Can Chief X11 make a proper tile roof gable edge?
John_B
Getting tired of incorrect Tile Roof Gables, I've looked high and low and can't find any dialog boxes to make them look correct...is there a way to have the Trim Tile go over the edge like the pic or is this function still non-existent?  Not really in the mood to create my own!
39 minutes ago, Chopsaw said:
Not really sure if Joe has posted his library or just talked about it as I can't seem to find it, but here is another to check.
I didn't put much effort into this but just adding a round molding to the gutter designation?
You could build a pretty simple 3d molding for the eave
Tried the gutter but didn't work....tried creating a Tile and then slightly re-oriented it 3 degrees for proper overlap but I think I need to taper the tile so that it overlaps properly (top is fine but the front isn't)...anyone with ideas how to taper this singular tile???  Getting awfully close using the Distributed Object Tool and offsetting the object -3" from ceiling!!!
P.S. I left it concrete color for visual clarity lol!!!
3 hours ago, Chrisb222 said:
I believe I saw a thread where Joe had a method for generating 3D tiles for not just the edge but also for the entire roof, since the flat pattern is especially fake looking. Might be worth finding that thread.
Yes he did but it's a lot of extra work.
  • 2 years later...
Hello! Does anyone know what this type of roof is called? It looks like there is some type of molding under the roof overhang. I can’t find it anywhere online. Any help would be much appreciated!
What exactly are you asking?  The term used here in Phoenix for the Molding under the the roof ends is a "rolled soffit".  This is made by using a styrofoam molding and stucco applied over it.  Here is where you add it in Chief:
