Any guess on my walls surfaces are phasing in and out of existence?
bdillard1
Go to solution Solved by Chopsaw,
  • bdillard1 changed the title to Any guess on my walls surfaces are phasing in and out of existence?
I concur with Mark above in that you applied a commonly thicker material to a 1/2" thick drywall layer and then thinness is causing the "Z" fighting you are complaining of. When I wish to display brick I use a "Brick 4 or 6" wall type. Short cuts like you applied are "faster" but the results are not assured, emulating how one actually builds in the field do work and are reliable.
7 hours ago, Mark3D said:
i think you have been using the eyedropper paint tool try changing the materials back the there defaults also remove the room wall coverings things should look better  after that
Thanks - I think I did some of what you recommended but I must have missed a step because the brick is still showing but I have drywall over it.   (it doesn't look like it is out of phase though).
https://1drv.ms/u/s!AonCBRorVv74rGi9iyjb6dwcmDPq?e=4CHRnT
1 hour ago, DavidJPotter said:
I concur with Mark above in that you applied a commonly thicker material to a 1/2" thick drywall layer and then thinness is causing the "Z" fighting you are complaining of. When I wish to display brick I use a "Brick 4 or 8" wall type. Short cuts like you applied are "faster" but the results are not assured, emulating how one actually builds in the field do work and are reliable.
Good advice - my concern is I don't think I want studs in a fireplace insert - do I?   I was thinking of going brick, mineral wool then drywall facing the room.
Two things. One, you can create a wall type that does not have any wood in it. Two, yes, some fireplace enclosures are framed just like a wall. It just depends on what type of fireplace you're after.
12 hours ago, bdillard1 said:
Hello,
I suppose I could redraw them but I'd like to know what I did wrong please.
Did you happen to copy/paste any items?  Dwellings?
I did this the other day when I copied an outbuilding from one plan, into main plan.
Half my walls were flashing and looks the way your photo shows.
I had to go back and redo the material of each wall and I was fine
JSnell
Do you know how far away from the origin your model is located? Sometimes if you build the model a long distance from the origin the camera will do this. Also, check your camera clipping planes, adjust them to a smaller number and this could change this effect. But, more likely, the answers above are correct.
I just noticed - it is 2 walls that show the brick (although they should show sheetrock) and 1 shows correctly.
Just for the heck of it - I put two layers of drywall on and it only shows brick - I also tried putting the drywall on both sides of the brick - still shows brick.  Tried change the wall type to Brick  4 - still shows brick.
17 minutes ago, Chopsaw said:
How about the other side of the wall ?  If it shows drywall then two of the walls are likely inside out.
I tried putting two pieces of drywall on one side, I tried reversing the wall, I tried changeing the wall type, I tried putting drywall on both sides - it still shows the brick.
https://1drv.ms/u/s!AonCBRorVv74rGloyOX1RN3O7kCU?e=dwYC6v
