DH7777 Posted February 20, 2020 Share Posted February 20, 2020 Can we change mortar colors on any brick material? If so how? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 20, 2020 Share Posted February 20, 2020 Unfortunately not, the brick and mortar are not independent of each other, a texture is just a pic and within CA the only option is to use the blend color with texture but this will affect everything, the brick will also change. The only way would be to load the texture into Photoshop and manipulate it there and then save it back to your textures for use in CA. Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2020 Share Posted February 20, 2020 14 minutes ago, DH7777 said: Can we change mortar colors on any brick material? If so how? Make your own brick texture...Check out the link below. https://brick.com/masonry-designer Link to comment Share on other sites More sharing options...
SNestor Posted February 20, 2020 Share Posted February 20, 2020 18 minutes ago, robdyck said: Make your own brick texture...Check out the link below. https://brick.com/masonry-designer Unfortunately the brick designer tool from Acme only works on PC's running "Windows". I'm on a MAC...such tech discrimination... The good news is that if you are member of Dan Baumann's Chief Experts Academy you can download all the brick textures. Unfortunately...there isn't any "course brick" as Chief calls them...just brick textures for standard running bond. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 20, 2020 Share Posted February 20, 2020 6 hours ago, SNestor said: I'm on a MAC...such tech discrimination... Man, that is too bad! The ACME tool is great, especially for changing the mortar color. Link to comment Share on other sites More sharing options...
robdyck Posted February 20, 2020 Share Posted February 20, 2020 If someone knew what they wanted, it'd be easy enough to make it for them... including soldier courses. Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 20, 2020 Share Posted February 20, 2020 You can also do a Google search for "brick textures" and click on "Images" and see if you can grab something that will work. Link to comment Share on other sites More sharing options...
DzinEye Posted February 20, 2020 Share Posted February 20, 2020 9 hours ago, robdyck said: Make your own brick texture...Check out the link below. https://brick.com/masonry-designer Pretty slick, thanks for sharing that Rob 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 21, 2020 Share Posted February 21, 2020 14 hours ago, DzinEye said: Pretty slick, thanks for sharing that Rob You're welcome. If I've got a mostly brick home that I need to show the client in 3D, I'll make several different brick textures for everything, sills, soldiers, sailors, running bond, 1/3 offsets etc. Another tip: Lets say you want to add a trim row in a herringbone pattern. You can make several different images of individual bricks, import the images into a cad detail in chief, place a few of the bricks manually and use a screen capture to create the a herringbone texture of the same brick. Obviously it's not the most high quality image but it will be clear enough for the purpose. I feel it makes it easier to be creative with the design when you can properly visualize it and present it. Link to comment Share on other sites More sharing options...
latifimr Posted February 14, 2024 Share Posted February 14, 2024 Here is another resource https://architextures.org/ You can select a brick or stone pattern and then edit the parameters to get the result you are looking for. Link to comment Share on other sites More sharing options...
