Cailin Posted January 7, 2021 Share Posted January 7, 2021 I deleted the "Living Area Calculation" from my floor plan. Where do I make that live again? Thank you! Link to comment Share on other sites More sharing options...
steve_stuart Posted January 7, 2021 Share Posted January 7, 2021 If you do a search here ("living area") you will get a ton of info on this. Here is a screenshot showing a small part of one, might help you out. Link to comment Share on other sites More sharing options...
JJohnson Posted January 7, 2021 Share Posted January 7, 2021 5 hours ago, Cailin said: I deleted the "Living Area Calculation" from my floor plan. Where do I make that live again? Thank you! Tools > Check > Plan Check makes it reappear for some reason Link to comment Share on other sites More sharing options...
Kbird1 Posted January 7, 2021 Share Posted January 7, 2021 55 minutes ago, JJohnson said: Tools > Check > Plan Check makes it reappear for some reason you may need to do it on each Floor..... and last weeks post about this..... Link to comment Share on other sites More sharing options...
steve_stuart Posted January 7, 2021 Share Posted January 7, 2021 42 minutes ago, Kbird1 said: last weeks post about this..... @Kbird1 Hi Mick, do you mind telling me how to link the entire post to another thread? Thanks Link to comment Share on other sites More sharing options...
lbuttery Posted January 7, 2021 Share Posted January 7, 2021 and once again this newbie trap is sprung CA needs to make the solution intuitive as has been suggested for over a decade Lew 2 Link to comment Share on other sites More sharing options...
glennw Posted January 7, 2021 Share Posted January 7, 2021 Maybe a quick search in the help file would help. Quote The Living Area label can be moved or deleted. To restore a deleted Living Area label, select Tools> Checks> Plan Check . You can click the Done button immediately, without actually completing Plan Check. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 7, 2021 Share Posted January 7, 2021 2 hours ago, steve_stuart said: @Kbird1 Hi Mick, do you mind telling me how to link the entire post to another thread? Thanks The time of the post in the top left Corner is a link to the Post , so I right click it and choose Copy link...then paste into a new Thread. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 7, 2021 Share Posted January 7, 2021 3 minutes ago, Kbird1 said: The time of the post in the top left Corner is a link to the Post , so I right click it and choose Copy link...then paste into a new Thread. Or you could use the "Share this post" feature in the top right. Link to comment Share on other sites More sharing options...
steve_stuart Posted January 8, 2021 Share Posted January 8, 2021 @Kbird1@Chopsaw Great, thank you both. Link to comment Share on other sites More sharing options...
CAmichael240114 Posted January 8, 2021 Share Posted January 8, 2021 Make sure this has not been unchecked Link to comment Share on other sites More sharing options...
