timmy123 Posted October 20, 2014 Share Posted October 20, 2014 Hi, I have a hilly site and would like to make sure my building does not exceed 30 feet from the terrain, is there a way to copy the terrain and lift it by 30 feet(then enable disable it) to check that all the ridges/building height are below 30 feet? Thx, Link to comment Share on other sites More sharing options...
lbuttery Posted October 20, 2014 Share Posted October 20, 2014 Timmy: I don't think so one method I use to check the building envelope for height restriction' is to place walls around the lot perimeter and set them to transparent set this "room to have a ceiling of 30' but no roof then take a 3d view and rotate around and see any terrain pokes thru see post #10 in this thread: http://www.chieftalk.com/attachment.php?attachmentid=1866&d=1118600499 Lew Link to comment Share on other sites More sharing options...
tommy1 Posted October 20, 2014 Share Posted October 20, 2014 Timmy, I certainly don't follow your approach. I'm not sure anyone will be able to give you a good answer without seeing the plan or knowing much more information. I for one would have to see how you did your terrain. Is the terrain complete? Is the house already placed in the correct location on the property? Is the building platform height set correctly based on the house location on the terrain and elevation data (heights)? If the house is sitting on an area of the terrain where the terrain is sloped, then the ridge heights will vary from the ground around the house due to the slope. If the house is sitting on an flat part of the terrain, then is a simple math calculation you can do to get a quick estimated height. How much of the foundation is exposed from the ground? This will make a difference on the building pad height. Are you asking this question because you have an aerial easement on the property? If so, are you showing it on a site plan? Certain questions I feel are better to ask with one on one help online or in person because it would take way too long to answer it here without having many posts. However, if someone has already seen the plan then maybe they can give you some good answers. I see you have some previous posts about importing or exporting surveys. BTW, I have to show some ridge heights in elevations to the planning department. Doing it Lew's way would not help me for permitting. Link to comment Share on other sites More sharing options...
dshall Posted October 20, 2014 Share Posted October 20, 2014 Believe it or not, The Bridge Troll knows what he is trying to do without a plan. Go to TERRAIN SPECIFICATION<GENERAL<BULDING PAD and change that number in the box by 30'...... either positive or negative, you figure it out, this will now hide your building if you do not exceed the 30' height limit. If you house is over 30' above grade, you will see it sticking out of the terrain. A very clever usage to determine if the house exceeds the maximum height limit Link to comment Share on other sites More sharing options...
ebdesign Posted October 20, 2014 Share Posted October 20, 2014 You can probably get the same info from a simple elevation outside the terrain perimeter. Link to comment Share on other sites More sharing options...
dshall Posted October 20, 2014 Share Posted October 20, 2014 You can probably get the same info from a simple elevation outside the terrain perimeter. Not so, Imagine a terrain that has dips and rises and you have a model with hips and gables and different plate heights at different areas.... I think Timmy is being quite clever in determining if any point of house exceeds the 30' height limitation at any point directly below any point of house. Link to comment Share on other sites More sharing options...
lbuttery Posted October 20, 2014 Share Posted October 20, 2014 Doing it Lew's way would not help me for permitting Tommy: yep, meant for visual verification Lew Link to comment Share on other sites More sharing options...
jollywheat Posted October 21, 2014 Share Posted October 21, 2014 morning Timmy, 1. turn off all layers except the terrain & make the skirt 10mm (½") thick & "follow terrain". 2. take an orthographic full overview. 3. export 3D model (any are fine) 4. import 3D symbol (or drag & drop into plan) 5. save as symbol & place on its own layer. 6. overlay it on the terrain 7. give it the correct elevation & you're good to go. regards, Brian Link to comment Share on other sites More sharing options...
ebdesign Posted October 21, 2014 Share Posted October 21, 2014 I thought it would have been measured from a single hi/lo or average natural grade to highest point of roof; average roof hgt, or something like that. I've never had to do it any other way. My mistake. Link to comment Share on other sites More sharing options...
dshall Posted October 21, 2014 Share Posted October 21, 2014 I thought it would have been measured from a single hi/lo or average natural grade to highest point of roof; average roof hgt, or something like that. I've never had to do it any other way. My mistake. Jim, come to Cali and I will teach you all sorts of funky things. Link to comment Share on other sites More sharing options...
ebdesign Posted October 21, 2014 Share Posted October 21, 2014 You forget Scott, that I am "in" Cali. But Cali is a very very big state & I am only familiar w/ how this issue is dealt w/ in jurisdictions in & around LA & SF. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 21, 2014 Share Posted October 21, 2014 How is it possible to be in SF and LA. Link to comment Share on other sites More sharing options...
KilgoreTrout Posted October 21, 2014 Share Posted October 21, 2014 "How is it possible to be in SF and LA?" I can think of one way but it involves a chainsaw and it might be a bit messy. 1 Link to comment Share on other sites More sharing options...
ebdesign Posted October 21, 2014 Share Posted October 21, 2014 Perry, Come to my office and I will teach you all sorts of funky things. Link to comment Share on other sites More sharing options...
dshall Posted October 21, 2014 Share Posted October 21, 2014 You forget Scott, that I am "in" Cali. But Cali is a very very big state & I am only familiar w/ how this issue is dealt w/ in jurisdictions in & around LA & SF. Yeah, I get it, heck fire, I think where I am at, I can probably come up with at least 3 different definitions of height above grade depending on the jurisdiction. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 21, 2014 Share Posted October 21, 2014 Perry, Come to my office and I will teach you all sorts of funky things. Jim, I don't want to come alone, you know, that saw in half thing. Link to comment Share on other sites More sharing options...
dshall Posted October 21, 2014 Share Posted October 21, 2014 Jim, I don't want to come alone, you know, that saw in half thing. LOL..... don't ask me to tag along. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 21, 2014 Share Posted October 21, 2014 Yes you are Scott, and you can go first in the door, I'll bring up the rear. It depends where his office is. Link to comment Share on other sites More sharing options...
ebdesign Posted October 21, 2014 Share Posted October 21, 2014 You guys can come to my office any time you like after sundown. You will be the guests of honor for the evening & we can have a bite together. Hahahahaha. http://soundbible.com/2055-Evil-Laugh-Male-6.html Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 21, 2014 Share Posted October 21, 2014 Ok, that it, I'm out. Link to comment Share on other sites More sharing options...
glennw Posted October 22, 2014 Share Posted October 22, 2014 Use a 30' high Terrain Feature and give it a transparent material. Link to comment Share on other sites More sharing options...
dshall Posted October 22, 2014 Share Posted October 22, 2014 Use a 30' high Terrain Feature and give it a transparent material. Okay, probably the perfect answer. But just to confirm...... If I had a 5' thick driveway, would that effect the transparent terrain height. Link to comment Share on other sites More sharing options...
glennw Posted October 22, 2014 Share Posted October 22, 2014 d dot, What do you mean Okay, probably the perfect answer. Of course it's the perfect answer! The driveway doesn't make any difference - height is measured off terrain. A variation is to give the Terrain Feature a Height of 30' and a thickness of, say 1/2" and you will just get a floating thin plane that mirrors the terrain at 30' high. 1 Link to comment Share on other sites More sharing options...
ebdesign Posted October 22, 2014 Share Posted October 22, 2014 Nice one Glenn. Gotta remember that one. Link to comment Share on other sites More sharing options...
Chief16Designer Posted October 23, 2014 Share Posted October 23, 2014 Draw a line an envelope 30' from the low and high showing the side elevation of the house ,adn the grading plan Link to comment Share on other sites More sharing options...
