bdillard1 Posted March 14, 2022 Share Posted March 14, 2022 Hello, I suppose I could redraw them but I'd like to know what I did wrong please. https://1drv.ms/u/s!AonCBRorVv74rGi9iyjb6dwcmDPq?e=1vL1hV Link to comment Share on other sites More sharing options...
Mark3D Posted March 14, 2022 Share Posted March 14, 2022 i think you have been using the eyedropper paint tool try changing the materials back the there defaults also remove the room wall coverings things should look better after that 1 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 14, 2022 Share Posted March 14, 2022 I concur with Mark above in that you applied a commonly thicker material to a 1/2" thick drywall layer and then thinness is causing the "Z" fighting you are complaining of. When I wish to display brick I use a "Brick 4 or 6" wall type. Short cuts like you applied are "faster" but the results are not assured, emulating how one actually builds in the field do work and are reliable. DJP 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted March 14, 2022 Author Share Posted March 14, 2022 7 hours ago, Mark3D said: i think you have been using the eyedropper paint tool try changing the materials back the there defaults also remove the room wall coverings things should look better after that Thanks - I think I did some of what you recommended but I must have missed a step because the brick is still showing but I have drywall over it. (it doesn't look like it is out of phase though). https://1drv.ms/u/s!AonCBRorVv74rGi9iyjb6dwcmDPq?e=4CHRnT Link to comment Share on other sites More sharing options...
bdillard1 Posted March 14, 2022 Author Share Posted March 14, 2022 1 hour ago, DavidJPotter said: I concur with Mark above in that you applied a commonly thicker material to a 1/2" thick drywall layer and then thinness is causing the "Z" fighting you are complaining of. When I wish to display brick I use a "Brick 4 or 8" wall type. Short cuts like you applied are "faster" but the results are not assured, emulating how one actually builds in the field do work and are reliable. DJP Good advice - my concern is I don't think I want studs in a fireplace insert - do I? I was thinking of going brick, mineral wool then drywall facing the room. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 14, 2022 Share Posted March 14, 2022 15 minutes ago, bdillard1 said: Good advice - my concern is I don't think I want studs in a fireplace insert - do I? Two things. One, you can create a wall type that does not have any wood in it. Two, yes, some fireplace enclosures are framed just like a wall. It just depends on what type of fireplace you're after. 1 Link to comment Share on other sites More sharing options...
65Shelby Posted March 14, 2022 Share Posted March 14, 2022 12 hours ago, bdillard1 said: Hello, I suppose I could redraw them but I'd like to know what I did wrong please. Did you happen to copy/paste any items? Dwellings? I did this the other day when I copied an outbuilding from one plan, into main plan. Half my walls were flashing and looks the way your photo shows. I had to go back and redo the material of each wall and I was fine JSnell 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted March 14, 2022 Share Posted March 14, 2022 Do you know how far away from the origin your model is located? Sometimes if you build the model a long distance from the origin the camera will do this. Also, check your camera clipping planes, adjust them to a smaller number and this could change this effect. But, more likely, the answers above are correct. 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted March 14, 2022 Author Share Posted March 14, 2022 I just noticed - it is 2 walls that show the brick (although they should show sheetrock) and 1 shows correctly. Just for the heck of it - I put two layers of drywall on and it only shows brick - I also tried putting the drywall on both sides of the brick - still shows brick. Tried change the wall type to Brick 4 - still shows brick. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 14, 2022 Share Posted March 14, 2022 How about the other side of the wall ? If it shows drywall then two of the walls are likely inside out. 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted March 14, 2022 Author Share Posted March 14, 2022 17 minutes ago, Chopsaw said: How about the other side of the wall ? If it shows drywall then two of the walls are likely inside out. I tried putting two pieces of drywall on one side, I tried reversing the wall, I tried changeing the wall type, I tried putting drywall on both sides - it still shows the brick. https://1drv.ms/u/s!AonCBRorVv74rGloyOX1RN3O7kCU?e=dwYC6v Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted March 14, 2022 Solution Share Posted March 14, 2022 Change your "Exterior Wall Surface" back to "Default" at the top of the list of "Plan Materials" and you should be good to go. 1 Link to comment Share on other sites More sharing options...
bdillard1 Posted March 14, 2022 Author Share Posted March 14, 2022 Schooled twice on one question! Thanks everyone! Link to comment Share on other sites More sharing options...
