Print Model in X11 - Where did it go???
Robertto
47 minutes ago, solver said:
That's not what the Print Model function was for.
Eric,  I think you might be wrong.  This would likely work better than anyone could imagine. Have not researched the required file formats but this could open up a lot of creative new ideas.
I thought Print Model printed paper that you could cut out and use to create a 3D model.
Print Model
The Model Maker allows you to print scaled drawings of wall and roof surfaces in your plan that can be assembled into a 3D model. Three types of prints are created: walls, roof planes, and a floor plan wall layout template for each floor.
The system arranges as many wall or roof sections as possible onto a single sheet. For larger scale models, a printer with a larger sheet sizes is helpful. If any wall surface, roof surface, or floor plan view covers more than one sheet, it prints by itself on the number of sheets required. Models with large surfaces may require a lot of paper.
Yes but just think if you did not need scissors and could cut it out of 1/4" mahogany plywood with laser precision in half the time.
Yes, I know. Years ago I used the function to print on poster board. With the advent of new technology, I was hoping to rekindle my use of the function. While researching the latest in 3d laser printers, I was thinking the function could be used on the wood media to create models. Seeing how the printers work, it should be possible.
try MENU - FILE - EXPORT - EXPORT 3D MODEL (STL)
STL is the format 3D laser printers use
in the reference manual do a search on STL
another choice might be EXPORT COLLADA - which is a .dae file
I have been on this forum since 2004 and the paper "Print Model" was discussed - maybe - a dozen times
not a very widely used feature
Lew
that may be a reason to keep X10 installed if anyone needs that feature
X8 is needed to open the old plan format of .plo,.pl1 etc from ver 9 and earlier
or the X8 client viewer
if STL doesn't work for this - then I may need to keep X10 installed
as I did have some plans to print foam models of the historic Buttery Elevators at the Niagara Whirlpool
and the Buttery Sawmill in Niagara Falls and in Silvermine CT
and Terrapin Tower at the brink of Niagara Falls
Lew
We deprecated the Print Model feature because it was very fragile and rather expensive to maintain.  And, to be perfectly honest, it really didn't work very well.  We had a long discussion about whether or not we should rewrite it or get rid of it and you can see that we decided to deprecate it.  The general feeling was that it was not cost effective to rewrite it based on the very few people that actually used it.  More people seem to be interested in using the modern 3D printers that work with an actual 3D model instead of the old 2D printer which required you to manually cut out and assemble a model.
If you feel strongly that this was a feature that you will miss, please feel free to contact our tech support team and voice your concerns.  Or, you can post something on the suggestions forum asking us to bring it back.
Thanks for responding Dermot.
I have not seen much in the way of positive presentable results from 3D printers at a reasonable price point yet.
This new technology may tip the tables by providing the choice of materials and precision required to modernize a very old technique.
It would require some research to know the level of compatibility but if Chief was to buy a laser cutter and offer a few choices of materials people who are designing their own homes or Architects that are getting started could use the service before investing in their own machine.
While it has been a while and I wasn't specifically an architectural modlelmaker all the time, I still have enough experience in it to have some idea. I think fussing about this being missing is scratching things that don't (or shouldn't) itch.
  • We still can export for 3D printing which appears to be where the model making industry  has headed at least for better presentation models.
  • Based on tests I tried out of curiosity the software doesn't generate I would want to build a model by hand if it were more than a simple box with multiple stories.
  • If building from scratch using boards I'd be working with detail from view and making some adjustments. With acrylic or bass wood I only want dimensions since that is table saw work. Same goes for massing models made with closed cell foam.
  • Lasers-there are plenty of options to outsource laser (or water jet) cutting in most localities. I'd been doing that since the mid 80's. We never used it for facades, more like scrolled railings, complicated surface details, and it could be useful for terrain contours. Thicker materials start to have a slight bevel on the edge creating issues in assembly. At first we just sent line art, later we sent dwg. Again you can get that from detail from view.
  • For smaller outfits that have a need look around for an old school architectural modelmaker, many are in need of any work, might get a deal.
    31423
    jomax77
    jomax77
  • Similar Content
    • By basilbabaa
      SITUATION:  X13 3D renders, when compared to X12, appear blurred, washed out, less vibrant in quality and the vector renders have excessive line weights in X13
      Rather than hijack a previous topic thread, I am starting this topic as a result of a side conversation that emerged here-in:
      It appears that there are others experiencing this same issue, and so I thought I would begin this here in it's own topic thread.
      Here is a Dropbox link to image and video files (generated on both a i9 and M1 Pro Max chips) depicting the issue: https://www.dropbox.com/sh/9zt4tagbuhsfkbi/AABsTnIW6DjT5uExeP6e5mcAa?dl=0
      As a note, I have already opened a support case with Chief Technical Support and they have graciously offered to look into it:
      If anyone else is noticing lesser quality output with 3D rendering in X13 as compared to X12, perhaps we can share our experience and thoughts here as well as with support towards a workable solution.
