ------------------------- String ceiling_elevation ------------------------------------ 109.125 in ----------------------------- Measurement ceiling_finish_layers -------------------------------- size = 2 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "5100 - Drywall" ----------------------- String area ----------------------------------------- 114 sq ft ------------------------------ Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Drywall" ------------------------------ String formatted_size --------------------------- "48"x96"x5/8"" ------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 3.75 ----------------------------------- Measurement source_description ----------------------- "" ------------------------------------- String material_list_category ----------------------- "Wall Board" --------------------------- String owner ---------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- thickness ------------------------------------ 0.625 in ------------------------------- Measurement [1] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "5100 - Drywall" ----------------------- String area ----------------------------------------- 112.215278 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Color - Bone" ------------------------- String formatted_size --------------------------- "" ------------------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 112.215278 sq ft ----------------------- Measurement source_description ----------------------- "" ------------------------------------- String material_list_category ----------------------- "Wall Board" --------------------------- String owner ---------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- thickness ------------------------------------ 0 in ----------------------------------- Measurement ceiling_finish_name ---------------------------------- "Color - Bone" ------------------------- String ceiling_insulation ----------------------------------- --------------------------------------- NVPublisher area --------------------------------------------- 112.215278 sq ft ----------------------- Measurement cavity_r_value ----------------------------------- 0.0 ------------------------------------ Float continuous_r_value ------------------------------- 0.0 ------------------------------------ Float depth -------------------------------------------- 12 in ---------------------------------- Measurement description -------------------------------------- "ceiling insulation" ------------------- String formatted_size ----------------------------------- "12"x16"x48" batts" -------------------- String length ------------------------------------------- 48 in ---------------------------------- Measurement num_batts ---------------------------------------- 21.25 ---------------------------------- Measurement owner -------------------------------------------- --------------------------------------- NVPublisher SEE ABOVE ------------------------------------ --------------------------------------- width -------------------------------------------- 16 in ---------------------------------- Measurement ceiling_platform_layers ------------------------------ size = 1 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "3110 - Lumber 1st package" ------------ String area ----------------------------------------- 134.548611 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Fir Framing" -------------------------- String formatted_size --------------------------- "" ------------------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 0 -------------------------------------- Measurement source_description ----------------------- "" ------------------------------------- String rebar_length --------------------------------- 0 in ----------------------------------- Measurement rebar_size ----------------------------------- 0 -------------------------------------- Integer room ----------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- steel_mesh_area ------------------------------ 0 sq ft -------------------------------- Measurement thickness ------------------------------------ 5.5 in --------------------------------- Measurement ceiling_thermal_envelope_area ------------------------ 112.215278 sq ft ----------------------- Measurement chair_rail_moldings ---------------------------------- size = 0 ------------------------------- Collection conditioned ------------------------------------------ true ----------------------------------- TrueClass conditioned_is_set_to_use_default_value -------------- true ----------------------------------- TrueClass crown_moldings --------------------------------------- size = 0 ------------------------------- Collection custom_pattern_scale --------------------------------- 1.0 ------------------------------------ Float dimensions ------------------------------------------- "11'-11" x 9'-5"" ---------------------- String drawing_group ---------------------------------------- default:_36_-_room_fill ---------------- Symbol fill_color_from_background --------------------------- false ---------------------------------- FalseClass fill_color_from_layer -------------------------------- true ----------------------------------- TrueClass fill_line_weight ------------------------------------- 1 -------------------------------------- Integer finished_ceiling_elevation --------------------------- 108.5 in ------------------------------- Measurement finished_floor_elevation ----------------------------- 0.875 in ------------------------------- Measurement floor_ceiling_group ---------------------------------- 1 -------------------------------------- Integer floor_elevation -------------------------------------- 0 in ----------------------------------- Measurement floor_finish_layers ---------------------------------- size = 2 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "Assorted Floors" ---------------------- String area ----------------------------------------- 112.215278 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Maple 5" Plank - Natural" ------------- String formatted_size --------------------------- "5" wide" ------------------------------ String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 3231.8 in ------------------------------ Measurement source_description ----------------------- "" ------------------------------------- String material_list_category ----------------------- "Flooring" ----------------------------- String owner ---------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- thickness ------------------------------------ 0.75 in -------------------------------- Measurement [1] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "Assorted Floors" ---------------------- String area ----------------------------------------- 112.215278 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Foam