Pet Door
BethVanDeusen
Install the Pet Door on the wall next to the door, open the DBX and adjust the size then copy and paste to your door (I found this works best in an elevation view). Also, be sure to adjust the size of the casing and uncheck 'Use Sill/Threshold' (Casing tab).
Beth:
for real life use install the pet door as close to the bottom of the door as you can
my golden ret. has a broken hip and he struggles with "tripping" on the bottom edge
I had to buy the extra large door - normally for St. Bernards etc so he wouldn't have to stoop
plus he is obese from lack of exercise
I've been using petdoors for decades - I recommend the double flap doors for cold weather situations or high winds
sometimes I built an enclave entrance and had two doors at right angles to prevent cold winds from entering house
but the double flap doors work fairly well
I spent less than this vendor so shop around - I believe I got mine from Home Depot
this is just an example of the double flap door
https://www.amazon.com/dp/B01LZ6NOHZ/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B01LZ6NOHZ&pd_rd_w=XET6g&pf_rd_p=f0355a48-7e73-489a-9590-564e12837b93&pd_rd_wg=gOssu&pf_rd_r=RH0F85V7C76T3YWSQX30&pd_rd_r=398e2b06-6e14-43c0-956c-a1a81f8bee7b&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYRzhMOTg2MldMTjEmZW5jcnlwdGVkSWQ9QTA2ODM5MTgyS1M3WEZLMzZUTURXJmVuY3J5cHRlZEFkSWQ9QTA5NTAyMzYxTVo5Sk9WMEtUU0Q1JndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Lew
  • 1 month later...
  • 3 months later...
On 10/25/2020 at 12:58 AM, lbuttery said:
Beth:
https://www.amazon.com/dp/B01LZ6NOHZ/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B01LZ6NOHZ&pd_rd_w=XET6g&pf_rd_p=f0355a48-7e73-489a-9590-564e12837b93&pd_rd_wg=gOssu&pf_rd_r=RH0F85V7C76T3YWSQX30&pd_rd_r=398e2b06-6e14-43c0- https://www.worktime.com/employee-monitoring 956ca1a81f8bee7b&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYRzhMOTg2MldMTjEmZW5jcnlwdGVkSWQ9QTA2ODM5MTgyS1M3WEZLMzZUTURXJmVuY3J5cHRlZEFkSWQ9QTA5NTAyMzYxTVo5Sk9WMEtUU0Q1JndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Lew
oh I'm sorry to hear this about your dog, I hope he gets better! ^_^
Do you know if there is a similar double-leaf door in the bonus catalog?
Hi:
no idea ?
probably not, but doubt if you need it for the plans ?
Ky did fine until Nov 2020 then he weakened and maybe stroke and was euthanized Dec 5 :(
Lew
Hi:
no idea ?
Lew
oh god I'm so sorry to hear that, excuse me! :(
condolences on your loss, but now he's in a better place!
  • 3 years later...
Good morning - I tried to do this, and it didn't work for me. Do you know if there is a way the dog door will actually cut a whole in the man door?
Thanks in advanced!
Short of designing your own door, for every door style you may want to use a pet door in,
I placed two "Euro H Plank" cabinet doors back-to-back - resized them both to be 10"x16"x1.5" and 3" up off the ground to maintain the integrity of the door frame and the door sweep.  I centered them on the back of the door and then moved them 2" forward into the wall.
You can then material paint each side a contrasting color
 image.thumb.png.72a9fe26e1d46110f987aab5d58b6c7e.pngimage.thumb.png.fd83444b132c673f2e2407c9d316f587.png
Or view them easily in technical or hand drawn lines.
image.thumb.png.1d5af73272773cc409eec58e7ba2ed42.pngimage.thumb.png.e8731ee6fc10b1e69191c1701db94db9.png
You can cad block the two doors and save this to any library to use on any door style.
This doesn't create a hole, but then we look at all our other doors closed typically, so showing a louvered flap like above, or using a shaker panel cabinet door style should suffice.
FWIW, I always try to put pet doors in a wall rather than a door.  If the house is later sold and the purchaser doesn't have a pet then the door doesn't have to be replaced.  It's much less expensive to just close up the opening in the wall.