    • By decorators3
      Hi
      I have just  purchased an Alienware  laptop - here is the system details,
      WINDOWS 11
      AMD Ryzen 7 5800H with Radeon Graphics
      Nvidia GeForce RTX 3070 Laptop GPU
      AMD Radeon (TM) Graphics
      16Gb memory
      8GB Storage/TTB SSD
      Can anyone tell me if this is sufficient  to run X11
      I have 30 days to return
      Much appreciated
    • By Doug_N
      My projects are increasingly moving into the digital submission world.  In digital format, various municipalities are setting up criteria for acceptable submission standards that are divergent.  That is to say, each municipality is reinventing the wheel.  So far as I can tell, no two municipalities have adopted the same submission standards, and so submission has become a major task up from a simple formality.
      The Province of Ontaria adopted a standard method for submission of paper documents.
      1) Fill out the mandated building permit form (mandated by the Ontario Building Code Act) that all municipalities had to accept.
      2) Provide at least 2 copies of the drawings in whatever scale is shown on the drawing.
      3) Pay the fee by cash or cheque
      Simple and pretty much the same everywhere.
      Electronic Submission Nightmare
      Easiest.
      1) Same as 1 above in PDF
      2) Same as 2 above except one PDF file (PDF must not exceed 5meg. Limit for most email servers)
      3) Same as 3 above but email Interac transfer
      4) Reply to comments from the plan examiner sent by email.  Send revised pages to the examiner in PDF
      Hardest:
      1) Create an on-line account with the municipality
      2) Fill out an on- line application form
      3) Register all parties (Owner and Agent at a minimum) and these people also have to participate in the on-line experience.
      4) Create individual PDF files for each drawing page to be submitted
            a) Each page to have proscribed blank area (2" x 5") for municipal stamps and comments,
            b) Each page to have a name that corresponds to the title block name
            c) Each PDF to be in vector format.  Raster format is not acceptable. (CA does not support vector PDF)  I suspect the vector PDF would be much smaller than a raster PDF)
            e) Each page has to be a flattened file, no layers
            d) Each page must not have any security features that would prevent editing or commenting (try to convince an Engineer who has stamped the drawing to do this!)
            f)  PDF file size must not exceed (put in some arbitrary limit here.)
      5) Pay the fees as required, usually on line,
      6) Try to understand the matrix of comments that contain examiner's comments.
      7) Upload revised drawing.
      8) Comment on the examiner's matrix table.
      As a result of all of this I have been experimenting with PDF print drivers, and Winzip PDF Compressor.
      My hat is off to the programmers at CA!   The PDF print driver included with CA out performs all of the other print drivers that I have installed on my computer for file size.
      Now if only I could automatically print, as a batch, all drawing files with an automatic link to the layout page title and page number or label.  That would be amazing.
      I wonder if some of that might be achieved in Ruby?  If CA made a printing template that allowed for individual pages as a batch print?
    • By TimelessJohn
      Hi All,
      I have a small insignificant detail problem that I wish to resolve and wonder if anyone has a Tip or Trick to fixing the fact that my Steel I Beams show up perfectly in my Posts and Deck patio beams but not in my roof beams.
      I have changed all of my defaults to I Beams in my settings to no avail, just curious if this a detail I will have to learn to live with or a glitch in Chief?
      Also I would like my I beams to show in the interior walls and imagine in order for this to happen I will need to create a niche and paint it black steel? Correct?
      Please see attached image.
      Thank you in advance,
      John
      Steel I Beam Issue.pdf
    • By CharlesVolz
      I am a creative designer who has acquired unique experiences and perspectives from my collection of work as a designer and builder. I have degrees in structural engineering (BS Rice University) and architectural engineering (MS University of Texas at Austin) and have planned, designed, developed and built various, diverse projects over my 30-year career.
      I am a member of the American Institute of Building Design ("AIBD"), which provides quality continuing education to ensure its members remain current with technology, materials and building codes. AIBD holds its members to the highest standards of ethics and professionalism.
      I utilize the latest technology like GoToMeeting to work with customers live online and OBS Live to record "how-to" videos for builders, designers and DIYers, instructing home design using Chief Architect. Training includes Chief Architect versions X10, X11, X12 and X13 for beginners to intermediate.
      I have worked with owners, builders, designers and architects from all over the U.S., Canada, New Zealand and England. I offer time-saving design assistance as well as expert training in Chief Architect. I am available to design your home from concept to working drawings, assist you in learning Chief Architect and/or improve your existing home design.
      Whether you need a home designer or just a few hours of training, I can accommodate you.
      Regards,
      Charles
      Charles K. Volz
      Castlerock Designer Homes
      947 Cheyenne Creek
      San Antonio, Texas 78258
      Phone:  210 744-7489
      Email:   CVRE@sbcglobal.net
      Skype:   CharlesVolz
      Web:     CastlerockDesignerHomes.com