Underlayment" -------------------- String formatted_size --------------------------- "1/8" thick" --------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 112.215278 sq ft ----------------------- Measurement source_description ----------------------- "" ------------------------------------- String material_list_category ----------------------- "Flooring" ----------------------------- String owner ---------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- thickness ------------------------------------ 0.125 in ------------------------------- Measurement floor_finish_name ------------------------------------ "Maple 5" Plank - Natural" ------------- String floor_insulation ------------------------------------- --------------------------------------- NVPublisher area --------------------------------------------- 112.215278 sq ft ----------------------- Measurement cavity_r_value ----------------------------------- 0.0 ------------------------------------ Float continuous_r_value ------------------------------- 0.0 ------------------------------------ Float depth -------------------------------------------- 12 in ---------------------------------- Measurement description -------------------------------------- "floor insulation" --------------------- String formatted_size ----------------------------------- "12"x16"x48" batts" -------------------- String length ------------------------------------------- 48 in ---------------------------------- Measurement num_batts ---------------------------------------- 21.25 ---------------------------------- Measurement owner -------------------------------------------- --------------------------------------- NVPublisher SEE ABOVE ------------------------------------ --------------------------------------- width -------------------------------------------- 16 in ---------------------------------- Measurement floor_number ----------------------------------------- 1 -------------------------------------- Integer floor_platform_layers -------------------------------- size = 2 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "3110 - Lumber 1st package" ------------ String area ----------------------------------------- 134.548611 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "OSB-Hrz" ------------------------------ String formatted_size --------------------------- "48"x96"x3/4"" ------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 4.25 ----------------------------------- Measurement source_description ----------------------- "" ------------------------------------- String rebar_length --------------------------------- 0 in ----------------------------------- Measurement rebar_size ----------------------------------- 0 -------------------------------------- Integer room ----------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- steel_mesh_area ------------------------------ 0 sq ft -------------------------------- Measurement thickness ------------------------------------ 0.75 in -------------------------------- Measurement [1] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "3110 - Lumber 1st package" ------------ String area ----------------------------------------- 134.548611 sq ft ----------------------- Measurement material_data -------------------------------- --------------------------------------- NVPublisher description ------------------------------ "Fir Framing" -------------------------- String formatted_size --------------------------- "" ------------------------------------- String manufacturer ----------------------------- "" ------------------------------------- String quantity --------------------------------- 0 -------------------------------------- Measurement source_description ----------------------- "" ------------------------------------- String rebar_length --------------------------------- 0 in ----------------------------------- Measurement rebar_size ----------------------------------- 0 -------------------------------------- Integer room ----------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- steel_mesh_area ------------------------------ 0 sq ft -------------------------------- Measurement thickness ------------------------------------ 11.875 in ------------------------------ Measurement floor_thermal_envelope_area -------------------------- 112.215278 sq ft ----------------------- Measurement function --------------------------------------------- "Unspecified" -------------------------- String has_ceiling ------------------------------------------ true ----------------------------------- TrueClass has_floor -------------------------------------------- true ----------------------------------- TrueClass has_floor_supplied_by_room_below --------------------- false ---------------------------------- FalseClass has_monolithic_slab ---------------------------------- false ---------------------------------- FalseClass has_raised_floor ------------------------------------- false ---------------------------------- FalseClass has_roof --------------------------------------------- true ----------------------------------- TrueClass has_shelf_ceiling ------------------------------------ false ---------------------------------- FalseClass include_in_living_area ------------------------------- true ----------------------------------- TrueClass include_in_living_area_is_set_to_use_default_value --- true ----------------------------------- TrueClass include_in_schedule ---------------------------------- true ----------------------------------- TrueClass internal_area ---------------------------------------- 112 sq ft ------------------------------ Measurement layer ------------------------------------------------ rooms ---------------------------------- Symbol layer_is_default ------------------------------------- true ----------------------------------- TrueClass layer_line_color ------------------------------------- 2151678207 ----------------------------- Integer layer_line_style ------------------------------------- 0 -------------------------------------- Integer layer_line_weight ------------------------------------ 18 ------------------------------------- Integer layer_set -------------------------------------------- " Working Layer Set" ------------------- String layer_text_style ------------------------------------- "Default Text Style" ------------------- String moldings --------------------------------------------- size = 1 ------------------------------- Collection [0] ---------------------------------------------- --------------------------------------- NVPublisher accounting_code ------------------------------ "5200 - Interior trim material" -------- String angle ---------------------------------------- 0.0 ------------------------------------ Float comment -------------------------------------- "" ------------------------------------- String component_code ------------------------------- "" ------------------------------------- String component_moldings --------------------------- size = 0 ------------------------------- Collection custom_fields -------------------------------- {} ------------------------------------- Hash depth ---------------------------------------- 0 in ----------------------------------- Measurement description ---------------------------------- "base molding: Default Base Molding" --- String formatted_size ------------------------------- "5/8"x3 1/2"" -------------------------- String height --------------------------------------- 3.5 in --------------------------------- Measurement length --------------------------------------- 512 in --------------------------------- Measurement manufacturer --------------------------------- "" ------------------------------------- String material_list_category ----------------------- "Interior Trim" ------------------------ String room ----------------------------------------- --------------------------------------- NVPublisher SEE ABOVE -------------------------------- --------------------------------------- supplier ------------------------------------- "" ------------------------------------- String width ---------------------------------------- 0.625 in ------------------------------- Measurement name ------------------------------------------------- "Unspecified" -------------------------- String pattern_angle ---------------------------------------- 0.0 ------------------------------------ Float pattern_color_from_background ------------------------ false ---------------------------------- FalseClass pattern_color_from_layer ----------------------------- true ----------------------------------- TrueClass pattern_horizontal_spacing --------------------------- 8 in ----------------------------------- Measurement pattern_vertical_spacing ----------------------------- 8 in ----------------------------------- Measurement perimeter -------------------------------------------- 512 in --------------------------------- Measurement schedule_number -------------------------------------- "" ------------------------------------- String show_room_label -------------------------------------- false ---------------------------------- FalseClass simple_schedule_number ------------------------------- "" ------------------------------------- String standard_area ---------------------------------------- 135 sq ft ------------------------------ Measurement stem_wall_height ------------------------------------- 37.5 in -------------------------------- Measurement stem_wall_top_elevation ------------------------------ 0 in ----------------------------------- Measurement transparent_pattern ---------------------------------- false ---------------------------------- FalseClass type_name -------------------------------------------- "Unspecified" -------------------------- String use_type_for_name ------------------------------------ true ----------------------------------- TrueClass volume ----------------------------------------------- 1006.430773 cu ft ---------------------- Measurement wall_coverings --------------------------------------- size = 0 ------------------------------- Collection wall_material ---------------------------------------- --------------------------------------- NVPublisher id ----------------------------------------------- -32768 --------------------------------- Integer is_default --------------------------------------- true ----------------------------------- TrueClass name --------------------------------------------- "Default" ------------------------------ String schedule_number ------------------------------------------ "" ------------------------------------- String shelf_material ------------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 72 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Color - Snow White" ------------------- String simple_schedule_number ----------------------------------- "" ------------------------------------- String soffit_accounting_code ----------------------------------- "5200 - Interior trim material" -------- String soffit_material_data ------------------------------------- NIL ------------------------------------ NilClass soffit_material_list_category ---------------------------- "Interior Trim" ------------------------ String supplier ------------------------------------------------- "" ------------------------------------- String suppress_label ------------------------------------------- false ---------------------------------- FalseClass toekick_depth -------------------------------------------- 3 in ----------------------------------- Measurement toekick_depth_is_default --------------------------------- true ----------------------------------- TrueClass toekick_height ------------------------------------------- 4 in ----------------------------------- Measurement toekick_height_is_default -------------------------------- true ----------------------------------- TrueClass toekick_material ----------------------------------------- --------------------------------------- NVPublisher id --------------------------------------------------- 72 ------------------------------------- Integer is_default ------------------------------------------- true ----------------------------------- TrueClass name ------------------------------------------------- "Color - Snow White" ------------------- String traditional_overlay_overlap ------------------------------ 0.375 in ------------------------------- Measurement traditional_overlay_overlap_is_default ------------------- true ----------------------------------- TrueClass transparent_pattern -------------------------------------- false ---------------------------------- FalseClass treat_as_undercounter_appliance -------------------------- false ---------------------------------- FalseClass type ----------------------------------------------------- base_cabinet --------------------------- Symbol width ---------------------------------------------------- 24 in ---------------------------------- Measurement 1 1 Link to comment Share on other sites More sharing options...
para-CAD Posted December 23, 2022 Share Posted December 23, 2022 I will go back and investigate further. I tried the underscore version first and it did nothing. When I drilled down the macro tree, the other version was the only non-grayed out option. Link to comment Share on other sites More sharing options...
para-CAD Posted December 26, 2022 Share Posted December 26, 2022 Confirmed. I have been bringing forward a modified Dan Baumann / Rene Rabbit hybrid plan template from X12 and X14, it has differences from pure X14. Thanks M. Link to comment Share on other sites More sharing options...
